hello, I have a Visio p50 HDTV20A and the bottom half of picture is yellow red with pink lines floating is my tv shot?? or can I replace a board of some sort?? any help would be amazing.
vizio p50 hdtv20a half screen pic if problem attached
Tags: None
Re: vizio p50 hdtv20a half screen pic if problem attached
Just saying, if it were mine, that's the board I would replace.Last edited by cliff_hootarski; 03-22-2013, 07:03 PM.Comment
You should be able to test the buffers for shorts. This article deals with samsung but I would imagine the procedure is same. Pictures will help you get more assistance.Comment
Sorry, forgot the link:
http://blog.coppelltvrepair.com/2010...er-boards.html
And here is a video:
https://www.youtube.com/watch?v=51SZsfH60EYComment
I'm going to disagree. The picture doesn't go crazy at exactly half of the screen. Probably the upper buffer -- one lower IC failed -- meaning the chained signal is getting lost for the rest.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Now that you mention it, I do see it's not exactly half the screen, and I would agree with your diagnosis.Comment
i have the p50 hdtv20a. one of the buffer chips on the upper buffer board was noticeably burnt out, but i couldn't see anything wrong with the ysus board. i replaced the bad buffer chip, now the tv powers on, but only the top 1/4 of the picture comes on. ideas?Comment
Could be other buffer chips bad. The signal between each is chained, so if one goes bad the signal can get lost.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
There are 4 buffer chips per board, and 2 boards. since the top 1/4 of the screen shows picture, i'm guessing the top 2 are working, but something with the lower 2 aren't chaining the signal correctly? and since they aren't chaining, they also cause the lower buffer board to malfunction?Comment
What I'm saying is it's possible that there are additional chips that are failed. In this case I'd look at replacing either the second or third chip, most likely third, from the top.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Check if -Vsc and Vsch are OK. You may only be able to locate -Vsc.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by valvashonThe 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it... -
by Raulnngood night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the... - Loading...
