DEG LCD TV(no model number) WITH BACKLIGHT WORKING BUT NO PICTURE, NO SOUND
+ More Options
Posts
    Re: DEG LCD TV(no model number) WITH BACKLIGHT WORKING BUT NO PICTURE, NO SOUND
    Originally posted by reality
    Yes! i can see it. how did you get that board? I thought it is not common. What do you mean by "initial aps"?
    It is a very common part. Used in lots of different brands of TVs.
    Initial APS is in the menu, try turning it on, then press power button to turn off, then turn it on again. Should power up as if it were new from the box.
    The EEPROM I think can be replaced with a blank one, but first, you will need to check the part # on it. Please can you read off the part numbers.
    • reality
      • Mar 2013
      • 50
      • Nigeria
      Yeah Tom66, the part # is 24c32wp.
        So that is an EEPROM.
        Can you source a replacement part locally or from a distributor?
        It doesn't need any program, it can be blank.
        • reality
          • Mar 2013
          • 50
          • Nigeria
          Ok. Tom66, i will source for it locally tomorrow since today is Sunday and will give you feedback how it goes. Thanks so much brother! you have been so helpful, i really appreciate.
            Does yours have that brown wire for a factory modification?
            Once you install that EEPROM you may have to adjust everything in the service menu. Colours etc may be wrong without doing that.
            Remember to keep the original EEPROM as a spare, in case you need it!
            • reality
              • Mar 2013
              • 50
              • Nigeria
              #26
              No! mine does not have that brown wire connected. Does it mean anything i need to know.However, i will do as you have instructed. Thanks a lot.
                Just remember to install the modification wire in the same place if it exists on your board.
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Tom
                  I have read somewhere that a set should still work without an eeprom in place
                  but as you say with odd settings. Any changes made in that state will be lost
                  when the set is switched off. Is that something he could try?
                    Possibly, but it did not work in my case on one Vestel. When I installed a blank eeprom it booted but was confused and had to be reconfigured.
                    • reality
                      • Mar 2013
                      • 50
                      • Nigeria
                      #30
                      Tom, should i try it without the eeprom, is it not going to cause a damage to the set?
                        I don't think it will work, but I doubt it will cause damage if not.
                        • reality
                          • Mar 2013
                          • 50
                          • Nigeria
                          #32
                          Ok! let me try then.
                            Carefully use a flat-head screwdriver to pry it out -- careful not to bend any pins.
                            • reality
                              • Mar 2013
                              • 50
                              • Nigeria
                              #34
                              Ok! i will be careful. thanks.
                              • reality
                                • Mar 2013
                                • 50
                                • Nigeria
                                #35
                                I tried it Tom, and this is what i saw on the screen-image below-. I made the necessary adjustments but it still did not produce any picture or sound like you earlier said. But does this little change prove that if i replace the eeprom it will work?
                                  Just proceed through the setup stages - select country, tune TV, etc. I think you'll need a blank eeprom to test it properly.
                                  Or did you try that and it did not work?
                                  I would try a blank eeprom but if not then the main board may need a replacement or repair depending on price.
                                  • reality
                                    • Mar 2013
                                    • 50
                                    • Nigeria
                                    #37
                                    Do you mean a new eeprom when you say a blank eeprom?
                                      Yes.
                                      • reality
                                        • Mar 2013
                                        • 50
                                        • Nigeria
                                        #39
                                        ok. then, like i said before, i will source for it tomorrow and try it. I pray it works.
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #40
                                          You could try putting the old one back in - just to see what it does- perhaps just taking it out will change something and putting it back may re-write it.
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • Mgiffune
                                            by Mgiffune
                                            I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                            I ordered a supposedly β€˜new' Tcon board this time, and
                                            06-09-2024, 10:28 AM
                                          • DKWS89
                                            Sony XBR 49x900E - Sound and backlight on but no picture
                                            by DKWS89
                                            Hey Guys,
                                            So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                            All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                            12-14-2023, 04:30 PM
                                          • Nicktronic
                                            Sony XBR-55X900F No picture, no sound no backlight
                                            by Nicktronic
                                            Hey,
                                            I have this subject TV and when I plug it in I don't get a picture, backlight or sound. The remote and power buttons don't seem to do anything. I've metered the signals on the following after plugging in the TV;
                                            Power Supply Board Connector CN6401 between PSU, MB, TCON
                                            PIN 1 - BL_ERR - 0VDC
                                            PIN 2 - BL-ON - 0VDC
                                            PIN 3 - POWER_ON - 3.47VDC
                                            PIN 4 - N/C
                                            PIN 5 - STANDBY3.3V - 3.50VDC
                                            PIN 6 - N/C
                                            PIN 7 - GND - 0VDC
                                            PIN 8 - GND - 0VDC
                                            PIN 9 - N/C
                                            PIN 10 - REG12 - 12.69VDC
                                            PIN 11 -...
                                            04-15-2023, 04:41 PM
