Vizio 26" VW26L Flickering white screen
  • CR Designs
    • Dec 2012
    • 430
    Re: Vizio 26" VW26L Flickering white screen
    Originally posted by budm
    Not good news for your chassis, you have one of those LCD panel with integrated T-CON board (some kind of setup uses in the small PC LCD monitor). You will have to take the LCD pnael apart to get to the board to check the fuse, not sure if it will be worth it for 26" TV
    Budm What size do you think the board is . I can see the edge of a green board where the ribbon cable connects to the frame but it is small. That's the board your referring to? The fuse in on that board is that correct?
    • CR Designs
      • Dec 2012
      • 430
      Originally posted by kevinm34232
      It looks like it's integrated into the main board, there's a ribbon cable coming off of the top left. I just got a 47" Vizio E471VLE today, same thing..
      That's right it is the same setup
        The board will be long skinny board, may have two linking together. They are making sure you cannot fix the TV since you cannot change the T-CON board by itself.
        • CR Designs
          • Dec 2012
          • 430
          Budm ,So is it possible to change and is that where you think the problem is? What should I do?
            That boards had flexible board that is bonded to the board on one end, another is bonded to the LCD panel, basically not replaceable. At this point you can try disassemble the panel to see if you can locate the surface mounted fuse.
            • CR Designs
              • Dec 2012
              • 430
              Budm, I will take it apart . I read that this could be a cap problem to. should I recap the power supply board even thou they look good. what do you think?
                Right now you have flickering backlights but at least you still have the backlight source for lighting up the screen, so you need to fix or find out why you are not getting the pictures on the screen first. The flickering may be due to bad caps but it does not make sense to fix the lights first. Once we verify that the fuse is good or bad and if it does have voltage on it or not, and able to get the pictures back, then you can work on the other section of the TV. The main board may not be sending out the voltage to the T-CON. So if you cad take good close up picture of the LVDS connector on the main board, then i may be able to tell you which pin is the B+ output pin for feeding the T-CON board, so lets do that first.
                • CR Designs
                  • Dec 2012
                  • 430
                  Thanks Budm Iwill do that tomorrow.
                  • CR Designs
                    • Dec 2012
                    • 430
                    Budm, Here's some pictures you wanted of LVD also picture of tear down. any ideas on how to remove the board I circled it in the picture,Thanks
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      #30
                      Bud wants a picture of the area of the board (Top left Corner in the out of focus picture) where the Flat LVDS plugs into the main board.
                      • CR Designs
                        • Dec 2012
                        • 430
                        Selldoor thanks for the help ,is this the picture budm wants?
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          #32
                          I think so and perhaps the part number on that Q6 8 legged component.
                          • CR Designs
                            • Dec 2012
                            • 430
                            Selldoor Here's the number 4405 BA8Y24
                              That is the one, Q6 is the MOSFET for supplying the swithced B+ to the T-CON. Check the DC voltage on pin27, or 28, or 29 of the connector (chassis as ref ground).
                              When TV is off, you will have 0V, when TV is on you should have either 5V or 12V (depends on the LCD panel design).
                              • CR Designs
                                • Dec 2012
                                • 430
                                Budm checked pins 27,28 and 29 power off ov on all 3 pins. Power on all 3 pins had 11.39v
                                  That means the main board is sending out the voltage OK, now hook the LVDS cable back up and see if you still get the voltage. If you do, then you will have to take apart the LCD panel next.
                                  • CR Designs
                                    • Dec 2012
                                    • 430
                                    Yes still get voltage
                                    • CR Designs
                                      • Dec 2012
                                      • 430
                                      Budm, I took another close look at the tcon board and I could see the fuse you were talking about checking I didn't take out the lcd. I tested the fuse(white) it is good. See picture I have the fuse circled.
                                        Well that means there are more circuits on the board have failed, there are voltage regulators and switching power supplies on the T-CON that will need to be checked out next.
                                        • CR Designs
                                          • Dec 2012
                                          • 430
                                          O.k will finish tearing in down, Thanks
                                          • harp
                                            White screen repairs
                                            by harp
                                            To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                            Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                            On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                            05-13-2024, 03:43 AM
                                          • domu
                                            Viewsonic VS16217 strange problem - white flickering screen on power up
                                            by domu
                                            As per subject, on power up display shows no image, but white
                                            flickering screen. Strangely, it only happen after power was lost
                                            when it was on. After power returns - white screen only, but if
                                            disconnect power for 12-24 hrs, and connect then again monitor
                                            works normally.
                                            Any clues how to go about it would be greatly appreciated.
                                            07-18-2023, 04:57 AM
                                          • spice_disc
                                            Vizio TV M50-C1 reboot cycle and static on screen
                                            by spice_disc
                                            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                            09-08-2024, 02:37 PM
                                          • Ado02
                                            Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                                            by Ado02
                                            We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                                            The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                                            12-16-2024, 02:33 PM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
