Sony Bravia KLV-32-400A - negative picture with white haze
    Re: Sony Bravia KLV-32-400A - negative picture with white haze
    It has solarized picutres like this one:
    https://www.badcaps.net/forum/showth...ng+LN37A550P3F
    See of it uses AUOPTO LCD panel.
    Voltage checking will tell you as Tom has suggested.
      Hello budm!
      It really seems to be the same problem! I'm going to try to test the voltages.
      Thank you!
        Hello!
        I took some measurements of my T-CON board Voltages :
        VGMA1: 15.42
        VGMA2: 15.19
        VGMA3: 12.77
        VGMA4: 11.74
        VGMA5: 10.98
        VGMA6: 10.42
        VGMA7: 10.05
        VGMA8: 9.77
        VGMA9: 9.61
        VGMA10: 14.78
        VGMA11: 7.35
        VGMA12: 6.93
        VGMA13: 14.5
        VGMA14: 5.21
        VGMA15: 6.73
        VGMA16: 4.48
        VGMA17: 3.91
        VGMA18: 3.63
        VGMA19: 3.16
        VGMA20: 2.43
        VGMA21: 0.39
        VGMA22: 0.28
        VCOM2: 6.33
        CONF2: 6.28
        VGL: -6
        AVDD: 16.04
        VIN_12V: 12.05
        V3D3: 3.30
        V1D8: 1.79
        VGHC1: 25.8
        LVDS_OUT1: 3.29
        AVDD_F: 16.06
        With this information it is possible to see anything wrong ? I attached a picture of the board too.
        Thank you!
        Looks like LVDS/format fault, possibly main board. Maybe a little too sharp to be gamma. Hard to tell. Voltages will tell you where fault is.
          So yep, another gamma fault right there. You can see that spike in the middle causing a world of hurt. You should replace the t-con or the gamma chip, replacing the gamma chip will require good SMD soldering skills.
          So that's quite a few this week, amazing how many are failing.
            My Sony Bravia KDL-40Z4100 failed a few weeks ago with this same problem. I replaced the AS15G this past weekend and it solved the problem. My set was manufactured in July of 2008 and the failed AS15 had a 2008 date code, the same as the one in guilhermemt's TCON photo.
            It would be interesting to know how many of the AS15 chips that are failing now were manufactured in 2008.
              The chip that you replaced is the one on the top-right of the board ? (AS15-F)
              Thank you!
                Yes the AS15-F chip at the top-right of the board is the same one that failed on my board. The voltage readings on my TCON board were very similar to yours.
                My board had an AS15-G chip which is functionally equivalent to the AS15-F.
                Good luck with the repair. Let us know how it turns out.
                  Ok!
                  i will have to find someone to do it for me. After that I 'll tell you.
                  But, one more question: how do I know that the measurements/voltages that I took aren't fine ? Is there any place where I can find the correct patterns ?
                  Thank you all!
                    See attached spreadsheet. Input them in and try it out.
                      Cool!
                      With this spreadheet is easier to understand!
                      When I answer 22 on the 1st spreadsheet (How Many?) the cell I1 shows ####. If I consider only 18 as the model, it shows FAIL.
                      Anyway, in detailed results is possible to see that something is missing.
                      Thank you!
                        Yep, that's a bug; I just fixed it. See this version.
                          I should test it first. This one works now.
                            Good to see that you fix it.
                            I also noticed that in Detailed Results Spreadsheet, the cells B21 and B22 cotains the same value =$Input.B16 . Is it normal ?
                            At other cells the value is always the last cell.
                              That was the bug I just fixed right now, see above.
                              With an incremental decrease from 16V to 0.01V, it should show "PASS".
                                Good!
                                Unfortunately my T-CON continues failing even after yours fixes.
                                  Problem solved after replacement of AS15-G at Sony Bravia LCD KLV-37M400A !
                                  Thank you guys !
                                    Thanks for the repair feedback.
                                      Can u plz tell me where should i check for voltage and what is the voltage range should be thanks
                                      I have a same problem plz tell me
                                        mtechall: take good pictures of your T-CON so we can see the test points.
                                          I have a Sony KDL-40Z4100/S . It has the white screen that winwin92 posted.
                                          What do you all suggest? I really love this tv.
