Sony Bravia KLV-32-400A - negative picture with white haze
    Re: Sony Bravia KLV-32-400A - negative picture with white haze
    @bagel, welll winwin92 did not post the follow-up to tell us if he fixed his problem by changing the T-CON board or not. You should post the pictures of your T-CON board since your TV version may not be the same as winwin92. You need to take voltage readings on the T-CON board.
    • vikrammpatil
      • Jul 2014
      • India
      #62
      Hi All,
      First i wud like to thanks tom66, joerebello and Kevin. As by this forum by Sony Bravia negative picture solved. I replaced IC AS15-HG, my issue solved.I really BADCAPS Forum as well. Please put me if you have any queries i will try to help you guys.
      • Charudatta
        • May 2017
        • India
        #63
        Hi , I have same issue I replace if as15-hg but some resistors are by mistake removed by hotgun malfunction can any budy tell me value of each resistors , All are same or different different. Help me Please
        • Charudatta
          • May 2017
          • India
          #64
          Does any one have standby V315B01-C08 T-Con board . I need resistor values for 1-18 as in Picture. Some resistor are swiped by heatgun bi mistaken. IC chip is As15-HG NOT F. I have datasheet for As15 but is it worth. Not clear from application data. Any on could help me please
          • thstuff
            SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
            by thstuff
            This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
            Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
            1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
            2) Waited 30 seconds, then pressed remote Power button and "Select language"...
            01-30-2023, 05:01 PM
          • PopsCaps
            Sony Bravia KDL-40V2500 that will not power on
            by PopsCaps
            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
            I do not hear any sound and I cannot see any backlight.
            I have tried disconnecting every cable on each board one at a time to see if anything changes.
            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
            03-25-2025, 11:23 AM
          • stav242
            Sony KD-55X8509C white flashing/pulsing LED
            by stav242
            I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
            On inspection, there was no physical issues.
            I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
            - this seems to indicate repairing required, done by Firmware update.
            so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
            Inserted the drive and repowered the TV.
            LED changed to white flashing/pulsing ... and it sat there for over an hour.
            i was unsure what was happening so repowered the TV and now it just...
            01-08-2024, 07:39 AM
          • justin35
            Sony bravia kdl-43w755c - boot loop
            by justin35
            i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
            from what i read online it looks to be an emmc issue…
            i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
            i took out the board and say an samsung 16gb emmc
            i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
            i could try to put one instead of the 16gb one, but will it work?
            where do i get the software from?
            any help will be much appreciated!...
            03-06-2024, 12:26 PM
            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
            Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
            10-16-2024, 05:15 AM
