Hi everyone, my first post.
I have a broken Vizio VO42L television again.
I have searched through the topics of this model and I have successfully (well only for about 20 minutes
) repaired my television due to the main inverter board had a 2 blown out caps and 1 leg on the ic was burnt off (could have been 2, I can't remember now)
I don't have professional equipment to do proper testing but I do have a digital multimeter, soldering station, hot air welder (Aoyue 968) and reflow/reball station that I fix xbox's with (sorry getting off topic).
I had replaced the boards last night, (I plan to replace the defective regulators and ic on the first blown board soon).
I received the new/used boards from a supplier in China and it worked fine for the 20 or so minutes that it was on, I don't know how long because I just left the room with the tv on and went back later to find no display.
I'll try to explain what I have done.
With the new boards, there is no popped caps, no ic damage that I can visually see, nothing burnt that I can see, but there are a couple of smd's that have been soldered crooked. The MOSFET's read 9.01k ohms on the master board and 8.9 on the slave board so I believe the MOSFET's are ok.
The fuses (main one 10A) seem to be ok, tested ok for continuity, the caps look ok but I think they are of poor quality sam young 105 deg., 35v 380 uF.
Plug the ac cord in, the Vizio emits orange (stand by)
Push power, Vizio emits white, but no picture (black screen).
I have done the 24V light test to see if the power supply is failing, but it seems fine with little voltage loss. Lights come on when I push power, go off when I turn the tv off.
Ac plugged in stand by mode...
Pson 0.03v
12 0v
5vsb 5.17v
A 0v
B 0.02v
AC plugged in and on (white Vizio icon)
Pson 3.27v
12 0v
5vsb 5.15v
A 2.91v
B 4.71v
I just don't want to replace (well it will be a repair this time, my wife can watch tv in the other room) the cards, but I don't see any physical damage this time, not like the last time when I smelt smoke and I knew exactly where to go (fix the problem).
Any other trouble shooting that I have missed would be greatly appreciated if there is something that I have missed working with the tools that I have.
The last picture is probably the worst for lighting. Go figure.
) repaired my television due to the main inverter board had a 2 blown out caps and 1 leg on the ic was burnt off (could have been 2, I can't remember now)I don't have professional equipment to do proper testing but I do have a digital multimeter, soldering station, hot air welder (Aoyue 968) and reflow/reball station that I fix xbox's with (sorry getting off topic).
Pson 0.03v
12 0v
5vsb 5.17v
A 0v
B 0.02v
Pson 3.27v
12 0v
5vsb 5.15v
A 2.91v
B 4.71v
