Sharp LC32D44E-BK Stuck in standby mode
    Re: Sharp LC32D44E-BK Stuck in standby mode
    i know they are black & gold but it dont say panasonic on the side?
      OK, well Panasonic are fine then... had me worried there... [M] is usually printed on them for Matsushita Electric Industrial (Panasonic's parent company.)
        yea i order that remote, and take it from there, so will i have to leave it bridged for now, until i can reset the lamp error?
          You will need to replace the bulb, unless you can live with the dim bar in the screen.
            you think get geniune remote or, those cheaper types.
            i will need to see the tv working, from whot ive seen so far playing around with the menu, and the other stuff it looks ok?
              I think you can use a non original remote but I'm not 100% sure.
                Whot i do is get the remote first then look up replacement bulb, thank you very much TOM66, you been very helpful, cheers.
                  Hope you can get it working.
                    ordered that remote for 11 quid, then you know when you buy something at the bottom it stays people have brought simular, yep you guess it, original new for £5 + 2.50 pp
                      You can cancel the order.
                        Tom66 you are a genius , remote came today did the reset like you did in the video, the rest is history.
                        Had too work out how to do a dtv scan, but i sorted it working perfect so far.
                        Dont believe this Backlight Acutime is only 4361H 10M
                        Do i got remove the bridge C7558?
                        I give it a proper good test from tommorows but im well happy.
                          Not going say fix too soon, i give it a week first
                            Remove bridge C7558, but test thoroughly. If it starts throwing LAMP ERROR then you need to fix the fault with the bulb unless you can live with dim patch.
                              I cant see no problem, no dark patch while watching.
                              I give it a proper test, if needed then i order that bulb.
                              I remove the bridge tomorrow, just to happy to go playing with it.
                              Only thing i dont like is the freeview channels aint in the same order that im used to, think its scrambled.
                              Got channel never had before.
                                Just had customer of this TV I fixed complain about mixed order. Same fault on an older Sharp LC-32SD1E...
                                  yea i will search online to find the correct order, ive just sorted the one's i know and lock them.
                                    never had moviemix before?
                                      Remove bridge from C7558 tv is back to the state i recieved it in.
                                      So i do believe i may have a bulb problem.
                                      How do i goto about getting the correct bulb for this tv.
                                        I think these are them.
                                        http://www.donberg.co.uk/descript/r/rlmpla029wjn.htm
                                          is it a clip in clip out job?
                                          23% vat?
