Sharp LC32D44E-BK Stuck in standby mode
  • Jahson
    • May 2012
    • 245
    Re: Sharp LC32D44E-BK Stuck in standby mode
    i know they are black & gold but it dont say panasonic on the side?
      OK, well Panasonic are fine then... had me worried there... [M] is usually printed on them for Matsushita Electric Industrial (Panasonic's parent company.)
      • Jahson
        • May 2012
        • 245
        yea i order that remote, and take it from there, so will i have to leave it bridged for now, until i can reset the lamp error?
          You will need to replace the bulb, unless you can live with the dim bar in the screen.
          • Jahson
            • May 2012
            • 245
            you think get geniune remote or, those cheaper types.
            i will need to see the tv working, from whot ive seen so far playing around with the menu, and the other stuff it looks ok?
              I think you can use a non original remote but I'm not 100% sure.
              • Jahson
                • May 2012
                • 245
                Whot i do is get the remote first then look up replacement bulb, thank you very much TOM66, you been very helpful, cheers.
                  Hope you can get it working.
                  • Jahson
                    • May 2012
                    • 245
                    ordered that remote for 11 quid, then you know when you buy something at the bottom it stays people have brought simular, yep you guess it, original new for £5 + 2.50 pp
                      You can cancel the order.
                      • Jahson
                        • May 2012
                        • 245
                        Tom66 you are a genius , remote came today did the reset like you did in the video, the rest is history.
                        Had too work out how to do a dtv scan, but i sorted it working perfect so far.
                        Dont believe this Backlight Acutime is only 4361H 10M
                        Do i got remove the bridge C7558?
                        I give it a proper good test from tommorows but im well happy.
                        • Jahson
                          • May 2012
                          • 245
                          Not going say fix too soon, i give it a week first
                            Remove bridge C7558, but test thoroughly. If it starts throwing LAMP ERROR then you need to fix the fault with the bulb unless you can live with dim patch.
                            • Jahson
                              • May 2012
                              • 245
                              I cant see no problem, no dark patch while watching.
                              I give it a proper test, if needed then i order that bulb.
                              I remove the bridge tomorrow, just to happy to go playing with it.
                              Only thing i dont like is the freeview channels aint in the same order that im used to, think its scrambled.
                              Got channel never had before.
                                Just had customer of this TV I fixed complain about mixed order. Same fault on an older Sharp LC-32SD1E...
                                • Jahson
                                  • May 2012
                                  • 245
                                  yea i will search online to find the correct order, ive just sorted the one's i know and lock them.
                                  • Jahson
                                    • May 2012
                                    • 245
                                    never had moviemix before?
                                    • Jahson
                                      • May 2012
                                      • 245
                                      Remove bridge from C7558 tv is back to the state i recieved it in.
                                      So i do believe i may have a bulb problem.
                                      How do i goto about getting the correct bulb for this tv.
                                        I think these are them.
                                        http://www.donberg.co.uk/descript/r/rlmpla029wjn.htm
                                        • Jahson
                                          • May 2012
                                          • 245
                                          is it a clip in clip out job?
                                          23% vat?
                                          • Dvsr
                                            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                            by Dvsr
                                            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                            After replacing the caps I started testing out the speaker. It seemed...
                                            09-10-2025, 10:20 AM
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • toty79
                                            Hisense LTDN50K220WSEU stuck in standby
                                            by toty79
                                            Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                            As per Hisense tv title LTDN50K220WSEU stuck in standby
                                            PSU rsag.820.5687 HLL 4855WF
                                            Main rsag 7.820.5842
                                            I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                            05-01-2022, 04:39 PM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
