DIGITREX CTF3271 PSU bsfp3220004ad
    Re: DIGITREX CTF3271 PSU bsfp3220004ad
    Lots of voltage regulators to test?
    Here is the data sheet for the IC1 - Dont know how to test other than for voltage in.
    Can find anything on an EZ949 - can you check the number E2949 BZ949 B2949 ?
      Ok thanks, those diodes all seem to check out ok on the reverse
      I am getting 14v on vcc of ic1 but nothing from anywhere else, shouldnt I be getting something from pin GD, gate driver, or will that be just a start up voltage to wake up the fets
        Have you considered changing the caps? Those look like crapXcon...
          Grrrr IPOS150's come back all is forgiven,
          Spoke to a friend earlier who checked a database with a different model with the same board and it recommended replacing the 5 caps mentioned in an earlier post, did this along with all the other secondary caps and there is no change still exactly the same
            ah my apologies, I missed that post I guess
              Anyone give me anymore pointers on this as I have been sat here for another 2hours and still cant get the 12 or 24v to kick in
              Could I also ask why am I getting 4.5v on the 5v rails but the 5vsb is sat at 5.03 volts and is 4.5 little low?
              Really want to get this one sorted as I always seem to see this board with the same fault and no cure on the tinternet for it.
              Thanks again in advance
                Did you test the voltage regulators on the main board?
                Did you try pulling the ps pin to ground to see if its a pin low switch
                there have been a few posts recently with that oddity. I will try and look for one later. Having a disaster with my cookies here - cant get into ebay on
                my laptop and I use it all the time.
                  VR-EH16A or equivalant sot23-1117-33 which states a 1.2 v drop and that is exactly what they are all doing
                  Can you just expand on this a little, do I just put ps to ground...sorry for sounding stupid
                    Can anyone give me pointers on how to boot the PS as a stand alone to see if the 12 & 24v kick in or the main is at fault.
                      Managed to sort a supply by putting a 2.2k resistor between ps and 5v, still nothing, not a dicky bird
                      Where do I need to start looking now????
