DIGITREX CTF3271 PSU bsfp3220004ad
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: DIGITREX CTF3271 PSU bsfp3220004ad
    Lots of voltage regulators to test?
    Here is the data sheet for the IC1 - Dont know how to test other than for voltage in.
    Can find anything on an EZ949 - can you check the number E2949 BZ949 B2949 ?
    • is_it_a_bird
      • Feb 2013
      • 59
      Ok thanks, those diodes all seem to check out ok on the reverse
      I am getting 14v on vcc of ic1 but nothing from anywhere else, shouldnt I be getting something from pin GD, gate driver, or will that be just a start up voltage to wake up the fets
      • martyparish
        • Dec 2012
        • 313
        Have you considered changing the caps? Those look like crapXcon...
        • is_it_a_bird
          • Feb 2013
          • 59
          Grrrr IPOS150's come back all is forgiven,
          Spoke to a friend earlier who checked a database with a different model with the same board and it recommended replacing the 5 caps mentioned in an earlier post, did this along with all the other secondary caps and there is no change still exactly the same
          • martyparish
            • Dec 2012
            • 313
            ah my apologies, I missed that post I guess
            • is_it_a_bird
              • Feb 2013
              • 59
              #26
              Anyone give me anymore pointers on this as I have been sat here for another 2hours and still cant get the 12 or 24v to kick in
              Could I also ask why am I getting 4.5v on the 5v rails but the 5vsb is sat at 5.03 volts and is 4.5 little low?
              Really want to get this one sorted as I always seem to see this board with the same fault and no cure on the tinternet for it.
              Thanks again in advance
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #27
                Did you test the voltage regulators on the main board?
                Did you try pulling the ps pin to ground to see if its a pin low switch
                there have been a few posts recently with that oddity. I will try and look for one later. Having a disaster with my cookies here - cant get into ebay on
                my laptop and I use it all the time.
                • is_it_a_bird
                  • Feb 2013
                  • 59
                  #28
                  VR-EH16A or equivalant sot23-1117-33 which states a 1.2 v drop and that is exactly what they are all doing
                  Can you just expand on this a little, do I just put ps to ground...sorry for sounding stupid
                  • is_it_a_bird
                    • Feb 2013
                    • 59
                    #29
                    Can anyone give me pointers on how to boot the PS as a stand alone to see if the 12 & 24v kick in or the main is at fault.
                    • is_it_a_bird
                      • Feb 2013
                      • 59
                      #30
                      Managed to sort a supply by putting a 2.2k resistor between ps and 5v, still nothing, not a dicky bird
                      Where do I need to start looking now????
