Wondering if anyone knows what could be causing this Rca L32hd32d to have a washed out appearance and inverted colors? All functions work and the unit stays powered on with full backlight. A reset just seems to dull things down a bit but color inversion and lack of sharpness persist.
Rca L32hd32d washed out, inverted colors
Re: Rca L32hd32d washed out, inverted colors
Does it look like this?
https://www.badcaps.net/forum/showth...mma#post304275Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
It may just need the new T-CON board.Never stop learning
Reviewing your helpful guides and forum links I wonder if my issue might be the AS19-HG which is on this T-Con board. For 3 bucks I might give it a try using "ChipQuik" to remove it and drag soldering to replace it.Comment
by dbuergiHi all,
i got a A1990 which shows strange colors. Sometimes looking faded or like a water mark and only visible when the cursor moves over the spot. With an external display everything looks fine.
So is there anything i can do on my own to fix this issue?
It doesn't look like the flexgate macs i have seen....2 Photos -
by ojmcBackground:
- Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
- I replaced all 6 of the backlight LED strips with these replacements: amazon
- The TV worked again perfectly for ~2 weeks.
- After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
by x_orange90_xSo I've got this 55UP7000PUA that has a very washed out and dim image. I've played with all of the settings, turned brightness to 100 as well as panel backlight, made sure no eco settings are on, etc. It looks like the backlight is at 50% or even less. I've been reading online that this is a pretty bad model with poor contrast and image retention issues, but I haven't seen anyone say it's dim like this. I've seen quite a few LGs with bad backlights before and they are usually blue. This doesn't appear blue, just washed out and dim. I've likewise never seen ANY backlights simply dim as a failure....
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by silikon77Hi!
Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
Found some advices watching youtube nad came up with this:
It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
See attached picture.
I tried a few combinations to block individual clock...1 Photo01-02-2025, 02:26 PM - Loading...
