MacBook Pro A1990 820-01041A strange / inverted colors and faded look on display
  • dbuergi
    • Jul 2024
    • 139
    • Deutschland
    i got a A1990 which shows strange colors. Sometimes looking faded or like a water mark and only visible when the cursor moves over the spot. With an external display everything looks fine.
    So is there anything i can do on my own to fix this issue?
    It doesn't look like the flexgate macs i have seen.
  • ACS-Repair
    • Feb 2021
    • 204
    It looks to me that the screen is damaged. I had a screen like this that would have a shimmering effect on some colours and brightness levels. Do you have another screen to try?
    • dbuergi
      • Jul 2024
      • 139
      • Deutschland
      i was able to fix the issue. The board was covered with some very fine dust and i gave it a good vacuum cleaning and finished with isopropanol. This dust was also inside most of the connectors.
      After putting everything back together the macbook started normal and all colors look like they should. :-)
      • ACS-Repair
        • Feb 2021
        • 204
        Wow! Good work resolving the issue.
        • silver60618
          Macbook Pro A1990 - Battery not detected after connector torn off
          by silver60618
          Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
          Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
          11-12-2025, 06:36 PM
        • alfredodinolfo
          MacBook Pro 2019 (A1990)
          by alfredodinolfo
          mb code:820-01827-A;
          sn:C02Z349ALVDR;
          i9 32GB Ram 1TB
          Hi, I found short on one of 6 black nand (total 1TB).
          i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
          I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
          macbook with A2141 configuration run on recovery but don't complete it.​
          anyone can help me?
          05-26-2025, 09:27 AM
        • master_haze86
          A1990 820-01814-A dead not charging - need help with diagnostics.
          by master_haze86
          Good day everyone,
          Let me preface this with letting you know that I have a smalltime computer repair shop but do not have a lot of experience when it comes to board diagnostics. I am good at soldering etc but finding the issue if there isn't an obvious burnt component is not my strong suit.
          The other day I got a customer come in with a macbook A1990 (motherboard 820-01814-A) that would not turn on and had previously been getting the warning message that the battery needed servicing. (Most folks seem to ignore that message, just like the check engine light in vehicles.)...
          09-13-2025, 06:01 PM
        • Strolch
          MacBook A1990 26 Pin Connector
          by Strolch
          Hello, can anyone tell me where I can get this 26-pin FPC connector? What is the connector for?So that one's also for the Touch Bar. I thought only the FPC at the top was for the Touch Bar. But where can I get it? I can't find the connector online. I only found the 22nd pin. Thank you....
          09-03-2025, 01:11 AM
        • silikon77
          Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
          by silikon77
          Hi!
          Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
          Found some advices watching youtube nad came up with this:
          It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
          I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
          See attached picture.
          I tried a few combinations to block individual clock...
          01-02-2025, 02:26 PM
