Rca L32hd32d washed out, inverted colors
  • dbuergi
    MacBook Pro A1990 820-01041A strange / inverted colors and faded look on display
    by dbuergi
    i got a A1990 which shows strange colors. Sometimes looking faded or like a water mark and only visible when the cursor moves over the spot. With an external display everything looks fine.
    So is there anything i can do on my own to fix this issue?
    It doesn't look like the flexgate macs i have seen....
    09-03-2024, 06:39 AM
  • ojmc
    Hisense 65H6570G - Color inverted after replacing LED backlight
    by ojmc
    Background:
    • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
    • I replaced all 6 of the backlight LED strips with these replacements: amazon
    • The TV worked again perfectly for ~2 weeks.
    • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
    10-17-2024, 02:29 PM
  • silikon77
    Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
    by silikon77
    Hi!
    Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
    Found some advices watching youtube nad came up with this:
    It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
    I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
    See attached picture.
    I tried a few combinations to block individual clock...
    01-02-2025, 02:26 PM
  • mecha1166
    Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
    by mecha1166
    I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
    07-03-2024, 05:03 PM
  • captainKKK
    Samsung LN37A550P3FXZA - washed out colors
    by captainKKK
    I have referenced https://www.badcaps.net/forum/showthread.php?t=35193.
    I seem to have the washed out pictures on my Samsung LN37A550P3FXZA. And have tested my T-con board voltages. My problem is that the board does not give the numbered sequence so I can easily tell if they are increasing/decreasing in order. So I number them myself as in my attached pictures and the voltages are:
    Samsung LN37A550P3FXZA T-con voltages:
    (text formatting this forum not good for tables - see attached picture)
    |Test | no antenna | with antenna
    |point...
    05-24-2019, 10:01 AM
