Goodmans LD266HD backlight issue
  • netdent
    • May 2011
    • 208
    Need some help with this, fault is tv powers on then 2 seconds to standby image is displayed for 2 seconds then led goes to red.
    good 24v to inverter, if I unplug supply to inverter set stays on, also tried plugging each of the tubes in one at a time each one flashes up ok for the 2 seconds but with only one tube connected it does not put the set into standby!
    The psu is vestel 17PW15-9 I know there are many kits for these boards but I'm not sure if the fault lies with the psu or inverter
    thanks Ronnie
    sigpic
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Goodmans LD266HD backlight issue
    you need to plug in a separate ccfl tube one at a time to rule out the back lights,the psu will go into protection otherwise and shut down the 24v supply to the inverter,in other words,pull one out replace with test ccfl then replace original ,and so on.
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • netdent
      • May 2011
      • 208
      Thanks for your advice, in my experience any problems from the inverter or ccfl's it shuts off and the tv will still run, in this case the whole tv goes to standby?
      sigpic
        The two 15n/630V caps at top of PSU are bad.
        • netdent
          • May 2011
          • 208
          Hi Tom, that's what I was thinking but not sure the symptoms fitted, in the past with these psu's and those caps the sets were stuck in standby?
          cheers Ronnie
          sigpic
            If rails collapse they are usually the issue. Check the main board STBY signal for activity as well though.
            • netdent
              • May 2011
              • 208
              It will always come out of standy everytime and will stay on if no load on the 24v?
              sigpic
                That sounds a lot like bad 15n's to me.
                • netdent
                  • May 2011
                  • 208
                  cheers Tom will go for that, kit on ebay for a fiver will save ordering caps for now but probably need to think about having a supply to hand
                  Ronnnie
                  sigpic
                  • ron77
                    • Dec 2012
                    • 63
                    • united kingdom
                    Had same problem as you have on your tv. Must have been over two years ago. It did turn out to be those 15n caps. Had replaced many 15n caps on that psu,but didn't suspect them at all in this case. Wasted a lot of time, I remember that all right.I think it was from previous experience, that I thought 24v rail was ok.However when I finally checked those 15n caps, one was ok, the other slightly low. Much better condition than other caps I had replaced. I do know that the inverter shut down, but can't remember if power on voltage changed from .6v to 1.7v to put the set into standby.Have feeling 24v remained, why I thought psu was ok.
                    If your set same fault as mine, Tom has got it right again. Don't know how he does it. Had this set in front of me and took quite a while to find the problem.
                    I think my set was 32 inch. Ron.
                    • netdent
                      • May 2011
                      • 208
                      Thanks Ron, that's good to know
                      sigpic
                      • Cornito
                        Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                        by Cornito
                        Hello Team,
                        I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                        Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                        Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                        08-08-2024, 08:09 AM
                      • cheebster
                        iPad Pro 12.9 5th Gen Backlight Issue
                        by cheebster
                        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                        Anyone...
                        05-20-2025, 09:17 AM
                      • Cornito
                        TCL 65C715 backlight issue
                        by Cornito
                        Hello team,
                        I'm back with another topic.
                        It's a 65C715 TCL tv with backlight issue.
                        But the problem is a bit strange.
                        When I took this tv from the marketplace backlight didn't work but picture was ok.
                        Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                        Putting all back together the tv worked fine for weeks. => Contact issue??
                        Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                        06-09-2024, 02:24 AM
                      • Riananyaina
                        MacBook A1708 820-00840-A backlight issue
                        by Riananyaina
                        Hello Everyone ,
                        today I'm coming to you regarding my issue which is no Backlight .
                        I have image on my screen but no light .
                        The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                        First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                        Please find below few informations which can help for the analysis...
                        04-24-2023, 05:03 AM
                      • Dreadnought
                        L40DIGB20 Logik 40" inverter/backlight issue.
                        by Dreadnought
                        Hi. Firstly I apologise if I break any forum unwritten rules, as I'm new here. I've used badcaps for advice in the past, but I've only just joined. I'm self taught, so I don't have anywhere near the knowledge that some of you guys have, but I can only hope to keep learning and get there one day.
                        Anyway, I've been working on a TV recently. It's the one listed in the title. Logik L40DIGB20. It powers on fine, with the standby light turning blue as it should. The backlight turns on for a second, then goes off. Using a flashlight, I can see an image on the screen. The power supply is fine,...
                        02-08-2021, 12:28 PM
