Toshiba 40XV640u strange screen issue; need help diagnosing...
  • vagabondjjm
    • Feb 2013
    • 8
    As the pictures show, I'm getting vertical and horizontal lines. The lines fade if nothing is being displayed on the screen and also show over the on screen menu.
    When I have a source on, such as my 360, the lines show over everything, but strangely enough, it almost looks like the color of thing "underneath" the lines is still right.
    I've changed the t-con out and I'm getting the exact same results.
    I've also checked the tabs on the lcd itself and they seem to be fine. They are unaffected by any slight pressure anywhere (I used a dense foam, not my hand).
    I'm mystified on this one. Could the main/video board cause something like this to occur? I don't see any obvious indicators like bulged caps or blown fuses anywhere, but going from the tcon backwards, this is the next thing in line.
    Also, same thing happen on any input, even if there isn't a source on.
    Thanks all for any insight you may have!
  • selldoor
    Slow Learner
    • 7870
    Re: Toshiba 40XV640u strange screen issue; need help diagnosing...
    May well be a bad panel
    Did you clean the lvds cables when you had them off?
    Was the TCON an EXACT replacement, if used, off the same size panel.
    If you can get into the service menu try a factory reset.
    • MisterD
      • Oct 2012
      • 668
      I had a Similar situation vertical lines like what you have, where pressing on the tab bonds did not do anything, I then used a hair dryer to heat up the tab bonds and then things started changing the lines went away and I had a normal picture, then after that I was able to get a response when pressing on the bad tab bonds.
      • cashkennedy
        • Aug 2011
        • 668
        I had a 40" sony that had a tab issue, that did not respond to pressure on the tabs, and would blur / some items on the screen kinda like it was stretching them out up and down. Like when the sony logo shows on the screen it would read sony fine in the middle, but the sony had a streak / shadow going up and down in bright pink...
        I finally was able to fix that set using the resistor trick / which is documented on this forum. If you completly disasemble the set you can fairly easily try the resistor trick, but the hard part is permanently soldering the resistor to a plastic tab...
        https://www.badcaps.net/forum/showth...40s5100&page=2 I linked videos in this topic about the resistor tab fix.
        https://www.badcaps.net/forum/showth...ht=kdl-40s5100 shows pictures of the symptoms it had.
        Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
        • vagabondjjm
          • Feb 2013
          • 8
          Thanks all for your replies! I am trying each in order this evening, starting with a factory reset if I can do it. Interested to see what heat does to the tabs. Any advice on heat settings and time for each tab?
          • vagabondjjm
            • Feb 2013
            • 8
            Okay well I tried about everything to no avail. Took a look at the back of the video board and it looks pretty bad on one part of the underside, but you wouldn't know from looking at the top.
            Considering the variables at this point I think I'm just going to sell the boards I know are good and move on. Time is money too . Thanks everyone for taking the time to try and help!
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • Ancient1
              Strange LG TV issue : Image vertical lines in black screen
              by Ancient1
              Hi
              Asking for a friend.
              I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
              but here its the opposite !
              TV has new T-con = same issue
              A missing panel voltage would have global effect
              So , what should one do ? how can I find where the fault is ?
              Thanks !...
              02-05-2025, 03:37 PM
            • wizard13
              Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
              by wizard13
              I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
              I have checked the forum and the available documentation but could not find a solution specific to my issue.
              • Brand & Model: Dynabook Satellite Pro C50D-B-100
              • Part Number (P/N): PYU13E-00C00PFR
              • Serial Number (S/N): 22028896H
              • System Configuration (SC): A1PYU13E1127
              • Motherboard Model: IP3_ACN16_MB_V21_20211222A
              • Power Input: DC 19V –
              02-28-2025, 02:43 AM
            • Russ17
              Toshiba 43L3753DB Screen Issue
              by Russ17
              Hi
              I have a Toshiba 43L3753DB.
              When turned on, the Toshiba Logo is distorted and unreadable, but once the TV is booted, pressing the "Menu" button gives a visible menu, but if you try to select any menu, the screen becomes unreadable. The No signal message is readable and so is the info bar at the bottom of the screen, it just seems that as soon as there is a requirement to provide an image across the entire screen, it becomes unusable.
              When the screen is unreadable, the PSU noise increases.
              The 12V is good (12.14V) and is present...
              11-19-2020, 04:36 PM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
