Vizio VW42L-HDTV10A Flashing
    Re: Vizio VW42L-HDTV10A Flashing
    If you have a computer with a LINE IN jack, or a set of computer speakers, you can use an RCA to 3.5mm cable to do the test. It helps break the problem down to the amplifier or something else.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      speakers off in menu?
      • follenj
        • Jul 2014
        • 3
        • united States
        Speakers are on in menu. I'll have to try the line in trick now.
        • maricm
          Vizio m65-c1 picture flashing on and off on the screen
          by maricm
          HI all,
          hope someone point to the possible issue before I start buying replacement parts.
          Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
          Backlight stays on all the time,
          Sound works fine.
          screen keeps changing form black to full picture in about 1sec intervals.
          Picture looks fine with no visible artifacts.
          I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
          Disconnecting left and right ribbons on...
          11-25-2023, 06:32 PM
        • x_orange90_x
          by x_orange90_x
          01-29-2025, 09:24 PM
        • DXseekerMO
          Vizio P502ui-B1E, delayed video, white flash, flashing picture UGH!!!
          by DXseekerMO
          About a week and a half ago this TV was traded in to me with the complaint: upon turning it on one morning a white blob slowly spread across the screen. Before I got it the TV had been sitting about 3 weeks. I also found the RF IN connector was missing. I turned it on for evaluation and got the splash screen/menus.
          I installed a 75ohm RF connector, repaired several bad grounds on the power board and chassis, checked all boards for loose screws and cleaned the entire inside of the TV. After all appeared well, the TV was tested for 40 hours and was subsequently put up for sale. ...
          05-07-2019, 07:20 PM
        • gavric
          Vizio M70-C3 Half picture is bad, main board on its last leg?
          by gavric
          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
          When tv powers on vizio V logo shows nice on whole screen. picture 1
          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
          When i click video to start playing picture goes black(like when you change...
          09-02-2021, 08:55 PM
        • Super360
          Vizio E701i-A3 Vizio logo flashing then turns off
          by Super360
          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
          07-25-2024, 07:06 PM
