Vizio VW42L-HDTV10A Flashing
  • terminator012
    • Feb 2013
    • 6
    I did a search and could not find my exact problem. My tv will come on and I can see a picture. The screen is flashing rapidly and there is popping coming from it. I have removed the back to look at the mother board and inverters. I see no signs of a burnt spot. I am an HVAC repair man and looking at the capacitors, they do not appear to be swollen or busted. I can find many threads with the screen flashing or blinking but they have a black screen. Mine has the picture in the background and the picture appears normal. I do not know what parts to fix or replace because of this problem. If it is the backlight it may not be worth fixing.
    Board- CSD-3642-0132-0395
    Inverter- 6632L-044BA pnel-T702A
    Any advice would be much appreciated.
  • awyatt2
    • Feb 2012
    • 407
    • america
    Re: Vizio VW42L-HDTV10A Flashing
    look on the inverter boards they are i think covered by a metal shield you should find 4 bloated caps two on each inverter.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Yes - here is the thread
      https://www.badcaps.net/forum/showth...ighlight=VW42l
      • terminator012
        • Feb 2013
        • 6
        Do these look blown to you??
          Very.
          • awyatt2
            • Feb 2012
            • 407
            • america
            look at the end of the caps they are bulged.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              And slightly leaky - even on those out of focus pictures
              • terminator012
                • Feb 2013
                • 6
                Thanks everyone. That link was very helpful. Do you have a link on the best place to order the correct capacitors for these inverters. I want to be sure I get the right ones. I have never done this before but I have a friend that has worked on some circuit boards before.
                Is there a place where I could just order the inverters and replace the whole thing.
                  Digikey sells caps -- we would need the uF and V rating.
                  The inverters are available but likely very expensive -- more than $100 for both I'd say -- when caps would be under $10 shipped.
                  • terminator012
                    • Feb 2013
                    • 6
                    v 35 uf470
                      These should be fine.
                      http://www.digikey.com/product-detai...1CT-ND/3072271
                      • awyatt2
                        • Feb 2012
                        • 407
                        • america
                        i have repaired three of these and the one that didnt repeat after 6 to 9 months, i used 50v caps because that was what i had on hand at the time. when the other two came in i replaced them with 50v caps and havent seen them back for repair. i know two of them are in service because i see them regularly. son has one daughter has the other.the one my daughter has i dont think is ever off until they go to bed.
                        • terminator012
                          • Feb 2013
                          • 6
                          So would I be better off getting the same thing in a 50v??
                          • awyatt2
                            • Feb 2012
                            • 407
                            • america
                            just letting you know what i did. i didnt do it for any other reason than i had a few 470uf @50v that i bought for another tv which i hadnt used. tv failed and i needed to get i fixed and no other source than to order them i used what i had. it worked for me and everytime i have one of these sets to come in i plan on using 50v caps on it. i also did the inverter mods on the boards as well. on all three the only difference was the caps. the two that came back had the 35v caps and the brand was the same. where i buy my caps i usually buy all from one brand i have had luck with rubyicon and use them. and always use the lower esr caps. i also have the mod for the inverter boards in pdf if you want it.
                              35V is fine on the inverter; it uses 24V DC. No need to increase the voltage rating.
                              • terminator012
                                • Feb 2013
                                • 6
                                I just wanted to thank everyone for the advice. The capacitors came in yesterday and I got them soldered in this afternoon. The tv seems to be doing fine. The flashing is gone and the picture is good. Once again many thanks.
                                • Super88
                                  • Mar 2013
                                  tom66 and terminator012 and every one thanks. did every thing you guys said to do and tv is working just as good as the day i bought it THANKS! for all the info and wanted to thank everyone for the advice in here ....
                                  • follenj
                                    • Jul 2014
                                    • united States
                                    Had the same issue replaced 4 caps on inverter boards and now picture is great but there is no sound. Any suggestions? Already checked all settings.
                                      If the TV has a headphone port, does that work? If not, it probably has a standard audio output (digital or analog) -- try checking those.
                                      • follenj
                                        • Jul 2014
                                        • united States
                                        Nope can't find a headphone jack. It does have the audio output, but I don't have a receiver or surround sound system.
                                        • maricm
                                          Vizio m65-c1 picture flashing on and off on the screen
                                          by maricm
                                          HI all,
                                          hope someone point to the possible issue before I start buying replacement parts.
                                          Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                          Backlight stays on all the time,
                                          Sound works fine.
                                          screen keeps changing form black to full picture in about 1sec intervals.
                                          Picture looks fine with no visible artifacts.
                                          I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                          Disconnecting left and right ribbons on...
                                          11-25-2023, 06:32 PM
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                        • DXseekerMO
                                          Vizio P502ui-B1E, delayed video, white flash, flashing picture UGH!!!
                                          by DXseekerMO
                                          About a week and a half ago this TV was traded in to me with the complaint: upon turning it on one morning a white blob slowly spread across the screen. Before I got it the TV had been sitting about 3 weeks. I also found the RF IN connector was missing. I turned it on for evaluation and got the splash screen/menus.
                                          I installed a 75ohm RF connector, repaired several bad grounds on the power board and chassis, checked all boards for loose screws and cleaned the entire inside of the TV. After all appeared well, the TV was tested for 40 hours and was subsequently put up for sale. ...
                                          05-07-2019, 07:20 PM
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
