Sorry that was need sevice manual e420vt burnt parts see pics
  • davewilson61
    • 110
    • usa
    Need service manual thanks dave
  • tw2005
    • Oct 2011
    • 6458
    Re: Sorry that was need sevice manual e420vt burnt parts see pics
    I was just about to mention that PSU was coming up VIZIO. 102K, 1Kv are the markings on that cap C504A or C604A?
    Have a look at this photo, pretty clear.http://www.shopjimmy.com/vizio-080gl...-led-board.htm
    • davewilson61
      • 110
      • usa
      Got it up running.. Changed 102k thanks tw2005.. But why did it burn the cap and blow the fuse? .. Running about an hour now
      • kev1n69
        et1984
        • Jul 2012
        • 13
        • usa
        Thanks tw2005 good fix
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          The resistor probably went short and gave too much voltage to the cap, causing it to pop, and then short, and when it went short, it blew the fuse.
          Permanently Retired Systems:
          Kooky and Kool Systems
          sigpic
            It is the high Voltage snubber ceramic cap for the PFC MOSFET, it is connected between the S and D pin of the MOSFET, ceramic cap fail's mode is shorted circuit., common failure in other power supply boards too.
            Best to go with higher Voltage than 1KV.
            • electomech-fixer
              First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
              by electomech-fixer
              I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
              I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
              09-15-2025, 01:42 AM
            • swimllamaswim
              Precision 5550 LA-J191P No Power, Burnt ISL9538
              by swimllamaswim
              I picked up this Precision 5550 to fix up recently, and found that the ISL9538 chip was burnt on pin 14 (CSIN). The two left side Type C ports negotiate at 20v, and the right side one only negotiates at 5v. I also found the EMI protection diode, DT35, was burnt on that side. I pulled the ISL9538 off, checked for any other obvious shorts, repaired the pad, and put a new one on. Now, I still do not get power, and there is a rapid clicking sound from somewhere on the board that I can't pinpoint.
              Here are the voltages measured at that chip:
              To note, DCIN at Pin 17 is low,...
              09-21-2025, 12:26 PM
            • I8jjrnhh4thvtl0dWZoY
              Repair Manual for Bosch SHX55M05UC/46 Dishwasher (702_58300000148618_ara_en_a)
              by I8jjrnhh4thvtl0dWZoY
              Repair manual part number 702_58300000148618_ara_en_a
              It took way too much effort to find this manual so I am sharing it here so the next person can find it easily. Also, I am mad at Bosch for not publishing it on their website, so they deserve to have it leaked....
              07-14-2025, 07:36 PM
            • mferna14
              Apple MacBook Pro A2338 820-02773-A AON Rail burnt
              by mferna14
              Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
              06-25-2025, 11:26 AM
            • nobbnobb1
              Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
              by nobbnobb1
              I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
              - 1x 3.14 A @ 250V main circuit fuse
              - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
              - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
              11-16-2024, 09:56 PM
