Panasonic sc tnpa5081 rebuild
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic sc tnpa5081 rebuild
    Originally posted by stryacker
    solved staff!!
    I reball in ddr3 memory of the motherboard and she returned to work
    Nice job, interesting because I have a mainboard from a 50U20 which is the cheap version of this TV, sounds like same issue just lose picture and control of TV, running with green LED. I've replaced the main board but still have the old one. I shall keep it for an experiment one day and try your memory reball / flow? What are the chip numbers you worked on?
    • leeroy012
      • Jun 2015
      • lithuania
      #282
      Can you tell me what chips are on sc board TNPA5081 in q421 and q403 places?
      • tw2005
        • Oct 2011
        • 6458
        you know if you read this thread you'd find out or search.
        anyway DG502LW DG402LW by panasonic
        D16451 RF101L4S 400V 1A
        D16482 RFN25TM4SW
        D16702 MA2J11100L 80v 100ma
        Q16452 GT45G128
        IC16521 M81737FP
        IC15771 78L05L, TA78L05F
        IC16773 TC7SH14F, marking HA, Schmitt NOT
        Q16402 DG3D5020
        Q16403 DG3D5020
        Q16421 DG3D4020
        Q16422 DG3D4020
        Q16521 CPH5524-TL-E
        Q16551 CPH5524-TL-E
        Q16647 2SK3018T106,2n7002
        Q16661 RJP63F3A
        Q16701 MMBTA92
        Q16702 2PD601ART,215, 2SD0601A0L
        Q16818 2SK3018T106,2n7002
        R16521 100 OHM,J,1/8W 1
        R16522 100 OHM,J,1/8W 1
        R16707 3.9KOHM,J,1/8W 1
        IC16561 TC74VHC541FK
        IC16562 TC74VHC541FK
        • mngopher22
          • Aug 2015
          • 6
          tw2005 I just had my tv's TNPA board go bad. Here is my first pass diagnosis.
          Part Status Manuf Notes
          Q661 SHORTED RJP63F3A
          Q401 SHORTED DG502LW
          Q402 OK DG502LW 580V breakdown
          Q403 OPEN DG502LW
          D401 OK F50ALW
          D402 OK F50ALW
          Q421 SHORT DG402RP
          Q422 SHORT DG402RP
          Q423 SHORT DG402RP
          D421 OK FUS20T4S 430V 20A
          Q601 OK JK60
          Q452 SHORT 45G128
          D481 OK RFUS20
          D482 SHORT RFUS20
          R551 OPEN
          R452 OPEN
          R521 OPEN
          R522 OK
          Q551 SHORT PNP/NPN totem buffer
          IC521 BAD M81737FP Gate Driver
          IC562 OK Buffer
          I have pulled out all of the bad parts I could find. I then powered up the 5V, 15V, 16V_F, 15V_F, and 5V_F individually. You can power individual circuits with a nice current limited power supply. This helps in diagnosing whats wrong. I will detail this process in my next post. I believe now that those power up with no shorts, I don't have any bad parts left in the circuit. Now I need to source some replacements and begin to repopulate the board.
          • tw2005
            • Oct 2011
            • 6458
            IC16563 C0JBAB000916 IC 1 , marking c14, INVERTER IC = TC74VHC14FK VSSOP Toshiba
            UTSOURCE has them, also direct from panasonic parts stockists
            • tw2005
              • Oct 2011
              • 6458
              D16482 RFN25TM4SW
              Q16452 GT45G128
              IC16521 M81737FP
              Q16402 DG3D5020
              Q16403 DG3D5020
              Q16421 DG3D4020
              Q16422 DG3D4020
              Q16521 CPH5524-TL-E
              Q16551 CPH5524-TL-E
              Q16661 RJP63F3A
              Q16701 MMBTA92
              this is not necessarily a "do this" guaranteed list, 30f125 IGBTs x 2 not mentioned but can be assured at least 1 will be bad majority of the time, I'd replace both, may see 200-300ohms across legs which is bad, may miss these if you rely on continuity check alone.
              • tw2005
                • Oct 2011
                • 6458
                Q403 OPEN DG502LW
                D401 OK F50ALW
                D402 OK F50ALW
                Q421 SHORT DG402RP
                Q422 SHORT DG402RP
                Q423 SHORT DG402RP
                Q601 OK JK60
                Q452 SHORT 45G128
                D481 OK RFUS20
                D482 SHORT RFUS20
                R551 OPEN
                R452 OPEN
                R521 OPEN
                R522 OK
                IC562 OK Buffer
                Not optimistic with your list. must be a 54" model. But i don't see IC771,773, Q701,702, 818, or any 30F125 IGBTs. Also D451 can short
                • myfastgti
                  • Aug 2014
                  • 32
                  Thanks tw2005 for helping me identifying the faulty 30f125. Too bad the diode continuity shows both good but resistance check actually confirms if they're good or not. I my case both were around 264 ohms
                  Have already placed an order with Utsource last week.
                  • tw2005
                    • Oct 2011
                    • 6458
                    If that was in cct then when pulled 1 may test ok as they're paired just like the DG402 & 502 IGBTs but for those usually both will be bad.
                    I'd replace both but you may need to redo ic773, q701,702,818 and obviously whatever else has shorted. Sometimes you're better off replacing everything associated that drives Q661.
                    If you go to the schematic there a 3.9k resistor that can blow with a failed attempt on Q661 blowing again. Check D451 too that's another that can be missed.
                    Once you get one right, the next one will be easier. I always do ic773, q701,702,818 regardless of whether I think they're good or not.
                    Chances are ic771 is ok, they don't always go when ic773 shorts
                    • myfastgti
                      • Aug 2014
                      • 32
                      IC 771 is good and I did received IC 773 from Digikey last week, still waiting for 30f125. Since I choose USPS, it'll be at least 2 weeks before I can retest the board.
                      The r707 3.9 k Ohm was good in both attempts but Q701 didn't survive. I believe there is a 4.7 k ohm resistor across both fets which was giving me reading of less than 100 ohm. Will see once I've all the parts
                      One last question I wanted to ask is do I need to worry about Q521 CPH5524-TL-E and Q551 CPH5524-TL-E. They seems good as the resistance check confirms according to your previous post.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Off the top of my head they often survive. I have not had to replace these except maybe one board. Once you have the FET driver, the 45G128 etc that are bad around there removed, if you check resistance across the opposing pins at both ends I think it may show 2-3 megohms,
                        That's width ways not length way as you look at the device. On the side that has 3 legs,end to end on that same side will show short .
                        • myfastgti
                          • Aug 2014
                          • 32
                          3rd attempt failed again with a load pop and back to square one.
                          One thing I want to bring to attention of everyone is I received 16 pieces of 30f125, out of which 2 pieces have resistance of 27k and 300k compared to rest which showed between 1.7 and 2.0 M Ohm. Not sure if you guys run into these while ordering from Utsource.
                          Here's the list of components I replaced
                          D16451
                          D16482
                          Q16452
                          D16702
                          IC16521
                          IC16691
                          IC16724
                          IC16771
                          IC16773
                          PC16461
                          Q16402
                          Q16403
                          Q16421
                          Q16422
                          Q16521
                          Q16551
                          Q16621
                          Q16622
                          Q16647
                          Q16661
                          Q16701
                          Q16702
                          Q16818
                          R16452
                          R16551
                          In the next attempt I'll be replacing IC16792, IC16561 and IC16562 since this only ones IC's didn't replaced
                          • tw2005
                            • Oct 2011
                            • 6458
                            D16451
                            D16482
                            Q16452
                            D16702
                            IC16521
                            IC16691
                            IC16724
                            IC16771
                            IC16773
                            PC16461
                            Q16402
                            Q16403
                            Q16421
                            Q16422
                            Q16521
                            Q16551
                            Q16621
                            Q16622
                            Q16647
                            Q16661
                            Q16701
                            Q16702
                            Q16818
                            R16452
                            R16551
                            I'll try and digest this soon but my hopes are low , really expect a win this time, failed attempts and additional damage i suspect = near impossible(for me) to work out. i only got my 5 attempt board going with the aid of a good board to check against and even then there was a fair amount of luck. This is such a shame, it's the misssed 30F125 s that started this roller coaster.
                            I understand the drive to succeed though. If a broken one pops up on ebay that may be cheaper and easier to ry again. there were 5 not long ago but they got snapped rreal fAST BY SOMEONE WHO REPAIRS THEM i SUSPECT.
                            Dammit, CAPS lock
                            • tw2005
                              • Oct 2011
                              • 6458
                              @ MYFASTGTI
                              Mate I'm out of ideas, must be something that does not normally fail maybe after a failed repair.
                              One thing i need to know, when you you powerup the SC is that with buffers connected or without and SC50 jumpered.
                              Asking just in case you have the buffers connected and they are shorted? Have you checked the buffers?
                              • myfastgti
                                • Aug 2014
                                • 32
                                @ MYFASTGTI
                                All tests were conducted without buffer boards/SC50 shorted. I also checked SU/SD boards and they tested good before I started working on SC board.
                                Have you run into bad 30f125 before ? Out of 16 peices I ordered 2 were having resistance of 300 kohm. I'm checked these fresh out of box as they arrived. I've a feeling some of the other IGBT's might have been DOA and would be the reason for failures.
                                Have been really busy and haven't started working on removing the failed components from SC board yet. Also someone of the Craigslist is selling cracked Panasonic TV with similar model, I'm going to buy and compare the readings of all the replaced components and will post results.
                                One thing I noticed that the readings of boards with MIP390's are way too different than boards with MIP391. A resistance check of MIP390 is around kohm but a resistance check of MIP391 is in mohm with ground.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Never touched one or replaced But I think someone here has and was faulty. If you tell me what you get on each pin and referrence I could dig out a board to see. With cracked panel TV, I've found the buffer dies but so far from 3 TVs SC have survived and SD always shot. Unless of course the panel was cracked and power never applied.
                                  Have not had issues yet with the bits but I'm always suspiscious
                                  • dolivas27
                                    • Mar 2014
                                    • 66
                                    I have a quick question what DMM are you using for these measurements? Once you report back I will let you know why I am asking.
                                    I am currently working on a board out of a 54" TV I will report back my repair after I receive my parts on Monday.
                                    Thanks,
                                    Dean
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Thanks,
                                      Dean
                                      I have an old fluke 75
                                      • dolivas27
                                        • Mar 2014
                                        • 66
                                        Ok I need a little help with this one.
                                        Ok so I picked up this unit cheap to try and repair it. Model # TC-P54G25
                                        The unit has the 7 blink code and of course the problem is the SC board. or so I thought
                                        TNPA5081 Rebuild Notes
                                        1st Repair Attempt
                                        Replaced = Not sure if it was Bad
                                        IC501 - Replaced
                                        IC521 - Replaced
                                        Q421 - Shorted
                                        Q422 - Shorted
                                        Q423 - Shorted
                                        Q401 - Shorted
                                        Q402 - Shorted
                                        Q403 - Shorted
                                        Q452 - Shorted
                                        Q661 - Shorted
                                        D481 - Shorted
                                        Q818 - Replaced
                                        IC771 - Replaced
                                        IC774 - Replaced
                                        IC691 - Replaced
                                        IC773 - Replaced
                                        Q702 - Replaced
                                        Q521 - Replaced
                                        Q551 - Shorted
                                        Q660 - Shorted
                                        Q701 - Replaced
                                        2nd Repair Attempt
                                        I retested everything again like I was starting the repair from the beginning and here is what I found. I was looking at the flow chart and Q608 jumped out at me as a possible problem part. I'm wondering if others that have failed did not have a bad Q608 it was causing the Q661 to blow every time! I would not have found this bad part if I did not remove it from the circuit. What I found was the part was leaky when tested. I replaced it a reinstalled the board SUCCESS THE BOARD NOW WORKS!!!!
                                        D642 - Shorted
                                        Q661 - Shorted
                                        Q608 - Leaky
                                        Ok now it's time to connect the buffer boards and fire it up. Yes I measured the buffer boards and they looked good NO shorts. Being All excited I have it fixed I connect everything and plug it in and BANG a loud POP now a 10 Blink code! Test for shorts again and now the Vsus is dead shorted! Remove the SC2 connector and turn the set back on and have the 7 Blink code again! SC BLOWN AGIAN!!!!!
                                        3rd Repair Attempt
                                        Once again retest everything like I was starting the repair from the beginning. This is what I found blown I had to order PC461 from China so I had to wait 2 weeks for it to get here. Thinking I must have measured or missed a shorted buffer board I ordered both buffer boards while I waited for the PC461 to get here. I receive the buffers and tested them they look fine as do the originals?
                                        D642 - Shorted
                                        D641 - Shorted
                                        Q661 - Shorted
                                        Q402 - Shorted
                                        Q421 - Shorted
                                        Q422 - Shorted
                                        Q423 - Shorted
                                        D642 - Shorted
                                        Q661 - Shorted
                                        PC461 - Shorted
                                        PC461 came in and I installed it and retested the board everything looks good. Reinstall it in the set and once again tested it without the buffer boards and the jumper installed in SC50. Everything powers up fine no blink codes!!!! Power cycled it several time to make sure it was fine. Reconnect the new buffer boards take some measurements to make sure everything looks good it does so decide to proceed with a power up. BANG LOUD POP and the SC BLOWS AGAIN!!!!
                                        What am I missing could the Panel be bad? I checked it to Chassis ground and do not see any shorts. Could the SS board be causing this? but if that was case would it not blow with the buffers removed and the SC50 jumper installed? Going to rebuild the SC again but before I test it again with the buffers installed I need some help to figure out what is causing it to BLOW.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          1st Repair Attempt
                                          IC501 - Replaced
                                          IC521 - Replaced
                                          Q421 - Shorted
                                          Q422 - Shorted
                                          Q423 - Shorted
                                          Q401 - Shorted
                                          Q402 - Shorted
                                          Q403 - Shorted
                                          Q452 - Shorted
                                          Q661 - Shorted
                                          D481 - Shorted
                                          Q818 - Replaced
                                          IC771 - Replaced
                                          IC774 - Replaced
                                          IC691 - Replaced
                                          IC773 - Replaced
                                          Q702 - Replaced
                                          Q521 - Replaced
                                          Q551 - Shorted
                                          Q660 - Shorted
                                          Q701 - Replaced
                                          2nd Repair Attempt
                                          D642 - Shorted
                                          Q661 - Shorted
                                          Q608 - Leaky
                                          3rd Repair Attempt
                                          D642 - Shorted
                                          D641 - Shorted
                                          Q661 - Shorted
                                          Q402 - Shorted
                                          Q421 - Shorted
                                          Q422 - Shorted
                                          Q423 - Shorted
                                          D642 - Shorted
                                          Q661 - Shorted
                                          PC461 - Shorted
                                          I've got no idea I'm afraid as I have not been in this situation. For me at least if it passes without the buffers, it's worked and kept working. Can't see it being the SS as it's not directly tied to it like the HD models.
                                          Really weird 2 sets of buffers doing the same. Is everything in right, all bolts for the SC and teh sd/su? All ribons in straight on the sd/su, ribbon between the sd/su connected?
                                          what pins on which buffers and what resistances did you get?
                                          what suffixes are on the buffer boards?
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • zen
                                            Txl47e5b , panasonic nand chip advice
                                            by zen
                                            Hi all
                                            Issue with this set is that after a few minutes of working , the remote control & on board functions stop working .
                                            Current software version is 1267-10402 , which i assume is the latest available , as i cannot get set to take an upgrade.
                                            Managed to obtain a working main board , which has same software version .
                                            Transplanted the TSOP 48 NAND chip , IC8900 ( 29F4G08ABADA ) from the working board into the faulty board , which now is working .
                                            This proved NAND chip is the problem , in the form of corrupt data....
                                            02-02-2021, 11:51 AM
                                          • sohail5307
                                            Need a2159 128gb nand bin file
                                            by sohail5307
                                            I have received SSD nand short A2159 macbook. I received new tsb4226 nand , but i think this is removed from iphone, I have nand programmer , if anyone have nand firmware please send me
                                            Two nand are using :
                                            Tsb4226(128gb)
                                            Tsb4226(128gb)
                                            09-16-2023, 09:20 PM
                                          • AquaMan Ua
                                            by AquaMan Ua
                                            05-17-2025, 09:40 AM
                                          • kenzo2
                                            Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
                                            by kenzo2
                                            I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
                                            I need dump file MACBOOK PRO A2159
                                            TSB4232(256)
                                            TSB4229(256)
                                            Thanks​
                                            01-11-2025, 04:18 AM
