Re: Panasonic sc tnpa5081 rebuild
OK, finally was able to get to this project again
I'll try to answer your questions
Yes, I decided to fix the board versus buying replacement after finding this forum, and don't regret doing it even though replacement parts will eventually cost me almost same after all, but that itch was hard to resist, what can be better than learning something in the field you work and you love what you do
Anyway, I have already 4 SC boards in my posession since I started
1 AF version from the TV (not working, project) TCP50G20
1 AF version from friends shop (not working, became donor)
1 AH version from his shop (not working, has less damage then other two) goes on 42" TV according to Shopjimmy
1 AL version (working, but from TCP54VT25 model)
So here is the list of parts I've replaced:
D451 (short)
IC521, M81737FP (short between pins 7 and 8)
IC501, M81737FP (put it back in, looked ok)
Q452, 34G128 , shorted
D482, RFN25, shorted
Q421, Q422 , DG402RP, both shorted
Q402, Q403 DG502LW, both shorted
IC773, Schmitt inverter(HA), shorted
Q701 (7EW), shorted
Q702 (C3W), shorted
Q661 RJP63F3A, shorted
5V regulator IC724 checks good on all boards
All C541's check good on all boards
After parts listed above were replaced, Q661 blew again and I found that Q621, 30F125 shorted and Q622, 30F125 was open
I can't imagine I missed those 2 first time, but can't be 100% positive
If I did miss them that should explain why Q661 blew again, right?
Now I have several parts in transit, so untill I get them from China, I can't do much, but wonder what should I do after I get the parts:
1. Replace Q661 again on the board along with 30F125's and taking your advise plug it in with buffers disconnected
2. Do the same plus replace that M81737FP I did not replace first time
2. Rebuild another AF board, which has 30F125's intact
3. Restore AL version to working condition and take a risk and try it on the TV, even though it is from larger TV
4. Repair AH version (it has q701,702 and IC773 intact) and plug it in, even though it is from 42"
5. All of above, without plugging 42 and 54 versions, since I will probably have enough parts
David
D451 (short)
Q701 (7EW), shorted
Q702 (C3W), shorted
David
