Panasonic sc tnpa5081 rebuild
  • tw2005
    • Oct 2011
    • 6458
    I've got 3 of these boards now and had no luck finding somone with a good one so I'm biting the bullet and going to have a go at component level.
    I've worked out most of what i think is failed when I stumbled across a reading across the 5v reg IC16771 VAD +5V between gnd and out of 5.2ohms. The other 2 boards have 2 & 8 ohms.
    This seems too low and would exceed what the little reg would handle I believe.
    Through elimination I've tracked it to what I believe is a 5pin, 2 input NAND gate. It has a marking "HA" which I believe I've tracked down as a 74HC1G00GW, SOT353 .
    I've confirmed out of cct the resistance between gnd and Vcc to the same 5.2 ohms and there is no longer that resistance present on the 5v reg.
    Just looking for advice or confirmation of my findings. Does anyone know what you'd expect to see across the nand gnd/Vcc?
    If I do get lucky and get one going I'll be adding all my research down the track.
    The pictures are one out of the manual & the other is from the datasheet for what I believe this is.
    Re: Panasonic sc tnpa5081 rebuild
    You'd expect to see more than a kohm between Vcc and GND so it's definitely bad. Question is why did it go bad. A logic gate is pretty reliable. Perhaps something on what it is connected to shorted to a higher voltage like Vsus.
    • tw2005
      • Oct 2011
      • 6458
      Yeah it's the needle in the haystack Tom. SU board short on 5V line, and another(i forget Vfo) and a dead SC.
      RJP63F3A x 1
      30F125 x 2
      178M05 x 1
      DG502LWx2
      DG402RP x 2
      45G128 x 1
      M81737FP x 1
      Oh and this is the "Tested Working " board I was supplied. I know, I'm dreaming like you said about these being tested.
      It won't be a cheap gamble to see if I get it going. I just wish i still had my good spare to compare the pair.
      I just found another nand onboard(smaller too! ) it tests in the K ohms about 4.
      Am I correct about what this device is?
      • tw2005
        • Oct 2011
        • 6458
        May have jumped to a conclusion too soon. just looked at some inverter cmos logic chips at RS and they have the exact pinouts. I was thinking they labelled NC as it was not used(pin 1) But the case is marked HA?
          It's an inverter, not a NAND. Something like 74LVC1G04.
          • tw2005
            • Oct 2011
            • 6458
            Cheers, I'm leaning that way too although no idea what spec. I'll check it out.
            • tw2005
              • Oct 2011
              • 6458
              Ok I've found this on only one board shorted. D16790 markings 34 and I think it might be this diode pd3s120l,
              What do you think? Is this simply cct protection? The way I see it if it was removed the cct would work.
              The dimensions and ratings make it conceiveable it's correct.
              Edit: after a closer look this is also part of the 15V fed to IC16521 FET driver M81737FP, 6.2 ohms across the diode and Vcc/gnd at the chip which are all in cct. I think it's going to be the IC.
              • tw2005
                • Oct 2011
                • 6458
                here's some buffer boards measurements I have on 3 sets.
                  Looks like a transorb (TVS) to absorb spikes on 15V line.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Transorb? man, I am out of touch. Did you have a look at those readings in my spreadsheet?
                    Is it the same schematic symbol for a TVS as for a diode?
                      TVS is basically a diode that "normally" never conducts. It can handle large reverse power of up to 5000W peak (around 500W for an SMD one.) Basically shorts out the supply if there's a failure. Think of it as a high power zener diode.
                      • tw2005
                        • Oct 2011
                        • 6458
                        Just spotted another small difference in the boards. Rev AF,AP have no capacitor installed at C461 (C16461), AW does. What's interesting here is in my manual which has the AF rev, it shows it in cct and on the parts list. This may explain why the same part number is showing for Q660 & Q601 which are both RJP6026 transistors on the AW and on the AF,AP R5007ANX transistors at Q660 and at Q601 it's RJP6026.
                        • tw2005
                          • Oct 2011
                          • 6458
                          Confirmed, IC16521 short or 6.2ohms across gnd/vcc. Diode now checks ok.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Tom, I ordered that 74LVC1G04 from RS and arrived today but last night I believe I found the correct item.
                            Toshiba TC7SH14F, marking HA, Schmitt NOT
                            http://home.zcu.cz/~ronesova/index.p...uitem=tos1gate
                            I think the 74LVC1G04 should still do the job or should I try and get the Toshiba which are out of stock at RS until early march.
                            Any thoughts?
                              The normal inverter doesn't have Schmitt tendencies, so it might pick up more noise. I would suggest a Schmitt substitute.
                              • tw2005
                                • Oct 2011
                                • 6458
                                Good pickup, was not even looking for that. Just the basic stuff like voltage,current ratings and propagation delay not that I really know what the hell I should be focussing on.
                                So this one came up using Ti cross reference.
                                SN74AHCG14
                                So the really hard question, using non schmitt will it;
                                a.work
                                b.not work
                                c. smoke
                                d. No idea, take my advice and get the right one
                                  D. I'm going to go with "D".
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    LOL. I would too, oh well who said progress was always easy.
                                    At least I've finally found the right device, brand and markings. It was bugging me taking a pot shot.
                                    • rcpilot82
                                      • Feb 2013
                                      • 33
                                      Have you found a source for this part yet? M81737FP
                                      I know I have a blown one on my board and I could not source one.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        If anything you should be able to get any part direct from the several suppliers of OEM TV parts in your country.
                                        How hard are you trying? Have you downloaded a manual yet as all the part numbers are in that.
                                        I can't as none will deal out of the US.
                                        http://cceparts.com/productdetail.as...r=C0ZBZ0001708
                                        http://www.searspartsdirect.com/part...01708/0057/528
                                        Have you had a chance to resistance test those buffer boards of yours and post the results for me to compare?
                                        • tranquility
                                          Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                                          by tranquility
                                          i want to repair an Onkyo TX-NR809 receiver.
                                          symptoms:
                                          on power on, display appears and i hear one click. enue functions is given.
                                          - no hdmi output
                                          - audio output not tested, but i think it is not there
                                          - usb sticks are not recognized
                                          if i read out the chips with display+standby button + tone+
                                          both dts show only ????
                                          chip is D830K013BZKB4
                                          things i have done:
                                          - reflow of the dts chip without taking off and reballing
                                          - changed the aluminium caps without the big one with 25v because i dont...
                                          Today, 01:04 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
                                        • zen
                                          Txl47e5b , panasonic nand chip advice
                                          by zen
                                          Hi all
                                          Issue with this set is that after a few minutes of working , the remote control & on board functions stop working .
                                          Current software version is 1267-10402 , which i assume is the latest available , as i cannot get set to take an upgrade.
                                          Managed to obtain a working main board , which has same software version .
                                          Transplanted the TSOP 48 NAND chip , IC8900 ( 29F4G08ABADA ) from the working board into the faulty board , which now is working .
                                          This proved NAND chip is the problem , in the form of corrupt data....
                                          02-02-2021, 11:51 AM
                                        • sohail5307
                                          Need a2159 128gb nand bin file
                                          by sohail5307
                                          I have received SSD nand short A2159 macbook. I received new tsb4226 nand , but i think this is removed from iphone, I have nand programmer , if anyone have nand firmware please send me
                                          Two nand are using :
                                          Tsb4226(128gb)
                                          Tsb4226(128gb)
                                          09-16-2023, 09:20 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
