DYNEX DX-32E150A11 No power, LED, or any life
  • Patm233
    • Feb 2013
    • 8
    • Usa
    Hey all I'm pat and I appreciate anyone's input on this.
    Last week a family friend gave my parents a non-working LCD tv. Last year, I was given a nonworking LCD and it had bad capacitors so it was a simple fix. This tv however is giving my father and I a run for our money. i'm not so great with repairs, but my father is fairly good at all the technicals.
    We checked the capacitors, nothing. Fuse looks fine, nothing seems out of place. We tried multiple power cords in multiple wall recepticals and no luck.
    Any ideas? I took some pictures in case you may see something we don't. If you need close ups I can retake some.
  • awyatt2
    • Feb 2012
    • 407
    • america
    Re: DYNEX DX-32E150A11 No power, LED, or any life
    do you have a vom to check the output voltages? the power supply (brown board) is labeled at coectors as to what they should be. check them first post the voltage listed ad what you actually get.
    stby 3.3listed 1.2 actual
    • Patm233
      • Feb 2013
      • 8
      • Usa
      I assume you meant connectors?
      We're supposed to read 24V at either connector and are reading 0 (zero).
      • Mr Bill
        • Nov 2011
        • 648
        Check the fuse with your multimeter set to OHMs and see if it reads 0.000, if it's more than 1 ohms it's bad. Then with the tv plugged in (not on). Set your meter to DC volts and put a your red probe and black probe on the 2 legs that come from the large cap. I drew a square around it. Be careful not to touch the 2 probes together when you are checking the large cap.
        • Patm233
          • Feb 2013
          • 8
          • Usa
          We've got 0.3 OHMs on the fuse.
          large cap reads 167.5 DCV
          • Mr Bill
            • Nov 2011
            • 648
            That's good.
            So the set won't turn on at all? Can you take a clear top and bottom photo of the power supply, larger size? Try and get it 2000 x 2000. You might have to use windows paint to shrink it down.
            • awyatt2
              • Feb 2012
              • 407
              • america
              does the voltage increase on the large cap whrn you try to power it up or stay the same?
              • Patm233
                • Feb 2013
                • 8
                • Usa
                Tried to get it as clear as possible so I broke the back into two photos and the front into three. Let me know if I need to snap a certain area
                • Patm233
                  • Feb 2013
                  • 8
                  • Usa
                  When I plug it in, it increases
                    To what voltage does it increase to approximately?
                    • Patm233
                      • Feb 2013
                      • 8
                      • Usa
                      After plugging in it'll hit about 167. Then he discharged it which lowered to 150, but then it goes back to 167 again
                      • awyatt2
                        • Feb 2012
                        • 407
                        • america
                        it should show an increase when you plug it in because it charges to stby voltage but it should increase agian if it starts up. somewhere near the main cap you should find a 8 legged ic with a small electrolytic cap closeby usually 10 to 47 uf at about 50v or so try replacing it and see if anything changes
                        • MisterD
                          • Oct 2012
                          • 668
                          I suggest that you plug in all connectors, secure the power supply board with all mounting screws, even though the TV will not power on go ahead and check and record all voltages on both of the white connectors on the PS Board and report them back here.
                          • tvguy12012012120
                            by tvguy12012012120
                            02-07-2025, 05:13 PM
                          • someonenotyou
                            Dell Vostro 3501 - no signs of life after BIOS read
                            by someonenotyou
                            Hi.
                            I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
                            Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
                            After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
                            Then I took the motherboard out...
                            01-27-2025, 05:15 AM
                          • davidk35
                            Lenovo ThinkBook 15 G2 ITL, some little signs of life
                            by davidk35
                            So i got above mentioned laptop. Which shows only some little signs of life.
                            When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
                            What ive already done:
                            -Flashed both bios chips 16 and 8 mb.
                            -Tried adding another stick of ram
                            -Check if backlight is faulty.
                            So any ideas?
                            Thank you
                            09-03-2025, 06:34 AM
                          • KYBOSH
                            Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                            by KYBOSH
                            I picked this one up today.
                            Previous owner says no signs of life.
                            TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                            Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                            The TV model is QN65LS03BAFXZA - version: CB06
                            The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                            I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                            Will keep you all...
                            04-05-2025, 08:32 PM
                          • Francisc Records
                            Asus N751JK no power, no sign of life
                            by Francisc Records
                            First of all im glad i've found this forum and i'm happy to start learning new things and sharing my knowledge with others!
                            Long story short : I have a laptop from work that has no power and no signs of life. My first question is: A 90W charger(19V 4.5A) is enough for this laptop? Because the original charger was 19V 6,4A(120W), so all the testing was done with the 90W charger because i don't have a 120W charger.
                            This being said, i opened up the laptop and i've inspected the MB and the components, everything seems fine, no sings of explosion, burn,...
                            03-27-2025, 01:44 AM
