40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
  • tieny
    • Feb 2012
    • 478
    Re: 40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
    its 102 and 123, so 1000 ohms and 12000 ohms?
    Calculating Equivalent resistance I get 923 ohms.
    Measure the resistors in circuit I'm getting 793 ohms
      That seems OK, but the value seems a little low for a 24V rail feedback... I'm working on the idea that overloading them can change their value and cause the feedback to be incorrect.
      • tieny
        • Feb 2012
        • 478
        Do you mean their resistance can drop even lower when its overloaded?
        Question: whats the difference between these resistors and the other ones? how come these are green and the other smd ones are usually black?
          Most resistors increase in value when the fail. An increase in value leads to an increase in output voltage.
          They are precision thin film 1% or better, because the output might have a 2 or 3% tolerance which is hard to achieve with standard thin film resistors (5% per resistor, plus 2% TL431 error.)
          • tieny
            • Feb 2012
            • 478
            I'm trying to find the resistors on digitizer but can't find it. Do you know where to get a replacement?
              Digitizer?
              • tieny
                • Feb 2012
                • 478
                oops sorry i meant "digikey" lol
                  Get me the values of them, using the previously linked chart, and then I can find the appropriate part or category for each.
                  • tieny
                    • Feb 2012
                    • 478
                    Precision thin film resistors, "102" or 1000 ohms and "123" or 12000 ohms. thanks
                      Only those resistor values used?
                      • tieny
                        • Feb 2012
                        • 478
                        Yeah, these two:
                        https://www.badcaps.net/forum/attach...6&d=1359831625
                        theres 3 numbers on the resistors, I just thought the 3rd number on it says how many zeros correct?
                          Yes, if it is just a number, that is a power of ten, otherwise, you need to use the table.
                          I suggest you replace all of them to eliminate any doubt.
                          • tieny
                            • Feb 2012
                            • 478
                            Ok, so all five resistors?
                            https://www.badcaps.net/forum/attach...5&d=1359830813
                            thats 102, 123, 752, 183, 564
                            1000 ohms, 12000 ohms, 7500 ohms, 18000 ohms, and 560000 ohms
                            Just wondering, since its outputing the wrong voltages, is there any way to force and drop the voltage down by only 1 volt just to get it working?
                              I still don't know if I believe those values - 963 ohm parallel is very low for 24V feedback.
                              • tieny
                                • Feb 2012
                                • 478
                                Theres also a 103 resistor (10000 ohms) near the two parallel 923 ohm for the 24V feedback, would it affect it in any way?
                                  We need to draw out a schematic of this section, can you do that, or do you need help?
                                  • tieny
                                    • Feb 2012
                                    • 478
                                    Hmm not sure if its right, but looking at it, it seems to be in parallel with the three main resistors.
                                      That seems a bit more realistic; does one of the leads of the TL431 go to the middle of that divider?
                                      • tieny
                                        • Feb 2012
                                        • 478
                                        Hopefully i drew this right, I might of missed a thing or two.
                                          Makes a lot more sense - does 24V come into the feedback at all?
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • tec3000
                                            Sony LED 65X9005A shuts down after few seconds - looking for help
                                            by tec3000
                                            Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                            I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                            03-20-2024, 07:29 AM
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
