40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
    replied
    Re: 40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
    That means the main board is not sending PWM (AC) out, the same failure mode as the Philips TV.
    replied
    From the service menu.
    DISPLAY -> 5 -> Vol+ -> Power.
  • tieny
    replied
    How do I check the hours?
    replied
    Maybe the CCFL was sensitive to the dimming somehow, TV will no longer have dynamic backlight, but I always found that annoying anyway. Check hrs on backlight counter.
  • tieny
    replied
    Hmm, cutting it worked. TV turns on perfectly, no dimming when it gets to the HDMI screen, its just full bright.
    replied
    I would try disconnect that Dim control wire and see what happen.
  • tieny
    replied
    I don't think it can? Switching the probes around I'm getting 0VAC and same DC readings.
    replied
    Can your meter read frequency? The PWM for dimming is around 150~200Hz with variable pulse width, the amplitude is 0~5V typical, and since it is not sine wave the AC value reading will not make sense especially if it is not True R.M.S meter.
    replied
    What meter was used for that measurement? Try measuring AC with probes reversed - sounds odd, but some meters only look at the positive cycle of any AC.
  • tieny
    replied
    Originally posted by budm
    Pin 14 on the inverter connector, you can see the label by the connector. I remember troubleshooting the Inverter board for Philips Tv on the thread, we had the bl_on, the 24v, etc, but nothing on the PWMDIM, the lamps will flash on and then go out (2-second to black). Took us awhile to find out that the PWM has 0V reading (stuck low), when we disconnect the PWM pin, the backlights will stay fully on. So I am not sure if this inverter is using variable DC to control the dimming or PWM for controlling the dimmimg.
    Ohh i see it, once I hit the power button itll go up to 3.24V DC then 2.32V DC when the backlights go on, and 4.5V AC
    replied
    replied
    Everything looks fine.. Very odd!
  • tieny
    replied
    Originally posted by tom66
    Is nearby bad OLP the same voltage?
    What's VREF measure?
    On the pad, VREF reads 5.56V, OLP measures -0.01 when lights go off and -0.09 when its on
  • tieny
    replied
    pin 14? you mean this one? When I'm measuring it with respect to ground I'm getting a loud buzzing sound. It read around 2.5, 2.7V from what i saw I think. And getting 5.5V when set at AC
    replied
    Just put the meter in AC volt position. I am trying to find out if this dimming control signal is Analog dimming control type (0~5v) OO if it is PWM AC signal (around 150~200Hz) type.
  • tieny
    replied
    how would i measure it AC
    replied
    What voltage do you have at the EXTERNAL DIM pin14 on the inverter board, measure it with DC and AC mode on the meter.
  • tieny
    replied
    Heres something interesting I found...
    When I'm measure this pin, (PIN #19 i think) ill be 0.01V when the backlights go on.
    And as it dims when it gets to the HDMI input. It'll raise up to 1.96V steady THEN the TV actually stays on and works!! But as soon as I remove my probe from the pin the TV turns off and starts cycling through the problem again?
    I had a similar problem like this with that 32" dynex, where I just resoldered the ground pins and it fixed the problem (But only lasted 20 minutes til it fully died with a main board problem and I gave up on it)
    replied
    bad->"pad".
    Noted there is VREF pad, so check that too.
  • tieny
    replied
    What do you mean by nearby bad OLP?
    pin 7 (VREF) i'm measuring is 5.58V
  • mauda
    Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
    by mauda
    I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
    Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
    05-21-2023, 11:56 PM
  • tec3000
    Sony LED 65X9005A shuts down after few seconds - looking for help
    by tec3000
    Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
    I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
    03-20-2024, 07:29 AM
  • AK_777
    Sony KD-65A1 Repair – 4 Red Blinks Error
    by AK_777
    Hi everyone!
    I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
    Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
    02-20-2025, 04:15 PM
  • jchon
    Sony A1e 5-blinks help
    by jchon
    Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
    I found the service manual, which was critical to know where to probe.
    https://www.manualslib.com/manual/20...1e-Series.html
    With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
    Unfortunately the 5-blinks...
    06-28-2023, 11:52 AM
  • Nicktronic
    Sony XBR-65X850D 2 Red Blinks
    by Nicktronic
    I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
    Any Sony experts out there that can help??...
    11-19-2023, 06:51 AM
