LCD TV and Monitor basic troubleshooting guides
This is a sticky topic.
    I cannot find the original post so this is the new post that I will have it liked to my signature file. It will be good if it can be on the sticky.
    Notes: When make voltage measurement in the DEADLY Primary (HOT) side, the negative leg of the LARGE filter cap will be the ground ref.
    The chassis will be the ground ref for the Secondary (COLD) side.
    You should at least plug the unit you are working on into the GFCI outlet for safety.
  • Beowulf
    • Dec 2012
    • 175
    Re: LCD TV and Monitor basic troubleshooting guides
    Thanks Bud M.
    Have not seen it yet and I already like it.
    • Steve.B
      • Dec 2008
      • 83
      Great job Bud M. Very handy and informative guides. I am sure these will be of great use to a lot of people. Certainly agreed that these should be 'stickied'.
      • Beowulf
        • Dec 2012
        • 175
        Oops forgot to say I vote for this to be stickied.
          Excellent guides. Sticky please! Along with the factory reset guide of Randtek's that got buried.
            Yes, the stickied for the factory reset too, that is really good one.
            • retiredcaps
              • Apr 2010
              • 9271
              I'll ask ratdude747 (moderator) to make this a sticky. He's a reasonable person to work with and quick to respond when he's not busy with school.
              This will hopefully decrease the frequent questions and workload for everyone.
              --- begin sig file ---
              --- end sig file ---
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                BAM!
                Thread stuck.
                sigpic
                (Insert witty quote here)
                  BAM!
                  Thread stuck.
                  Is it possible to sticky this one, too?
                  https://www.badcaps.net/forum/showthread.php?t=24809
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Excellent work Bud!!
                    May I ask you, if you could include in these documents, some pictures with the standby voltage area(or other important areas of the device), the most important ICs(and what they do), how do we know if the PS should have 166V or 450V.
                    • Foppel
                      • 62
                      Hi Budm i like your cats Thanks for the Links. This page also helps me a lot: http://youclickspk.blogspot.de/p/tes...l#.UQF8yGf3G71
                      cheers - Foppel
                        This is SONY training manual for the T-CON.
                        • ohmmy
                          • 182
                          Wow great little tutorial budm. Explains things neatly and in correct sequence. Great guide!
                          • coxtel81
                            • Feb 2013
                            • ROMANIA
                            Excellent work
                            • dejesus
                              • 108
                              • usa
                              This inf. is great. A lot to learn in this side. hard to find inf. like this. Great!!!
                                TFT voltages:
                                Sanyo LCD display training manual.
                                AS15G (EC5575) spec
                                Washed out picture:
                                https://www.badcaps.net/forum/showth...mma#post304275
                                • rukmani
                                  • Mar 2013
                                  • india
                                  thank sir good work...................
                                  • Ahakim
                                    • Apr 2013
                                    • 64
                                    Need full Schematic of LG 32LD330 model. Who can help???...
                                    • HerbTech1
                                      • Apr 2013
                                      Thank you very much for this post. Lots of good reading ahead.
                                      • sinaaa
                                        • Apr 2013
                                        • syria
                                        Need full Schematic of samsung ln32c450e1d model. Who can help?
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • keepread
                                          Dell monitor PSU vs Dell laptop PSU
                                          by keepread
                                          Hi there!
                                          Someone gave me their old monitor, it's Dell S2715ht.
                                          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                          10-30-2025, 04:45 PM
                                        • wattage
                                          by wattage
                                          Hello Badcaps Community,
                                          07-13-2025, 04:41 PM
                                        • Rick_1234
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          Things I tried
                                          06-22-2024, 04:44 PM
                                          Wise Wing F199 19'' LCD monitor - recapped
                                          by momaka
                                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                          When I saw the Craigslist post, I wasn't...
                                          08-24-2020, 10:58 AM
