Samsung LNS3251DA won’t power on, no sound, no standby light-power board problems
  • BmD_Online
    • Jan 2020
    • 28
    • France
    #61
    Re: Samsung LNS3251DA won't power on, no sound, no standby light-power board problem
    I have replaced the MOSFET and ICP801S.
    I've build a Dim Bulb Tester (105W halogen bulb), and connected TV.
    Once connected, TV seems to be in standby mode (red led on).
    When I press start button, the bulb gets dim, but nothing happens to TV.
    I've tried without dim bulb tester, and... fuse blows, and... circuit breaker trips (we say like that in english ?) !
    I have spend to many money according to TV age, so I'm giving up !
    Thanks to everyone who helped me.
    • nomoresonys
      • 12328
      • U.S.
      #62
      Indeed BUT at this point it's not a matter of money anymore, it's getting to the bottom of the mystery why it is not working, right, lol.
      • BmD_Online
        • Jan 2020
        • 28
        • France
        #63
        You're right. I think I've burned MOSFET again with this attempt !
        Right now, I'm a little upset.
        Same power supply board is sold 15€ on eBay (refurbished) !
        I think I'll buy it, check if TV works, and compare the two boards.
        • nomoresonys
          • 12328
          • U.S.
          #64
          Just for fun, make sure all the caps n such you replaced, that none are in backwards and all have good solder joints and all the other solder joints are good.
          • nomoresonys
            • 12328
            • U.S.
            #65
            Need to figure out what is blowing the fuse.
            • nomoresonys
              • 12328
              • U.S.
              #66
              Did you check all the diodes?
              • BmD_Online
                • Jan 2020
                • 28
                • France
                #67
                Does the TV have to switch on when dim bulb tester is used ?
                Can I create a short circuit connecting inverter to wrong connector (S or A) ?
                I have double/triple checked all replaced caps.
                All solders joints seems to be correct.
                I will verify diagram. Maybe I've made a short when soldering SMD circuit (near to pin 4), but I don't think so.
                I will try to check all diodes too. Not checked yet.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #68
                  my dim bulb tester has no switch but i use a incandescent bulb i see you mentioned you used a halogen one im not sure if it works the same?
                  in your third picture can you clean all the flux off and post another picture of the same area
                  • BmD_Online
                    • Jan 2020
                    • 28
                    • France
                    #69
                    About dim bulb tester I mean when everything it right (after power supply repair), can I make TV power on and work correctly connected to dim bulb tester ?
                    Or I only can check for shorts, bu don't make it work fully.
                    I'm not sure my question is clear.
                    • nomoresonys
                      • 12328
                      • U.S.
                      #70
                      I believe if you have a short the bulb will light bright and stay bright, the tv should start with tester hooked up, prolly need a 60 watt or so incandescent bulb.
                      • BmD_Online
                        • Jan 2020
                        • 28
                        • France
                        #71
                        Here it is.
                          Edited: so the PFC MOSFET is tested as shorted again?
                          • BmD_Online
                            • Jan 2020
                            • 28
                            • France
                            #73
                            Without unsolder anything :
                            PFC MOSFET : 5.5 Ohms
                            bridge rectifier + - : 5.2 Ohms
                            bridge rectifier ~ ~ : shorted
                            RP819 : 0.8 Ohms (meter probes resistance is about 0.7)
                            I suppose I have to unsolder MOSFET, check it again and check bridge rectifier too ?
                            And, if I replace MOSFET, I have to replace ICP801S (tda4863-2) again ?
                            I have a second one, but I have to buy a new MOSFET and/or bridge rectifier if needed.
                              More likely that new MOSFET is blown again, it was OK when you first apply the power to the TV.
                              So did fuse blow the minute you bypass the lamp, or it blows the after the power switch is activated when the lamp is bypassed?
                              • BmD_Online
                                • Jan 2020
                                • 28
                                • France
                                #75
                                Yes, fuse blow directly when I bypass the lamp.
                                • nomoresonys
                                  • 12328
                                  • U.S.
                                  #76
                                  And your replacement fuse is an exact match?
                                  • BmD_Online
                                    • Jan 2020
                                    • 28
                                    • France
                                    #77
                                    Yes it is. 6.3A.
                                    I've ordered new MOSFET. I'll come back when I receive and replace it.
                                    We'll made controls at this moment.
                                    • R_J
                                      • Jun 2012
                                      • 9623
                                      Once you have removed the shorted fet, re-check the bridge rectifier, even with the fet is shorted (5.5Ω), you should not have a short between ~&~ of the bridge. If the bridge is shorted, ac is being applied to the pfc ciruit.
                                      • BmD_Online
                                        • Jan 2020
                                        • 28
                                        • France
                                        #79
                                        I have unsoldered the MOSFET.
                                        PFC MOSFET : different values according to multimeter position :
                                        103.4 K (multimeter set to 200K)
                                        15.54K (multimeter set to 20K)
                                        Looks like MOSFET isn't blown, but bridge rectifier is !
                                        Do you know an equivalent of TS4B05G ? I have difficulties to find a replacement one (except from China, with really long delay).
                                          Lift one end of RM801 then recheck the resistance of the bridge again.
                                          What is the exact resistance reading between ~ and ~?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
