Samsung LNS3251DA won’t power on, no sound, no standby light-power board problems
  • R_J
    • Jun 2012
    • 9551
    Re: Samsung LNS3251DA won't power on, no sound, no standby light-power board problem
    I believe TS4K60-A should be the same
    • nomoresonys
      • 12206
      • U.S.
      #82
      Ok, bridge rectifier should be the first or close to it, to check when fuses keep popping.
      • BmD_Online
        • Jan 2020
        • 28
        • France
        #83
        Originally posted by budm
        Lift one end of RM801 then recheck the resistance of the bridge again.
        What is the exact resistance reading between ~ and ~?
        RM801 ? sure ?
        when lifted :
        5.2 Ohms between + and -
        0.7 Ohms between ~ and ~ (internal multimeter resistance is about 0.6 0.7 too).
          To get 0.7 Ohms between ~ pins, at least two internal diodes of the bridge have to be dead shorts.
          Did you remove the bridge and test it yet?
          • BmD_Online
            • Jan 2020
            • 28
            • France
            #85
            Finally, I have unsoldered bridge rectifier.
            And... all diodes are blown.
            about 6 Ohms between + and -
            about 1 Ohm between ~ and ~
            In diode mode, all pins beeps between each other.
            I have ordered another brider rectifier (same ref) from AliExpress.
            Chinese new year, dispatch time... I should receive it within 37 days !
            In the meantime, I have received new MOSFET. I have compared values and confirm previous one isn't blown.
            • BmD_Online
              • Jan 2020
              • 28
              • France
              #86
              Hi again.
              I've received my bridge rectifier and replaced it.
              I have also ordered another power board (used).
              With this replacement board, the TV works. So I can compare components between the two board if needed.
              I've replaced the bridge rectifier on my board and re-soldered the MOSFET.
              Now, fuse isn't blowing. Great !
              But, TV stay in standby mode. I can't power it on.
              Red led is blinking... pressing power button does nothing.
              • nomoresonys
                • 12206
                • U.S.
                #87
                Maybe compare voltages between the good board and the bad one, from the bridge right on thru, checking the mosfets and diodes and resistors and whatever else is checkable.
                • nomoresonys
                  • 12206
                  • U.S.
                  #88
                  Maybe check those readings first with the mainboard unhooked from powerboard, not likely since it hasn't yet but you wouldn't want a faulty powerboard to damage the mainboard, of course a lot of the tests are done with no power to the boards.
                  • nomoresonys
                    • 12206
                    • U.S.
                    #89
                    Did you check all the caps right by the bridge?
                    • nomoresonys
                      • 12206
                      • U.S.
                      #90
                      A good rule is ALWAYS check new components you get from anywhere before installing, if possible, can save a lot of troubleshooting if you catch any bad ones before installing.
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
                      • howardc64
                        by howardc64
                        07-24-2025, 05:17 PM
                      • howardc64
                        Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                        by howardc64
                        • Prior owner tried a replacement main board. No difference.
                        • Samsung 2x red blinking standby LED = panel fault
                        • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                        • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                        • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                        07-19-2025, 10:54 PM
