RCA L32WD22 no picture
  • rossland
    • 8
    Hi, my TV quit while I was plugging in a HDMI cable (just coincidence?) The LED turns green, but no picture, sound, etc...can't bring up menu..nothing. When I turn it off the LED flashes amber 23 times. The voltages on the power supply check out .. 5v, 15v, but the 12v reads high at 14v. All caps are visually OK, nothing burnt. Same with main board. Any suggestions?
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: RCA L32WD22 no picture
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    • rossland
      • 8
      Thanks for your help. Hope these pictures are helpful. I am no expert by any means, and this is my first TV repair. I am pretty good at soldering, and have repaired other electronics. I have a few DMMs, and a scope. I forgot to mention in my last post that my 24v was also high at 27v.
      C
      • rossland
        • 8
        I had another go with the power supply board. Everything looks good with the exception of the 12 and 24 volt legs running too high. Is this acceptable? I'll check out the main board tonight.
          Can you take the pictures of the Inverter board/s? We need to see the BL_ON (ON/OFF) PIN which turn the backligts inverter circuit on/off.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            The 14v on 12v, and the 27v on the 24v does not seem right. Those caps in there look to be made by 'Elite', which of course is crap. Have you tested the voltages on the voltage regulators on the mainboard? They look like big transistors (they have 3 pins, and one tab. Usually one pin is cut off, however that does not affect operation, since the tab is used instead of that pin).
            Also, is this an LCD or an LED TV???
            Muh-soggy-knee
            • retiredcaps
              • Apr 2010
              • 9271
              On most lcd and TV SMPS, the voltage rails are typically unregulated. They will run high until there is a load (i.e. the TV is working with a picture and backlight).
              --- begin sig file ---
              --- end sig file ---
                And, on most DMMs, with a flat battery, readings will appear higher than they actually are.
                Most inverters will actually shut down with 27V on the 24V. Typically rated from 23V to 26V DC.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Yes, about once a month, we see cheap multimeters give incorrect readings with weak batteries, but with no indication of a low battery indicator on the lcd display.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I also dislike it when people don't post the exact reading.
                    For example, is the reading 27V? If yes, that would imply it is 27.00V exactly. Or is 26.88V, but rounded up to 27V?
                    Unless you are using an analog multimeter, please report all digits on the multimeter.
                    • rossland
                      • 8
                      Thank you for the advice. I will replace my battery and re measure the voltages. I uploaded a couple more pics showing the connections. I have voltage going to the Darfon board, but it doesn't turn on. What kind of signal does it need on the on/off pin... grounded, or a voltage ? Wish I could find a more useful service manual.
                      • rossland
                        • 8
                        After changing the battery, I got some readings that make sense...
                        5volt = 5.26 standby, 5.19 switched on
                        15volt = 15.01v
                        24volt = 24.01v
                        Now the 12 volt ... 13.54v on standby (should this have voltage on standby?) 13.47 switched on.
                        I think its safe to say that the 12 volt is too high. Could this be the cause of my problems? I checked the main board too. All the voltages at the regulators are within spec, as printed on the board.
                        Also, the 5 volt is a bit high, is this a problem?
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          15volt = 15.01v
                          24volt = 24.01v
                          If there is barely any load on it, then the output will be high. Just like in linear unregulated power supplies. No, I do not think this is your problem.
                          Muh-soggy-knee
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Budm asked for pictures of the inverter boards. I don't see them.
                              "All the voltages at the regulators are within spec, as printed on the board" I do not see any Voltage rating printed on the board by the Low Drop Out Voltage regulator ICs. The less info we get from you the less help you will get.
                              • rossland
                                • 8
                                Sorry guys, I'm new to this. More pics to come. The inverter board? Is that the one for the backlight?
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Yes.
                                  • rossland
                                    • 8
                                    More pics. I've included the values printed on the PCb for the regulators.
                                      OK, I see three small LDO Regulators but do not see any Voltage printing next to them that I can easily see in the pictures.
                                      I also see fuses on the inverter board that need to be checked.
                                      I also need good focus picture around the area of the inverter board connector, I cannot see anything printing on the board that shows the function of each pin of the connector. We need to find the BL_ON/INV_ON/ONOFF PIN.
                                      • rossland
                                        • 8
                                        Thanks budm. The LDO regulators you circled are all marked as "7E7L 17-33L" They measured as follows...
                                        LDO #1 Pin1 5.4mv Pin2 3.28v pin3 5.02v
                                        LDO #2 Pin1 4.3mv Pin2 3.33v pin3 5.02v
                                        LDO #3 Pin1 5.5mv Pin2 3.30v pin3 5.02v
                                        On the inverter board, 2 of the fuses read 0 ohms, but fuse 1 read 1.8 ohms.
                                        I've included a pic of the back of the inverter board that has the pin functions.
                                        The voltages at the cable (not plugged into the inverter board) are..
                                        Pins 1-5 (VDD) 24.07v
                                        pins 6-10 (GND) -40.01mv
                                        pin 11 -not used-
                                        pin 12 (BL ON) 0.85v
                                        pin 13 (VDIM) 9.9mv
                                        pin14 -not used-
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
