NEC Px42VM3A lost all display
    Re: NEC Px42VM3A lost all display
    there's a label next to the PSU (Power Supply Unit) on the left. But not on the PSU itself but on the let call it the sheet which the PSU is attached too. This has 4 gold screws which hold it in. on that label is the following
    42NH-PDP-4
    S/N 02214262
    Input AC 100-240v 50Hz/60Hz 5.4A
    Output +170V 1.6A,+60V 1.6A, +5V, 4.0A,+5V,0.8A, + 3.3V 1.8A
    + 7V 0.5A,+13V 1.0A,+24V 1.25A +6V 0.15A
    MFR. Origin Electric Co., LTD
    Made in Japan
    No other labels are on or near this PSU I looked under the PSU just to be sure.
      So the PSU should supply 60V but it isn't, 60V is one of the voltages we need. Can you get a pic of underneath the PSU so I can trace where it might come from?
        hope these will help. Let me know what I can do to assisit.
          I'm going to take a stab that the last two rows are VA, because it makes sense based on the connector layout.
          Those two black diodes -- check those. With TV unplugged & board removed, test on diode mode between pins 1-2 and 2-3, both ways. (Pins labelled arbitrarily from left to right, order unimportant.)
            can you show me which ones and do I need to remove them from the circuit board
              If I am correct the diodes are as follows 1 is behind the 4 white lets call them blocksnext to the heat sink and the other one is by a lone hwite box to the right of the 1500 uf 200V cap. Each of these reads 755 and 770
                I mean the two lone black devices in this pic.
                https://www.badcaps.net/forum/attach...7&d=1359412997
                  RC2 which has 3 pins reads 608 and RC1 which reads 678
                    Both ways?
                      what do you mean by both ways?
                        When you reverse the probes is the reading the same or different?
                          if you mean on RC1 which has 2 pins putting + lead on left and - on right and then switching them putting + on right and -on left it reads as follows
                          677 switching them it reads 547
                          as for RC2 which has 3 pins putting + lead on left and - on right it reads as follows
                          606 (+ on pin 1 and - on pin2) (+ on pin 2 and - on pin3) reads 1
                          (+ on pin3 and - on pin2) reads 606 ( + on pin2 and - on pin1) reads 1
                            They may be OK, but is it possible to remove them from the circuit and test them?
                            If those diodes are good, we need to find out why the VA transformer is not being driven.
                              RC1 the diode with 2 pins taken out of circuit board reads as follows
                              + on left - on right reads 1
                              + on right - on left reads 616
                              RC2 the diode with 3 pins taken out of the circuit board reads as follows
                              + on left pin 1 - on pin 2 reads 171
                              + on left pin 2 - on pin 3 reads 1
                              + on pin 3 - on pin 2 reads 164
                              + on pin 2 - on pin 1 reads 1
                                The diodes are fine then, re-install them.
                                  okay sounds good.
                                    Are there any fuses other than the ones near the main input?
                                      no, just those two
                                        Any like this?
                                        http://www.jprelec.co.uk/image/624-035_big.jpg
                                          nothing with that marking on the top. All I see is something simular that has 4R7 (there are 2 of these) and 1 that says 2R2
