is that the one you wanted?
I'll write this again if that's okay
Model NP42B2MF02
20220455
4.7-5,25/50-65/160-175
3.0/2.0/1.6A Factory ID : K
NEC CORP made in Japan
I don't know what that is but it has nothing to do with CN7.
I can see, right next to CN7, there is a line going over to a box with labels. What are these labels?
if you mean the 2 labels to the left of CN7 one is a serial # and the other is that info that I posted. I can give you the info thats on the right towards the middle but it's not a label
Huh, I had hoped for Vd etc.
Time for bed for me, will have a look in the morn.
thought I would add some more photos.
These are the bottom side of the circuit board # NEC 942- 200432.
as you can see this circuit board has gotten pretty warm. this is on the right side when unit is lying face down, This circuit board is connected to PH cable connection. This circuit board is found underneath the main input circuit board.
Do you see those cyan-blue capacitors with a "K" shape on top?
What voltage do you measure across them?
Good Morning,
Are these the ones you speak of ? just below CN7 see the pictures I included
These are labeled as C62,C63,C64,C65. Circuit board # 942 200 450
Do I need to remove the caps from the board to get measurment?
Should I use a cap meter or ohm meter and do I need power running to them? If I need power running I'll put it all back together or
Should I take the circuit board out. I only ask because it's a process to measure those from the bottom of the board.
Can I measure them by putting the + lead on top of the cap and the - lead to cassis?
What do you recomend?
Measure volts DC across them while the set is running.
The leads on either side can be probed, no need to remove it.
OK; this indicates a lack of Vda. Which will cause no picture.
Can you isolate all but the one long board going along the bottom of the panel. This means disconnecting all connectors. Leave the heatsinks on.
