NEC Px42VM3A lost all display
  • Dblueman
    • Nov 2012
    • 84
    Re: NEC Px42VM3A lost all display
    input ac 100-240v 50Hz/60Hz
    Out put +170v 1.6A+60v 1.6A +5v 4.0A+5v 0.8A+3.3V 1.8A
    +7v 0.5A+13v 1.0A
    +24v 1.25A + 6v0 15A
    Made in Japan
    • Dblueman
      • Nov 2012
      • 84
      is this what you need
      Input AC 100 -240v 50Hz/60Hz
      Output + 170V 1.6A +60V 1.6A+ 5V 4.0A+5V 0.8A+3.3V 1.8A + 7V 0.5A+13V 1.0A +24V 1.25A + 6V0 15A
      made in Japan
        170V is the nominal output of the PSU. We're looking for the panel's calibration sticker. Like this:
        https://www.badcaps.net/forum/attach...9&d=1326915294
        because each plasma panel is slightly different and the voltage settings must be set properly to ensure a good picture.
        • Dblueman
          • Nov 2012
          • 84
          Could it be this?
          NEC NP42 B2MF02
          202204255
          4.75-5.25/50-60/160-175
          3.0/2.0/1.6A Factory Id:K
          Made in Japan
          • Dblueman
            • Nov 2012
            • 84
            Thanks for being patient with me tom66
            • Dblueman
              • Nov 2012
              • 84
              I don't see any other labels. I've removed all the circuit boards and looked under them
              Those two were the only ones I found
                Hmm well normally there'd be a calibration sticker present. Can you measure the Vs voltage and tell us what you get?
                • Dblueman
                  • Nov 2012
                  • 84
                  how would I do that?
                  • Dblueman
                    • Nov 2012
                    • 84
                    What I mean to say is would I use a standard volt/ohm meter and where on the power circuit board would I test to give you a reading.
                      It'd be on the power supply connectors going to the X and Y-drive. Can you post a close-up shot of that connector, on the power supply end?
                      • Dblueman
                        • Nov 2012
                        • 84
                        I see the L and N but where would the X and Y be and what seting on the ohm meter do you need?
                          X and Y boards are on the right & left hand side of the plasma panel... It's those brown/white wires. Top of this pic.
                          https://www.badcaps.net/forum/attach...9&d=1358192926
                          • Dblueman
                            • Nov 2012
                            • 84
                            • Dblueman
                              • Nov 2012
                              • 84
                              try these, I see what you are asking
                                3rd pic. Any labels next to the connectors?
                                • Dblueman
                                  • Nov 2012
                                  • 84
                                  on the cables themselves they are marked PD and PH there is a small label with this marking on it.
                                  Serial NO
                                  202204255
                                  Vd= 60v
                                  Vs= 170.8v
                                  Code AA-01
                                    OK, so you will have to test each pin, red pin on the metal surround around the connector pin, black probe on the chassis of TV, measure on 200V DC range.
                                    • Dblueman
                                      • Nov 2012
                                      • 84
                                      PH from left to right
                                      pin 1 00.8
                                      pin 2 00.7
                                      pin3 - 00.0
                                      pin4 00.6
                                      pin5 -00.0
                                      pin 6 -00.0
                                      pin7 00.0
                                      pin8 -0.00
                                      pin9 -0.00
                                      PD from left to right
                                      pin1 171.9
                                      pin2 171.9
                                      pin3 -0.00
                                      pin4 00.0
                                      pin5 -00.2
                                      pin6 -00.3
                                      pin7 04.8
                                      pin8 -00.2
                                      pin9 10.1
                                        OK, so you have good Vs, but I don't see Vd. Vd goes to the vertical driver boards from the sustain boards, and it's generated on the PSU in most cases.
                                        The plasma panel requires Vd to make the display work though you should still see a faint glow. It is possible it derives the other voltages for the sustain board from Vd instead of Vs.
                                        CN7 is on one of the drivers. Next to it there is a label. What does this label show?
                                        • Dblueman
                                          • Nov 2012
                                          • 84
                                          So far I've found everybody but CN7 where abouts?
                                          I apologize I have to go up and down to the work shop
