Just found an insignia ns-lcd32
+ More Options
Posts
  • keico
    • Oct 2011
    • 52
    ok just found a insignia ns-lcd32 lcd tv that was thrown away.
    After plugging in I see the screen is cracked.
    Was wondering if anyone has a part number for the screen or can provide me with a link to where I can get one.
    Re: Just found an insignia ns-lcd32
    It will be written on the back of the LCD panel i.e. LTA32A0P06 for a Samsung 32" LCD panel. However please note in the vast majority of cases it is not economical to replace the LCD panel.
    • keico
      • Oct 2011
      • 52
      Here is what was on the screen
      k32w0wf0131111437x06n7lr001166
      I can't seem to find anything with this part number
        How about a picture of the back of the chassis?
        • keico
          • Oct 2011
          • 52
          I will make sure I put one up today
          • keico
            • Oct 2011
            • 52
            ok i found the part number CLAA320WF01-SC
              http://www.ebay.com/itm/DYNEX-LCD-PA...-/170830516833
              Probably not worth it to be honest.
              • keico
                • Oct 2011
                • 52
                I agree seems like this particular Model LCD had a lot of problems.
                Do you think I should save the electronic boards and throw out the rest or just throw the who;e thing away????
                  That is what I would do.
                  I just picked up a free 32" Polaroid with a cracked screen. If I had just replaced the LCD it would be no good, because the force which cracked the screen also damaged the power supply and main board (bending both.)
                  • keico
                    • Oct 2011
                    • 52
                    I did plug it in and it did come on, I can even see some of the menu, so I do not think the power supply or any other boards are bad .
                    Question do you think this screen will work in this one
                    http://www.ebay.com/itm/321051150062...84.m1423.l2649
                      The screen must be an -EXACT- match to guarantee it will work, because don't forget you also have mechanical mountings.
                      • keico
                        • Oct 2011
                        • 52
                        Here are some pics
                        • keico
                          • Oct 2011
                          • 52
                          I don't mean to keep bugging you but the one I posted from ebay says it will fit the same model I have
                            OK, so it may work. The LCD panel model is also important because the main board will be programmed for the right panel. Also try the main board with a video signal to see if you get a picture, just in case main board has other issues.
                            • Mr Bill
                              • Nov 2011
                              • 648
                              I think the ebay link you've posted won't work. The ebay link Tom posted in post #7 is an exact replacement for the panel you need. Your current broken panel is a chunghwa panel. The ebay link you posted is a Chi mei innolux panel. So the chances are very slim that it'll work right out of the box. Shop Jimmy is showing 29 different panels for you tv and 17 mainboards if i'm counting correctly. SO the ebay auction you posted is correct saying it'll work for your tv but like Tom has already said if the mainboard isn't compatible with the panel your probably going to be buying a paper weight.
                              I have a CLAA320WA01 panel in my basement but you need a CLAA320WF01 panel. I looked at the datasheets and your panel and mine are pinned completely different. Though you MIGHT be able to cut the LVDS cable and reroute the wires but its a job in itself.
                              • keico
                                • Oct 2011
                                • 52
                                I really appreciate the advice I am getting.
                                I did send the guy message about the panel, because I see that I have 7 connections on one side and on his it might be 8, I think if it is 7 then it just might work.
                                I still am not sure if I will invest or not, just weighing my options right now
                                  Best way to verify is to download the specification of the panel and look at the pin out of the T-CON and the voltage it needs.
                                  • Paul678
                                    • Nov 2011
                                    • 402
                                    Keico, I have a good panel from this same model.
                                    It might work for you. Contact me in a personal message.
                                    • B2L_Repairs
                                      Huawei D15 no power found corrosion damage
                                      by B2L_Repairs
                                      I got a huawei D15 that came in for no power repair. Device charges , charging led flashedms but doesn't turn on. I found corrosion on an IC (ic name is BDJCY1...I can't find out much info about it online). I removed this ic and two pads are corroded but they can be repaired. To my knowledge inductors never short to ground (i might be wrong and please those that are more knowledgeable than me can correct me). I found few inductors short to ground when my multimeter is in beep mode ,indicating a short in the line of those inductors...but I don't know how to go about to find the shorted component...
                                      02-06-2025, 01:05 PM
                                    • Grouickman
                                      Hofmann geodyna 6300 Wheel balancer
                                      by Grouickman
                                      Hi there,
                                      First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                                      Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                                      I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                                      I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                                      03-31-2025, 05:29 AM
                                    • gagarasta
                                      Operating system not found, cannot enter bios or boot to usb
                                      by gagarasta
                                      Hello everyone, I had issues on my laptop acer 4752G
                                      I'm using windows 10 until I decided to install windows 7 because of old hardware limitation, then I just found I cannot access my bios anymore. So far I already try these:
                                      1. On system information its uefi not bios/legacy
                                      2. Advanced restart but there's no uefi setting
                                      3. Try to reinstall my pc using fdd but cannot enter boot selection
                                      4. Press f2 f8 f10 only beep but straight into boot
                                      5. Try reflash bios using fdd fn key+esc+power not success
                                      6. Take the cmos battery off and...
                                      11-05-2023, 11:23 AM
                                    • dropfry
                                      Dead t480s, trying to troubleshoot. May have found something.
                                      by dropfry
                                      Hello. I have a lenovo that will not show any indication of life. No led, sound or anything really. So I took the motherboard out and started testing points according to the advice in this thread: https://www.badcaps.net/forum/showthread.php?t=102409
                                      PU201 is Showing 6v
                                      VREG3/5 show a high value (around 20v) for a split second then drop down very quickly. Hold around 1v but then continue to drop to zero. One is showing .2v.
                                      Fuse PF1 is showing very low voltage (which according to the thread deals with docking and is expected)
                                      09-29-2023, 02:38 AM
                                    • nassimhamdi
                                      Acer aspire V5-591 electronic component not found!
                                      by nassimhamdi
                                      hello
                                      today i have laptop Acer aspire V5-591 DA0ZRYMB8G0 REV: G MODEL: ZRY
                                      the problem of this notbook is powering on but black screen, when i verifing the motherboard i found TWO electronic component not found! AS PICTURES BELOW please help
                                      ,thanks ADVANCED....
                                      08-04-2023, 01:20 PM
