sharp aquos 42. lc-42d43u
  • robbiec16
    • 20
    • us
    I dont know how to post pics feom my phone so I will include a link to my craigslist posting with pictures.
    I just got this tv off of craigslist. After about an hour and a half of watching it the picture turns to fuzziness. The figures are very splotchy and distorted. Their are halos around peoples bodies. Any ideas of what the. Problem is and a fix?
    http://jacksonville.craigslist.org/ele/3541156584.html
    Re: sharp aquos 42. lc-42d43u
    Is it sudden? Or does it slowly occur?
    • robbiec16
      • 20
      • us
      It starts to occur slowly and then got worse quick.
      • robbiec16
        • 20
        • us
        One of the pics I posted was of the TV working an hour before and then one of the outcome
          I doubt it will fix it but this procedure has cured it when it occurs continuously (i.e. straight from power up.)
          http://www.tgohome.com/ServiceManual...epair_tips.txt
          For a Sharp LC-32SD1E.
          • robbiec16
            • 20
            • us
            No it didn't work. Wouldn't even come up with a k....just powers on
            • robbiec16
              • 20
              • us
              Any other way to get into firmware menu?
                Just to check: Does this TV have a power LED and an "OPC" LED?
                • robbiec16
                  • 20
                  • us
                  Yes, the power light is on, the opc light comes on when I turn the option on.
                  • robbiec16
                    • 20
                    • us
                    I'm hoping its not the main board, got any suggestions yet?
                      Just found the SM.
                      http://www.tgohome.com/ServiceManual...&Search=Submit
                      Use in conjunction with:
                      It mentions a service mode, but I can't see anywhere on how to access it??
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Ones I have fixed a 32D43U by tightening the boards mounting screws. They were selling new screws with washers as a kit.
                        Not saying that it's the same issue, just an idea.
                        • randtek
                          • Oct 2011
                          • 280
                          • US
                          refer to my "Factory Resets" thread and try the Sharp reset methods. They will take you into service mode
                          https://www.badcaps.net/forum/showthread.php?t=24809
                          • robbiec16
                            • 20
                            • us
                            Dont really know what to do once in the service mode...the earlier information about doing eepclearb wasnt a menu item nor being able to switch it in to euro version. Anyone think its the physical parts causing the problem?
                              Can we see a picture of the service menu?
                              The service manuals I linked may have more information about reset.
                              Obviously that information I gave is only valid for some Sharps... it probably won't work on yours, though mine looked exactly like the photo, just it was always there.
                              • robbiec16
                                • 20
                                • us
                                Do u want all 26 screens? Or one in particular
                                  Is there an overall menu where they are listed or just one after another? Any sign of any reset options?
                                  • robbiec16
                                    • 20
                                    • us
                                    Its just one after another with no sign of reset.
                                      Found this... any sign of "INDUSTRY INIT"?
                                      Move the cursor to the [INDUSTRY INIT (+Cause)] line.
                                      Using the [VOL+/-] keys, set this item ON and press the
                                      [ENT] key.
                                      • randtek
                                        • Oct 2011
                                        • 280
                                        • US
                                        I believe it is on screen 2/26
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • jonah1024
                                          Sharp Aquos LC-40UG7252E LCD TV burn in?
                                          by jonah1024
                                          Hello!
                                          I'm a few days old into this TV screens repair universe so please bear with me.
                                          Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                          - I did a factory reset as well...
                                          07-16-2024, 04:23 AM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
                                        • foxyUK
                                          Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                          by foxyUK
                                          Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                          The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                          There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                          10-22-2024, 10:27 AM
