i just picked up a 60" lg it is a 60pc1d-ue . (pdp60x60000)
when i try to power it on you hear it click to try to power up , then you hear it start the recyling series of clicking. i know power board right? my gut is the sub power board because the fuse holder had the fuse missing and a wire solidered across it. i took the sub power board out looked at the bottom side(green side) it looks like someone tried to put new capicators in or some went bad ,,the solder job did look too great!! i have a capicator repair kit to install to see if this will help or not. everything else looks ok by a visual inspection! i have a multi meter,,but limited knowledge on using, so work with me and help walk me through this please. i will try to post a couple good pictures when i get time! can i put a t6.3 fuse in the sub board to power it up just for the mean time ,,the t15 fuse is missing and i don't have a extra one? i reheated the areas that had the bad solider spots to see if maybe that would help, if not then i will put the repair capicator kit in! any help out there,,??
