lg 60 pc1d recycles clicking
  • tocold4u2
    • Dec 2012
    • 284
    • usa
    i just picked up a 60" lg it is a 60pc1d-ue . (pdp60x60000)
    when i try to power it on you hear it click to try to power up , then you hear it start the recyling series of clicking. i know power board right? my gut is the sub power board because the fuse holder had the fuse missing and a wire solidered across it. i took the sub power board out looked at the bottom side(green side) it looks like someone tried to put new capicators in or some went bad ,,the solder job did look too great!! i have a capicator repair kit to install to see if this will help or not. everything else looks ok by a visual inspection! i have a multi meter,,but limited knowledge on using, so work with me and help walk me through this please. i will try to post a couple good pictures when i get time! can i put a t6.3 fuse in the sub board to power it up just for the mean time ,,the t15 fuse is missing and i don't have a extra one? i reheated the areas that had the bad solider spots to see if maybe that would help, if not then i will put the repair capicator kit in! any help out there,,??
    Re: lg 60 pc1d recycles clicking
    I would be considering the Y-sus or Z-sus on this model, as the xxPCxD plasmas have poor reliability with either board.
    • tocold4u2
      • Dec 2012
      • 284
      • usa
      thanks for the info , the next time i try to power it on i will unplug the x or the y board and c what happens.!
      • tocold4u2
        • Dec 2012
        • 284
        • usa
        should i resoilder the wire across the fuse holder cause i cant find a fuse (t15a)
        all the other fuses are smaller? any help
          Use a 10A fuse for now, and keep a small collection, because it will blow them after some time. Find a 15A fuse later.
          • tocold4u2
            • Dec 2012
            • 284
            • usa
            i tried to power up the tv with just the power supply board and the sub board hooked up . i got only 1 click, then i tried with the y main and the plug with the v5 i got the cycling clicks. i then tried the x main and the v 5 plug and y main still got the cycling clicks . i also spoke to previous owner ,,he said that the large power board was hooked up to a "ultrasonic" and that it checked out ok. i think the capicator repair kit that i ordered will be here tomorrow, atleast i hope!!
              I do not know what an ultrasonic is or would possibly do.
              • tocold4u2
                • Dec 2012
                • 284
                • usa
                i dont know either, thats just what he told me. i will check out the power board and the sub board , then go from there. maybe i can find a repair manual on line.
                • tocold4u2
                  • Dec 2012
                  • 284
                  • usa
                  i put a repair kit on the (sub power board) i still have the clicks , but their not as often now?? i did notice a resistor on the large power board had a chip out of it or it went bad,, someone put it on the board ,and put it on the wrong side lol,,,so now i know that the lg and smaller board was messed with. i will need help on finding a new resistor, i will put a picture of it up later , i think the number on the board is r995 on the powersupply board eay32961801.
                  • tocold4u2
                    • Dec 2012
                    • 284
                    • usa
                      Measure the Vs voltage with and without the Y-sus and Z-sus connected.
                      • tocold4u2
                        • Dec 2012
                        • 284
                        • usa
                        this is one more pic, there is a burnt spot under that resistor . anyone know what size or where i can get another one from ?
                          Is that on the bottom of the board?!
                          • tocold4u2
                            • Dec 2012
                            • 284
                            • usa
                            yes that is. i think someone was trying to replace parts ???
                              Is there a footprint marking for it on the top?
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                A low ohm resistor bridging the primary to the secondary?! Is that not safe?!!!
                                Muh-soggy-knee
                                • tocold4u2
                                  • Dec 2012
                                  • 284
                                  • usa
                                  im gona say that the part was put in wrong by previous owner, i tested vs and va they were both low vs 160 should of been 190 va 30 should of been 60 the still has the recycling clicks but its not as often as before. it is kinda hard to get a good reading when its doing that!!
                                    Check your mulimeter's battery just in case.
                                    • tocold4u2
                                      • Dec 2012
                                      • 284
                                      • usa
                                      i think there is a short in either the power board or the sub power board.
                                        That would cause near zero output voltage.
                                        Please verify your multimeter battery.
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                        • jshhh
                                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                          by jshhh
                                          Hi guys,
                                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                          Anybody know how to remove this type of fuse?
                                          (The fuse is toward the bottom of the image labeled F2)...
                                          06-17-2025, 01:35 AM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
