lg 60 pc1d recycles clicking
  • tocold4u2
    • Dec 2012
    • 284
    • usa
    Re: lg 60 pc1d recycles clicking
    i replaced the battery in multimeter n i will check again
    • tocold4u2
      • Dec 2012
      • 284
      • usa
      va was36 should of been 60 vs was 187 should of been 193
      • tocold4u2
        • Dec 2012
        • 284
        • usa
        thats after i replaced battery in meter,,,the numbers drop quickly when it starts to cycle the clicks
          Those readings are good.
          • tocold4u2
            • Dec 2012
            • 284
            • usa
            retested 187 vs va was 35
            • tocold4u2
              • Dec 2012
              • 284
              • usa
              #26
              that was after i switched battery
                Wait you do not have 60V on Va?
                • tocold4u2
                  • Dec 2012
                  • 284
                  • usa
                  #28
                  is there a way to run a jumper to bypass the cycling clicks and get the tv to come on ? va was 35 vs was 187
                    Vs is good but I suspect something is wrong with the part of the PSU that supplies Va.
                    The clicking may be due to the PSU detecting a low Va or some other problem that hasn't been fixed yet.
                    Is there an adjustment point for Va? Can you adjust it at all?
                    • tocold4u2
                      • Dec 2012
                      • 284
                      • usa
                      #30
                      any clues as to what to check,,,could it be the large cap 68 uf x 450 v thats the only cap that wasent replaced because one wasent in the repair kit ? or could it be one of the resistors (white box) ??
                        I doubt it for now.
                        You need to get Va to the right voltage so first try adjusting it, it could have simply drifted.
                        • tocold4u2
                          • Dec 2012
                          • 284
                          • usa
                          #32
                          yea but with the power clicking back off or into safe mode can u adj the va ? i was thinking its something that makes the va a resister or something shorted ??
                          • tocold4u2
                            • Dec 2012
                            • 284
                            • usa
                            #33
                            any clue where i can get the schematics for this model and download it free?? that would help alot !!
                              LG don't publish schematics, except sometimes for their main boards, but those are rare failures.
                              • tocold4u2
                                • Dec 2012
                                • 284
                                • usa
                                #35
                                if the va didnt drift could this damage something more ? thats the last thing i want to do!!
                                i will c if i can adjust the va .
                                  You can adjust it with boards disconnected.
                                  The risk is adjusting Va too high which can damage the plasma panel, however, this only happens if the connection to the panel is made (via the data drivers at the bottom of the screen.) Unplugging the Y-sus and Z-sus connectors will disconnect the data drivers and plasma panel.
                                  • tocold4u2
                                    • Dec 2012
                                    • 284
                                    • usa
                                    #37
                                    so just disconnect the two wire harness that goes over to the y-sus board and i should be safe ??
                                      And the one going to the Z-Sus.
                                      • tocold4u2
                                        • Dec 2012
                                        • 284
                                        • usa
                                        #39
                                        when i disconnect those wire hsrness and try to get a reading with the multi meter there is almost no reading ??
                                        but when their pluged in i get a reading ??
                                          You need to measure on the power supply end.
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • jshhh
                                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                            by jshhh
                                            Hi guys,
                                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                            Anybody know how to remove this type of fuse?
                                            (The fuse is toward the bottom of the image labeled F2)...
                                            06-17-2025, 01:35 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
