phillips 42pf7520d/10 plasma
  • ron77
    • Dec 2012
    • 63
    • united kingdom
    fault-protection activated.green led on almost continuosly.Searched badcaps forum for similar problem-no matches. Set about repair and found replacing capacitor 2508 in 9 volt standby circuit cured problem. The capacitor was 100mfd 16 volts. It read 92 mfd on capacitance meter. After this fault i ordered an esr meter.The capacitor did respond when heated.Psu number 3104-328- 42741 Psu number 3104-328-42742 is almost identical.
    Re: phillips 42pf7520d/10 plasma
    Thank you for the repair feedback.
    • Techstar
      Tv Restoration
      • Dec 2012
      • 122
      • United Kingdom.
      Yes an esr meter is the most useful thing to own next to a multimeter.
      The one from peak electronics in buxton is superb , i have the one with
      audio beeps which is a nice feature. The dual readout for capacitance and
      esr is just fantastic. Without an esr meter any technician will waste time.
      I used to miss lots of faulty caps years back when i just used a capacitance meter.
      • ron77
        • Dec 2012
        • 63
        • united kingdom
        Tom 66 and Techstar. Thanks for your comments. Did not expect a response as no troubleshooting to do.Something I wanted to tell Tom. Had two Sharp LC32D44E/BK around for some time.Saw your diagnosis on forum and those two sets now working. Thanks, Ron
          Red/Green/Blue cloudy pixels? Yes, I am very proud of that fix. I want to get more of similar models. Probably the easiest fix in the world. Bought TV, took it apart, found Sharp Service Tip, and it was working...
          • ron77
            • Dec 2012
            • 63
            • united kingdom
            Tom 66-In my last post tried to keep words to a minimum.Should have mentioned what fault my televisions had.My sets had CCFL faults. Your work regarding my sets, I thought was very good.Cloudy pixels i have no knowledge of that fault at all.Does sound like a very interesting fault.
            • speedypro
              • Feb 2013
              • 561
              Nice find! Where in the UK I get the cap from? I've searched all over the web and found few in America.
              Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
              • chth96
                by chth96
                03-09-2024, 10:03 PM
                12-31-2023, 06:04 AM
              • jorpec
                by jorpec
                Hi
                Thnaks
                01-23-2023, 10:37 AM
                Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                12-14-2023, 07:45 PM
              • Uranium-235
                Phillips 50PF7321D/37 Plasma slow reboot
                by Uranium-235
                Customer said if he keeps it on for a long time, turns it off, and later back on, it takes 10 minutes to get to proper brightness. Is this just a cap issue? I didn't have time to take it apart I was just there to drop a repaired laptop off
                12-27-2021, 09:14 PM
