sanyo no back ligth
  • ealequi
    • Dec 2012
    • 212
    • usa
    #41
    Re: sanyo no back ligth
    Originally posted by budm
    Service manual:
    I did not have a chance to look at it yet.
    this address is not good. it frezze your computer
      Works fine for me. What browser do you use?
      • ealequi
        • Dec 2012
        • 212
        • usa
        #43
        explorer
          Try Firefox or Chrome; IE doesn't work well with elektrotanya.
          • ealequi
            • Dec 2012
            • 212
            • usa
            #45
            By the way, Can I get the picture of this connector so I can clearly see the label on the pins? Right now the wires are blocking out the labels.
            ok. sorry i was busy today
            • ealequi
              • Dec 2012
              • 212
              • usa
              #46
              • ealequi
                • Dec 2012
                • 212
                • usa
                #47
                i send the pic. you asked, pls help me. thanks.
                • ealequi
                  • Dec 2012
                  • 212
                  • usa
                  #48
                  can anyone help me with my sanyo dp42849
                  • MisterD
                    • Oct 2012
                    • 668
                    Can you please move your camera around to the other side of this connector, you may have to unplug the connector so we can see the voltages printed on the board, the wires are in the way. please look at the area where the red circle is drawn around it. that's what budm is asking to see up close without the wires in the way. Thanks.
                    Please Go to Post 39 and look at the picture there, you will see the red circle around it, I don't know why my re-post of this picture is not working.
                    • ealequi
                      • Dec 2012
                      • 212
                      • usa
                      #50
                      • ealequi
                        • Dec 2012
                        • 212
                        • usa
                        #51
                        is this pic. good?
                        • MisterD
                          • Oct 2012
                          • 668
                          It's blurry but is what we need to see, can you try again to get a clearer picture of it. Thanks.
                          Looks like going from left to right.. GND, STB5V, 12V and Line Off
                          • ealequi
                            • Dec 2012
                            • 212
                            • usa
                            #53
                            yes
                            • ealequi
                              • Dec 2012
                              • 212
                              • usa
                              #54
                              • ealequi
                                • Dec 2012
                                • 212
                                • usa
                                #55
                                is this one good?
                                • MisterD
                                  • Oct 2012
                                  • 668
                                  is this one good?
                                  Yes, very good. thank you. hopefully budm will be back on here to help you.
                                  • ealequi
                                    • Dec 2012
                                    • 212
                                    • usa
                                    #57
                                    i be here.thanks
                                    • MisterD
                                      • Oct 2012
                                      • 668
                                      i be here.thanks
                                      I think there's a good possibility that your Main Board is bad and not sending the correct signal to the power supply to turn on the Backlights since that voltage is too low on BL_ON only 1.3V and should be closer to 3v, but please wait for more replies to see what others think.
                                      • selldoor
                                        Slow Learner
                                        • Dec 2010
                                        • 7870
                                        #59
                                        When you were taking the measurements did you have everything connected and
                                        a source - generally recommend a dvd then you can tell it is playing by the sound.
                                        Even though you cant see the picture can you see the on screen menu?
                                        • ealequi
                                          • Dec 2012
                                          • 212
                                          • usa
                                          #60
                                          ok. i wait
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
