sanyo no back ligth
  • ealequi
    • Dec 2012
    • 212
    • usa
    Re: sanyo no back ligth
    Originally posted by MisterD
    with the tv powered on, check the voltage on the small white connector that has the 3 black and 1 white wire, it's near the edge of the power supply board, I see it is labeled BL_ON, hook a volt meter with the black probe to chassis ground and use the red probe at the connector making sure it touches the metal part where the wire goes in, set your meter to DC Volts, report the voltage reading back here.
    before anything i gave you the wrong model number, the rigth model number is dp42849
    Ok. went i use the fluke i set it on automatic and it show this: stb5v-115ac so all the oder. when i use the craftman it show this: STB5V-42.7 GND 39.4 BL_ON 41. BL_DIM 41.6 WISH IS THE RIGTH READING?
    • ealequi
      • Dec 2012
      • 212
      • usa
      stb5v 9.4v
      gnd 8.7
      bl-on 9.2
      bl-dim 10.1
      • ealequi
        • Dec 2012
        • 212
        • usa
        stv5v 9.4v
        gnd 8.7v
        bl_on 9.2v
        bl_dim 10.1v
          Something is wrong with your meter if 5V measures 9.4V.
          • MisterD
            • Oct 2012
            • 668
            Make sure you have the black negative wire hooked to the metal chassis of the TV, are the black and red wires plugged into the correct ports on the meter itself? can you post a picture of the meter with the two wires plugged in? and also show where you have the dial set? Thanks
            • ealequi
              • Dec 2012
              • 212
              • usa
              #26
              • ealequi
                • Dec 2012
                • 212
                • usa
                #27
                look that i was putting it in the wrong ground. in the black cables there was no reading
                • MisterD
                  • Oct 2012
                  • 668
                  Is the connector where you measured labeled CN6? List any voltages you are getting.
                  NC = ? V
                  BL-On = ? V
                  BL-Dim = ? V
                  5V STB = ? V
                  of course Gnd is Ground and will not have any voltage.
                  • ealequi
                    • Dec 2012
                    • 212
                    • usa
                    #29
                    yes
                    • ealequi
                      • Dec 2012
                      • 212
                      • usa
                      #30
                      NC = ? V
                      BL-On = ? V
                      BL-Dim = ? V
                      5V STB = ? V
                      bl_on 1.3
                      bl_dim 3.2
                      5vstb 5.v
                      • ealequi
                        • Dec 2012
                        • 212
                        • usa
                        #31
                        bl_on = 1.3
                        bl_dim = 3.2
                        5vstb = 5.v
                          OK, suspect the inverter portion of P/S. As it is being told to turn on and brightness is set correctly.
                          There is usually a separate fuse on the combo boards.
                          • ealequi
                            • Dec 2012
                            • 212
                            • usa
                            #33
                            i did not find any burned fuse
                              Can you get a picture of the whole of the bottom of the power supply, green side?
                                "bl_on = 1.3" that does not look right, I expect >2.5V.
                                • ealequi
                                  • Dec 2012
                                  • 212
                                  • usa
                                  #36
                                  what that mean?
                                    It means the signal from the main board is too low to turn on the baclights inverter.
                                    I believe someone in this forum has the service manual for this dp42849.
                                    Any luck on posting the pictures of all the boards so we can see how they are connected together?
                                    • ealequi
                                      • Dec 2012
                                      • 212
                                      • usa
                                      #38
                                      i can't belive you still anwering peoples question. well apreciated. i will post the picture tomorrow morning. I am very gratiful. thank you.
                                        By the way, Can I get the picture of this connector so I can clearly see the label on the pins? Right now the wires are blocking out the labels.
                                          Service manual:
                                          I did not have a chance to look at it yet.
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
