sanyo no back ligth
  • MisterD
    • Oct 2012
    • 668
    Re: sanyo no back ligth
    Originally posted by ealequi
    what about the wire that he want fromstb5v on cn2 to stb5v oncn6?
    You already have this done.... connect the resistor between PIN1 (5vstby) and pin3 (BL_ON) of CN6. So leave the resistor in place. Now just cut the one wire into like I said above, this way it is no longer connected to the mainboard, then follow the steps I said by turning on the TV and see if you have backlights.
    I don't think you have to do anything with CN2, he's just saying you have 2 different 5VSTBY Sources.
    • MisterD
      • Oct 2012
      • 668
      Here it is again
      He is saying plug connector CN6 back in and to just cut the one BL_ON wire into that's on CN6, leave it at least 3 inches long at the end going to that connector (CN6) so you will be able to splice it back together later, Leave the resistor where it is and turn on the TV and see if you now have backlights.
      • ealequi
        • Dec 2012
        • 212
        • usa
        #123
        same thing. Get audio,video but not lit-up
        • MisterD
          • Oct 2012
          • 668
          With the TV turned on check the voltage now at BL_ON on connector CN6 and see what it is.
            You will put the cn6 connector back in place, but cut the BL_ON wire, leave it long enough so you van splice the wire back together once we fix the problem, that is how I troubleshoot misterd philips TV.
            • ealequi
              • Dec 2012
              • 212
              • usa
              #126
              3.7v
              • MisterD
                • Oct 2012
                • 668
                3.7v
                Okay, did you cut the BL_ON Wire on CN6 ?
                • ealequi
                  • Dec 2012
                  • 212
                  • usa
                  #128
                  yes
                  • MisterD
                    • Oct 2012
                    • 668
                    Bud, he has 3.7V at BL_ON with the 1K resistor in place and he has the wire cut now.
                      OK, so now you do get the LED to be on, but still no backlights?
                      • ealequi
                        • Dec 2012
                        • 212
                        • usa
                        #131
                        There is a misunderstanding. Is the back ligth went you able to see the video but is dark? That is what i have. I need the brite ligth wish i imagine that is the led. The tv still doing the same thing that make me come to the forum
                        • MisterD
                          • Oct 2012
                          • 668
                          The backlight (a white light ) can be seen through the holes in the metal chassis from behind with the back off the TV, the LED he is referring to is the little light on the front of the tv plastic case. Do you have that white light?
                          This is from your first posting and it sounds like the backlight is not working because you are using the flashlight method to see video.
                          "I have a sanyo dp42647 when i turn it on there is a black screen with sound. If i put a flashligth close to the screen i can see the video. Any idea?"
                          • ealequi
                            • Dec 2012
                            • 212
                            • usa
                            #133
                            ok. i missing the backligth. i have video, sound led i green but no backligth.
                              Well at this point we have verify that the backlights are not working not due to the main board problem but due to your bad power supply/inverter combo board problem or due to bad lamps.
                              We do not have the diagram to troubleshoot down to component level, but I want to make sure that you DID NOT EVEN SEE THE SCREEN FLASH for seconds? The problem is now down to either bad board or bad lamps, with one or two bad lamps I will expect to see the screen lights up for seconds then shutdown if the inverter board is OK, but if the inverter board is bad it may not even try to light up the screen at all, this is where you have to make the decision if you will want to try ordering the new power supply-inverter board to find out if it will fix the problem or not.
                              • MisterD
                                • Oct 2012
                                • 668
                                deleted.
                                • MisterD
                                  • Oct 2012
                                  • 668
                                  Before he added the resistor his readings were:
                                  bl_on = 1.3
                                  bl_dim = 3.2
                                  5vstb = 5.v
                                  Before making any changes BL_ON was only 1.3V, then after adding the resistor BL_ON was 3.7V and still no backlights. If there is a problem with the inverter board or bulbs why would it be at 1.3V. since the 1.3V would still be there and he is adding 5V through the 1K resistor I would think it would be higher than 3.7V, is it possible there is a shorted component on the inverter section or bad lamps pulling that voltage down?
                                    That 1.3V can be the main board is not pulling high enough, there is voltage divider resistoirs that the 1K is feeding, that is why it will never be at 5V, 3.7V is more than enough to drive the transistor. That 1.3v reading was generated by the main board, since we cut that line open, all he now is the 5V feeding through the 1K resistor.
                                    See post 86 for typical receiving circuit.
                                    If he trace that BL_ON line, there will be a resistor connected to that pin.
                                    Without the diagram of of the board, we cannot check for test points.
                                    • MisterD
                                      • Oct 2012
                                      • 668
                                      I see a lot of variances of this power supply board for your model, if you do order one BE VERY CAREFUL to get the part number off of the white bar code sticker and not the pc board itself, I see some on ebay and also some places on ebay repairing your board if you send it in. you can also check shopjimmy.com to see what they have.
                                      • lorins_core
                                        BlackSmith
                                        • Dec 2012
                                        • 551
                                        • Philippines
                                        #139
                                        Ok i Suggest. Would you try to Resolder. fist the Main Power Supply?. then Try if have no Luck. Try The secondary. they have a Old Solder lead at the Main Board. I Suggest Only. Good Luck Friend.
                                          OK. please check the fusible resistor R322 that feed the B+ to the inverter transformer driving circuit.
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 08:10 PM
                                            HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
