55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
  • KongRubix
    • Dec 2012
    • 24
    Re: 55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
    The space of the room is such that a 55-60 inch is appropriate (and it is also in line with the guidelines I've seen posted elsewhere on the net for HDTV's). Any smaller and it gets awkward, IMO (it's for the main living room across from our couch).
    PS: Added a Samsung above, btw, although I believe I recall you saying to avoid those.
    Thanks for the amazingly fast response!
      If you buy any TV, do not buy this one. I have seen too many Samsung TVs to know they cut costs which ultimately severely shortens the lifespans of their products.
      • KongRubix
        • Dec 2012
        • 24
        I find myself arguably torn over the plasma vs. LED rivalry. I like the way LED's look (bright colors, none of the "dithering" with plasmas) but plasmas tend to be cheaper from what I see and I've heard from multiple sources that they are still superior (which is why we bought the Panasonic plasma to begin with). I may just need to go back and see your earlier reply, but what is the primary reason for choosing plasma over LED? Is it simply that the dithering does not bother?
        Even from across the room, I can see the dithering (if I am using the correct word -- the way lines aren't crisp but have a sort of pixellated flux of squares that dance around).
        I believe it was this response:
        Originally posted by tom66
        Avoid Samsung if you buy an LED TV (sorry... but Samsung make poor quality TVs that look pretty on the outside and have a great picture until they die 2 or 3 years later.) But to be honest, LED isn't all it cracked up to be anyway. The picture quality is only slightly better than a conventional LCD and probably worse than a good plasma; and the reliability is generally worse.
        I'd personally recommend a plasma... maybe an LG if you don't want a Panasonic, even though Panasonic do have some of the best build quality, I'm seeing more and more issues with them. Not sure if it's because they're more popular, or just poorer built. They've definitely cut down to make TVs cheaper, but at least they still use good components and the build quality is second to none.
        But I still think it's worth repairing.
          Plasma vs LED/LCD:
          • Longer lifespan (typically) 100,000 hr vs 20,000~40,000 hr for LED and 60,000hr for LCD
          • Higher contrast ratio (>30,000:1 typical) vs 2000:1 -- this will not necessarily be apparent in a bright showroom
          • Greater colour depth (12-bit or 14-bit) vs 8-bit/10-bit for LED/LCD
          • Sub millisecond response time (good for fast action) vs 5~15ms for LED/LCD
          • Greater "moving picture resolution" of typically full display (1080 lines) vs typical 500~800 for LED/LCD -- basically indicates how good display is at showing moving action.
          • Lower cost
          LED/LCD vs Plasma
          • Higher brightness typically
          • No dithering (but depends on the model of plasma TV)
          • Lighter, thinner
          • More energy efficient (about 60% of the energy usage of a typical like-for-like plasma)
          Contrast ratio really is the killer. A plasma display is capable of very deep blacks. The thing is, when the showroom is lit up very brightly, it can make the picture on a plasma look much more washed out, so you lose that advantage. At home, with normal lighting, it'll look much better, and in a dark room, it will look even better.
          And the source matters too. More than likely, Costco are just feeding all the TVs off a crap composite video source from a DVD player. This'll make for all sorts of picture noise. Sometimes an LCD or LED-LCD can hide this due to the inherent blur in the display panel, but you'll lose detail on true HD sources.
          • KongRubix
            • Dec 2012
            • 24
            Will keep that in mind -- thanks again. We'll probably pull the trigger on a purchase soon (odds are another plasma, haha). Trying not to let that Panasonic debacle unfairly bias future purchases.
            • retiredcaps
              • Apr 2010
              • 9271
              #46
              It's a good TV. I would go for this one. It will beat an LED TV hands down, and it's cheaper. No brainer.
              With a price of $799.99, I suggest spending the extra $59.99 to extend the total warranty to 5 years. That is only $20/year after the "standard" 2 year Costco warranty.
              --- begin sig file ---
              --- end sig file ---
              • johnboy1313
                • Nov 2012
                • 1959
                So to speak to your original problem, I don't know if it's exactly like my Panasonic Viera 42" but try this troubleshooting manual. Specifically, page 4.
                Check out this link
                https://www.badcaps.net/forum/showthread.php?t=24894
                • enkidu12
                  • May 2013
                  • 13
                  Hello!! I too have a TC-P55GT30 with the 7 blinking lights. I've reviewed this entire thread and follow all the steps suggested. Unfortunately, I'm not very skilled with testing specific components so I just decided to replace boards. I started with replacing the SD & SU boards. (Found them pretty cheep on eBay.) I still have the same 7 blinking lights. I saw on a youtube video that when the SC board ribbon is disconnected the 7 flashes goes to 8 flashes and this indicates that the SC board is bad. Does anyone have the same opinion as this? I didn't pay a lot for the SD & SU cards but the SC card is a bit more and I want to make sure I'm doing the right thing first before I make the purchase. Here is a link to the youtube video I watched.
                  http://www.youtube.com/watch?v=uNFke...-a33eg&index=7
                    It should go to 6 flashes if SC is unplugged. That being said, we have found a lot of buffer boards off eBay dead on arrival due to them being removed from cracked screen plasma TVs. (The cracked screen shorts out the board if it is powered up during or after it is cracked.) Post a picture of the board; we should be able to show you how to test.
                    • enkidu12
                      • May 2013
                      • 13
                      Ok. Here is a photo of my recently purchased and installed SD & SU boards and my old SC board. Again, the video that I watched said that if you unplug the ribbon that is found in the top right corner of the picture on the SC board and the tv blinks 8 times the SC board is bad. By what I've read on your posts, Tom, you know what your talking about so I'll take your advice.
                      Also, I'm not sure how to post a picture so I just added it as an attachment.
                        8 blinks is SS board. While an SC board fault can cause 8 blinks mis-detection, it is much more rare compared to 6 blinks with SC removed. You should always get 6 blinks with SC removed. If the SC is bad, you can get either 6, 7 or rarely 8 blinks.
                        As for testing the SU and SD, you will need a digital multimeter, do you have one?
                        • enkidu12
                          • May 2013
                          • 13
                          I do. It's saved my in the past from buying a new dryer when a $5 part went bad. Lol.
                            OK, remove the buffers from the set.
                            Follow my video here:
                            https://www.youtube.com/watch?v=51SZsfH60EY
                            For your GROUND (the probe that does not move) use the screw points which should be marked HV DANGER.
                            • sordids999
                              • May 2013
                              • 2155
                              • uk
                              #54
                              Hey tom can i test this board just like in your video ?
                              removed from my cracked plasma screen want to test it before i give it to my m8
                                Yes, just ensure it is disconnected from the SC board, large lefthand board.
                                • sordids999
                                  • May 2013
                                  • 2155
                                  • uk
                                  #56
                                  ok thanks would there be a chance the sc board has shorted due to it being in a cracked screen also ?
                                    Usually on these SC survives.
                                    • enkidu12
                                      • May 2013
                                      • 13
                                      Ok, Tom. Assuming I did this correctly, neither my old or newly purchased SD / SU boards have continuity. My multi-meter never goes off 1. I checked ever pin where the ribbons attached and got the same result. I've attached a photo to make sure that I've placed the leads in the correct spots.
                                        Are you testing all outputs? Each pin on those connectors drives one line on the plasma display panel so you need to test all 1080 lines. Does your meter have a beep functionality? Test it by touching the probes together.
                                        • enkidu12
                                          • May 2013
                                          • 13
                                          Yes I placed the leads together to ensure that it was working properly. When I did this the meter went to 0. I also did test all the pin connectors on both set of boards. I'll go back over them again to make sure I didn't miss any.
                                          • bialag
                                            Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                                            by bialag
                                            I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                                            Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                                            03-25-2025, 05:56 PM
                                          • Audeze
                                            Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                            by Audeze
                                            I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                            Does...
                                            10-06-2024, 08:54 PM
                                          • badcappo
                                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                                            by badcappo
                                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                            Diode type G972s6 - D101 with a short
                                            Mosfet 06N90E - Q301 shorted
                                            Fuse T5AH 250V - F103 blown
                                            Diode D301 shorted
                                            Relay DG1U-17VDC II - RL001 blown
                                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                                            11-24-2024, 11:27 AM
                                          • domix
                                            43pus6401/12 - no picture, blinking ambi lights
                                            by domix
                                            Hello i have 43pus6401/12.
                                            After turn on red light slowly blinking and ambilight blinking randomly, different colors fadein/out, etc
                                            Screen is black, no backlight. Caps look normal. I didnt measure it, I forgot my multimeter in another car.
                                            Any common issue?
                                            Thanks...
                                            05-17-2022, 04:35 AM
                                          • crewdog
                                            Hp 15-dy2087nr white lights blinking
                                            by crewdog
                                            Board DAOP5HMB8F REV F
                                            Model OPSH
                                            No bios battery on board
                                            Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
                                            Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
                                            and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
                                            Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
                                            10-25-2023, 03:08 PM
