52LG50 Has Mind of its own
  • Lireb93
    • Dec 2012
    • 20
    TV is about 4 yrs old, and never had a problem, that is until now. You go to turn it on, with remote or by hand, and it comes on, off, on, off, ect for what seems like an eternity but then comes on and works just fine. Then when you go to power it off, sometimes it works and sometimes not. Have had 2 different technicians look at it and they are saying it is either the main board, or the power supply board. Would like to repair myself if at all possible, so any suggestions would be greatly appreciated.
    Re: 52LG50 Has Mind of its own
    My first consideration would be the power button itself getting stuck (not turning off here is a clue), but LG do also have lots of problems with bad capacitors.
    There's a board for the buttons usually. Try locating this and unplugging it, then use the remote. Does it still encounter problems?
    • Lireb93
      • Dec 2012
      • 20
      At work now, but will try later, probably tomorrow and let you know.
      • kartwood
        • Dec 2012
        • 18
        Consider replacing the Front Panel PCB assy. It may be something like: EBR42597903 and usually quite reasonably priced.
        been down that road several times....
        • Lireb93
          • Dec 2012
          • 20
          Found the board for the on/off button. Unplugged both connectors and tried remote, which nothing happened. Shouldn't one be plugged in and other not and then try remote? One lead goes to the buttons on side of the TV while the other I believe goes to the main board.
            Maybe the on-off button board has the IR sensor on it? In which case unplugging it will mean you won't be able to turn the TV on. You may just need to replace the board.
            • Lireb93
              • Dec 2012
              • 20
              So you believe it to be that board?
                It would be my first check point.
                • Lireb93
                  • Dec 2012
                  • 20
                  My wife said that while the TV was on, she unplugged it from the wall and took the switch completely out, plugged it back in and it still did the same thing, on,off,on,off,ect. So if that is the case, what next, the main board?
                    What switch are you talking about? The plug switch, one on the TV, or something else?
                    • Lireb93
                      • Dec 2012
                      • 20
                      The on/off button board that has the IR sensor on it. (EBR42597903)
                      • Lireb93
                        • Dec 2012
                        • 20
                        I took the switch and the main board out. Checked the connections, blew the dust out and put back together. Seemed to work fine until last evening, and it started on and off again. My wife seems to think that it is being interrupted by the signal from the house phone. Is that possible, and if so, wouldn't that be the switch because it has the sensor attached?
                          I doubt it would be related to a phone, cordless or not.
                          Since you cleaned the switch and it worked, the switch still has contamination, it just needs either more cleaning or to be replaced.
                            Any pictures of the board?
                            • Lireb93
                              • Dec 2012
                              • 20
                              The Main Board?The P/N is EBU41909802. Nothing seemed to be out of place as far as I could tell. No hot spots, or broken connections that I could see. Have had 2 different repairmen out and they both said it was more than likely the main board because it probably got an electrical surge through the HD cable. Should I just go ahead and replace the main board and the on/off switch?
                              • Lireb93
                                • Dec 2012
                                • 20
                                Changed out the switch and it is still cycling on and off. Would it be the main board or the power supply next?
                                  Have you done a service reset?
                                  MENU on remote and MENU on TV at same time for 5~10 seconds, then find reset option and select.
                                  • randtek
                                    • Oct 2011
                                    • 280
                                    • US
                                    If the problem still occurs with the Function Switch board disconnected at the main board, the main board is your problem. I have had this type of problem on several LG sets, and it can be caused by either the Function Switch CBA or the Main. This is not a power board issue.
                                    • Lireb93
                                      • Dec 2012
                                      • 20
                                      Attempted the service reset, and after the 5-10 seconds, the prompt on the screen for password came up. I entered the password and it went to a screen that I never seen before. Did not however find a reset. Is it on the remote?
                                        What is the password?
                                        Never heard of that before on an LG...
                                        It may be buried in one of many menus.
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
                                        • N3Star
                                          ASUS ROG G15 G513QY random freezes
                                          by N3Star
                                          My laptop recently started freezing randomly - it usually freezes after a few minutes, sometimes after 2, other times 10 minutes.
                                          So far I kind of ruled out software problems, as the problem persists on live booted Linux, installed Windows and also while installing Windows. My first thought was that it was overheating, so I checked the temps and they are fine, as You can see on the screenshot, never the less I opened it up and reapplied LM on both cores, also using some more thermal putty on the VRM, obviously didn't help.
                                          While live booting Linux it usually freezes...
                                          Yesterday, 02:48 PM
                                        • brithepi2k
                                          Toshiba 65QA5D63DB - Dead EMMC
                                          by brithepi2k
                                          TV has broken down, it started with what I suspect was a bad EMMC (tv stays on red standby and doesn’t respond to remote). I tried a hitachi board with the same connections and the tv powered up with the hitachi logo and double screen (this was the test to check if a new main board would work). I bought a new board but I’m now getting duplicate image which I suspect is because the panel software on the replacement board is different to mine?
                                          what’s the next step? I tried using ChatGPT Premium (AI) to help me however I tried downloading the .pkg file it told...
                                          11-08-2025, 02:51 PM
                                        • madscientist750
                                          Replacing electrolytic caps by solid caps on old motherboards
                                          by madscientist750
                                          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                                          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                                          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                                          10-19-2025, 06:10 AM
                                        • fixpcuyst
                                          HELP!! Asus ux363ea Zenbook 13 problem with usbc controller
                                          by fixpcuyst
                                          Hi guys, I'm having a problem with this Ux363EA motherboard. I'm here to tell you:
                                          A few days ago, a client brought me this ZenBook 13 with a completely burned-out USB port, including the charger. Upon inspecting the motherboard, I found a lot of sulfate everywhere and a small explosion on the USB controller and the surrounding area (I've attached photos).
                                          The laptop turns on and works without problems, but it doesn't charge (obviously), nor does the USB port, which is healthy (obviously, the USB controller is burned-out).
                                          I'm attaching photos and I'll ask you how I can...
                                          10-15-2025, 10:58 AM
