Sense Model 51-32 LCD Stuck in Standby
  • davuk1972
    • Dec 2012
    • 6
    • United kingdom
    Hi
    I've aquired this broken LCD TV,
    Plugged in Standby lamp is on and tring the remote or standby switch does nothing. There is a voltage change from the switch pack to the main board when buttons are pressed
    Checking the PSU, I had 4 bulged Caps which I have replaced.
    Testing the output voltage of the PSU
    Connector to the Invertor
    4xGrounds
    4x23.8 Volts
    and the Connector to the Main Board
    2xGrounds
    2x5.04 volts
    1x4.6 volts (Labelled SB)
    1x5.04 volts (Labelled 5vSB)
    2x5.04 Volts
    3xGrounds
    1x11.8 volts
    I'm sure there is enough power to start the TV
    The PSU does not appear to be in standby but nothing works as all the voltages are present.
    Is the 4.6 volts to SB correct I'm guessing this is the wire that turns the PSU Standby on and off.
    Should I replace the rest of the Caps on the PSU even though my voltages are quite good or do I have another problem with the Main Board
    Any advice would be appreciated
    Or I'll be chucking it in the bin!!
    I've attached some pics of the boards, I'm not sure if they will help, perhaps someone else has had this fault
    Thanks!!
  • selldoor
    Slow Learner
    • 7870
    Re: Sense Model 51-32 LCD Stuck in Standby
    needs a good dust!! Dust means heat - heat is bad. I would change the two caps on each side of the transformer in the easy to get at bit of the PS.
    EDIT
    Should have asked what make of caps did you use as replacements
    • DjSvoy
      Lenovo ThinkPad Z13 JZ3A0 NM-E071 Rev.1 no power, usb-c stuck at 5 volts
      by DjSvoy
      Looking for help.
      I have a Lenovo ThinkPad Z13 JZ3A0 NM-E071 Rev.1, charging stuck at 5 volts / 0.09A.
      According to the customer, he tried to replace the battery himself, and this is what happened.
      I suspect that one of the two USB-C controllers (U5401 OR 5301) has failed.
      Can anyone confirm that?
      Presented voltages on a board:
      (measured on coils)
      PL1901 - 3.3v,
      PL0501 - 3.3v
      PL0202 - 5.14v
      PL1601 - 1.8v
      PL1401 - 0.75v
      Any help appreciated....
      06-08-2025, 02:56 PM
    • lepak06
      TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
      by lepak06
      Hello
      I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
      The TV is faulty with stuck in Standby RED LED. Can't power the TV.
      Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
      All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
      But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
      01-12-2023, 01:43 AM
    • toty79
      Hisense LTDN50K220WSEU stuck in standby
      by toty79
      Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
      As per Hisense tv title LTDN50K220WSEU stuck in standby
      PSU rsag.820.5687 HLL 4855WF
      Main rsag 7.820.5842
      I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
      05-01-2022, 04:39 PM
    • u666sa
      HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
      by u666sa
      Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
      Platform: ipa32 la-m024p rev 1b
      Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
      I found a short on the other side:
      10-04-2025, 05:03 PM
    • Stunt
      Hp Laptop Stuck on Hp protected by hp sure start screen
      by Stunt
      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
      screen that's it and stuck there. I left it until the following day and i still...
      09-02-2025, 01:51 PM
