Sharp LC-47SB57UT will not power on
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Sharp LC-47SB57UT will not power on
    Are the standby circuit and the PFC circuit tied together? If so, why do you suppose I have full 5V at the 5V pins but only partial votage at BD901? If not, what would bring that 168V at BD901 up to the 320V that the troubleshooting guide suggests?
      The PFC circuit is separate from the standby supply, but sometimes it is powered by it. It boosts the voltage across the main cap from 168V to 390V or so. However, this only happens when the TV is turned on, as boosting the bulk voltage while it is in standby wastes a lot of power. This also won't affect the voltage across the bridge rectifier.
      • johnboy1313
        • Nov 2012
        • 1959
        The trouble shooting guide says that BD901 should be at 320V when the tv is off and "about 400V" when the tv is turned on.
          320V (230V x 1.414) for 230V line AC, 170V (120V x 1.414) for US 120V.
          As I explain how the PFC works, that PS_ON is used to turn on the PFC circuits if you look at the diagram of the PFC, that is why I keep asking for you to find out what DC do you get at the 450v cap when you use that 1K resistor, You can use 2 batteries in series to get 3v to feed that PS_ON PIN, and if the voltage on those two caps still does not jump up to 380~400V , then the PFC is not working.
          • johnboy1313
            • Nov 2012
            • 1959
            + of batteries in series to PS_ON and - to chasis ground?
            • johnboy1313
              • Nov 2012
              • 1959
              With + of the batteries on pson and - on ground I measured 3.11v at pson referenced to the ground pin on the psu. When plugged in I measured 170v across c907, c908, and bd901
                OK, now you will have to check the DC voltage on that Emitter and at the Collector of the transistor that supplies the VCC to the PFC IC, they should have about 12~15vdc, you will have to use the neagtive leg of the large filter cap as the ground ref for this measurement, if you do have the voltage, then the PFC IC is not running.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  With the psu plugged in and 3v applied via batteries to ps_on, the voltage at ps_on and 5vstby both fluctuate from ~2.5-3.5v when referenced to ground. All three pins of q906 and pin7 of ic901 fluctuate from ~7.5-9.5v when referenced to the - side of c907.
                    This is really confusing that the PS_ON is from external 3V power source that feed just one transistor Base drive, I cannot see why it will be fluctuating at all, are only getting 7.5~9.5V on the transistor which being fed by the startup caps voltage that you were getting about15~16v in post 63.
                    At 7.5~9.5V is not enough for the PFC IC to run, the PFC IC will not run if the VCC is less than 11V, min voltage to run is 11.8V.
                    So we are back at the 5VSTBY power supply again. I have to think what else that can cause the outputs (5V output and the AUX output for running the 5V SMPS IC and for running the PFC IC) to be low and fluctuating. I have to think more on how to isolate the problem.
                      I am thinking perhaps another tap from the 5VSTBY supply that is shorted or has a shorted output diode.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        I went ahead and ordered a used psu. It came in the mail today. The tv still won't turn on but I can force this psu and the backlights on. It looks like I may be dealing with a bad main board too. Any ideas about trying to troubleshoot this main board?
                          Held down Ch- and Vol- while powering up? This can overcome some errors temporarily.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            No luck.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Used PSU and a brand new main. Not cheap at all. Lets just say there won't be much profit with this one.
                                Great, looks nice. Thanks for repair info.
                                • advant
                                  by advant
                                  02-03-2020, 12:25 AM
                                • sefoster
                                  Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                  by sefoster
                                  I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                  11-20-2022, 09:29 AM
                                • gavenb
                                  Sharp LC-80LE661U 80 inch
                                  by gavenb
                                  Hi folks!
                                  I have a LC-80LE661U that had some interesting issues.
                                  Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                  I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                  11-12-2023, 02:05 PM
                                • SONY_E-WASTER
                                  Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                  by SONY_E-WASTER
                                  Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                  The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                  then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                  does...
                                  12-26-2021, 05:46 PM
                                • Superbee_dad
                                  Sharp 80” long short flash backlight error - Help
                                  by Superbee_dad
                                  Hello Sharp TV experts
                                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                  01-24-2025, 11:51 PM
