SMD Resistor (Stumped)
  • DavidDunn
    • Sep 2012
    • 10
    I have an odd resistor that I cannot seem to figure out.
    This is a logic buffer from a Panasonic Plasma. I shorted the resistors out when I dropped a screw that grounded out the board and now causes a black strip in the screen. I know I could replace the board but I would rather save a few bucks and try to replace the resistors.
    I have never seen this resistor with a negative ( - ) symbol on a resistor and cannot find any information about it on the web. Does this negative mark change the value or should I just treat this as a 6.8 ohm resistor.
    I hope someone will be able to shine the light on this -6R8 resistor
  • Cosmo66
    • Nov 2012
    • 87
    Re: SMD Resistor (Stumped)
    I would assume that to be 6.8
    what does it measure?
    • DavidDunn
      • Sep 2012
      • 10
      They are blown so it measured nothing. The same resistors next to these on a different channel measured 4.1 ohm.
      I suppose that is my answer but I still have never seen them with this symbol and would like to know what it means.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Safest route (as far as value measurement is concerned) would be to unsolder them from the board and measure them out-of-circuit.
        Looks to me like they're part of some RC filtering circuit (with that chunky 1210(?) cap to their right)...
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        • selldoor
          Slow Learner
          • 7870
          I cant find anything relating to a minus sign before the 6R8 perhaps the manufacturer produces 3 digit code and 4 digit code resistors and HAS to print something when it is only 3 digit value? I would go for 6.8 ohms.
            Hate to bear bad news but if you've got a black bar it might not just be those resistors -- the panel driver may be fried (which is bonded to the plasma panel, so is unreplaceable.)
            • randtek
              • Oct 2011
              • 280
              • US
              I believe Selldoor has the correct answer. The "-" is just a place holder.
              • DavidDunn
                • Sep 2012
                • 10
                I may just treat it as a 6.8 Resistor. The idea of it just being an extra placeholder for a 4 digit code makes since.
                I do hope the panel is not bad but we will see. I will try to replace the resistor and if that doesn't work I will replace the board. If that doesn't work than I will know that I have ruined the panel
                Thanks for the advise guys.
                • TinkerTron
                  Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                  by TinkerTron
                  Hey everyone,
                  I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                  Instead, here's what's been bugging me so far:
                  The schematic...
                  03-06-2025, 02:03 PM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
                • karatzdi
                  Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                  by karatzdi
                  I know some might say... just buy another one. Sell it as parts..!
                  So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                  Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                  Spent some time downloading the Service...
                  06-11-2024, 08:38 AM
                • chth96
                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                  by chth96
                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                  Since then, This AC/DC adaptor have been out of order.
                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                  And Is there any possibility that it will suddenly explode as well as to be out...
                  12-03-2023, 04:40 AM
                • flat-earther
                  Hoover FM216LI cordless vacuum refuses to charge
                  by flat-earther
                  I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                  I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                  5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                  So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                  06-06-2025, 03:14 AM
