Factory Resets Listing
This is a sticky topic.
  • RinusB
    replied
    Re: Factory Resets Listing
    RCA TV Service Menu
    TV on: Menu-1 -1-4-7 (as above post)
    To save the settings turn off TV with remote or on set.
  • IamEngineer
    replied
    Samsung UE40D5520, eeprom was reset, new firmware through USB. Now it need some service setings, but Ihave not idea how to set in service menu . Type, local set, front vlor option. There is not this TV model in listing
  • amennone
    replied
    Master TL550
    Main TP.S506.PC821
    Service mode
  • lotas
    replied
    Originally posted by georgeciurea17@gmail.com
    do you know how to enter in service menu on JVC FireTV?
    I have jvc 49cf890 and I need serice menu
    Thank you
    You have a 17mb170 chassis, try this.
  • georgeciurea17@gmail.com
    replied
    Thank you
  • alfatv
    replied
    Vizio E60-C3 - Menu 3481 to enter factory mode menu, but not very useful
  • Nernder
    replied
    HI Im curious if its possible to do a factory reset on a Toshiba LED SMART tv only using the remote the model number is 50L9450EE
    Long story short, Is I bought the tv to repair. It had a common error message of "USB over current status detected" Which required pulling an IC off the mainboard.
    Now... I wound up pulling 3 IC's of the main board. the final being the one that managed to get rid of the error and fix the tv. Everything was fine, albiet I couldnt use the USB ports...
    The problem was that when i tried to reset the Android user account it is now stuck in the log on screen. This wouldnt be a problem if I could connect a mouse and navigate..lol but i pulled the IC that allows a usb connection. The buttons on the TV also dont seem to work (Am guessing one of the other 2 ICs had something to do with that.)
    I now have a great tv that is stuck on the android log in screen. IF i could bypass Android kitkat all together and use HDMI that would be fine... Im hoping I can reset the TV and it will allow me to use the remote to navigate. As currently the only think i can do with the remote is change the volume.
    Any help would be greatly appreciated. BTW i have also looked for the mainboard, but cant find it AT ALL..grrr
  • daveb9999
    replied
    Originally posted by tom66
    Some of mine:
    Vestel (most):
    Menu 4725 then select "RESET"
    Samsung (European):
    Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
    LG/Zenith:
    Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
    NEC:
    While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
    To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
    I vote for sticky!
    top work Tom !!! you,ve saved me many times over already !!
  • amansilla
    replied
    I believe a factory reset on Toshibas can be done pressing the on/off bottom when turning it on
  • elpiko
    replied
    i have supra snart tv sled43cfhdsm1606 it get to the home screen but display a message unfortunately android.process.media has stop even if you press ok to close the message it come back so you cannot do anything at this point . is there a hot key to press while the tv is booting up to get to a reset screen like most android devices?
    replied
    Code R_J posted:
    Default Re: Vizio M50-C1/M65-C1 Service menu
    Try this:
    Do the following steps rapidly:
    1. Press “MENU”;
    2. Press”1”+”9” +”9” +”9”;
    3. Press ”last”;
  • skyx
    replied
    Originally posted by sardarshams
    ny :Philips LED LCD
    Modal :22PFL 4407
    Code :MENU+2580
    Sr. No. :44
    Company :LG TV:
    Modal :none
    Code :press "Menu" buttons on remote and TV panel simultaneously for a few seconds
    Sr. No. :43
    Company :LG TV:
    Modal :none
    Code :Press and hold*buttons on remote as well as TV panel for a few seconds
    Sr. No. :42
    Company :Samsung TV
    Modal :none
    Code :First power off your TV using the remote, then press following buttons quickly on the remote: Info + Settings + Mute + Power Mute + 1 + 8 + 2 + Power Mute + 1 + 1 + 9 + Power Display/Info + Menu + Mute + Power Display/Info + P.STD + Mute + Power P.STD + Help + Sleep + Power P.STD + Menu + Sleep + Power Sleep + P.STD + Mute + Power
    Sr. No. :41
    Company :Samsung TV
    Modal :none
    Code :Mute + 1 + 1 + 9 + Enter
    Sr. No. :40
    Company :Sony TV
    Modal :none
    Code :First power off your TV using the remote, then press following buttons quickly on your TV remote: Display (or i+) + 5 + Volume Up + Power
    Sr. No. :39
    Company :Toshiba LCD, LED
    Modal :none
    Code :1. Press the {MENU} button on the remote. 2. Highlight the "Picture" icon. 3. Press the {9} {3} {0} {1} buttons on the remote control. The Service Menu will be displayed with the following Modes: "Options" - "Adjustments" - "Selections" 4. Use the {OK} button to access and navigate through these Modes 5. To change values use {VOL +} {VOL-) {P+} {P-} 6. To exit, press the {MENU} button
    Sr. No. :38
    Company :LG LCD
    Modal :none
    Code :1 POWER ONLY 2 IN.STOP 3 IN.START 4 EZ.ADJ Intercode 0000 7777 0413 8741 8743 8878
    Sr. No. :37
    Company :VIDEOCON TV
    Modal :none
    Code :MENU +6483
    Sr. No. :36
    Modal :none
    Code :MENU +1147
    Sr. No. :35
    Modal :none
    Code esign mode MENU +1982 SERVICE mode menu +1947
    Sr. No. :34
    Modal :none
    Code esign mode MENU +0203 SERVICE mode MENU +0323
    Sr. No. :33
    Company :VIDEOCON LCD
    Modal :none
    Code :MENU+SOUNDS POP UP+8532
    Sr. No. :32
    Modal :none
    Code :MENU+123
    Sr. No. :31
    Company :CHINA
    Modal :none
    Code :PRESS MENU BUTTON picture contrast NOW PRESS 9705
    Sr. No. :30
    Company :TELEFUNKEN
    Modal :all model
    Code :MENU+4725
    Sr. No. :29
    Company :Jumper board
    Modal :V56U V56J.11.2
    Code :INPUT+0000
    Sr. No. :28
    Code :INPUT+2580
    Sr. No. :27
    Modal :TP.HV320.PB801
    Code :MENU +1147
    Sr. No. :26
    Company :None
    Modal :Jumper board
    Code :Menu+8896
    Sr. No. :25
    Company :China
    Modal :None
    Code :mute+6483
    Sr. No. :24
    Company :China
    Modal :None
    Code :source+0000.
    Sr. No. :23
    Company :China
    Modal :None
    Code :source+menu+0000.
    Sr. No. :22
    Company :China
    Modal :None
    Code :source+3138
    Sr. No. :21
    Company :China
    Modal :None
    Code :source+2580
    Sr. No. :20
    Company :China
    Modal :None
    Code :menu+audio balance +1969
    Sr. No. :19
    Company :China
    Modal :None
    Code :menu+audio balance +0532
    Sr. No. :18
    Company :China
    Modal :None
    Code :menu / c- / 8532
    Sr. No. :17
    Company :China
    Modal :None
    Code :menu/ v+ / c- / 8532
    Sr. No. :16
    Company :China
    Modal :None
    Code :menu+8893
    Sr. No. :15
    Company :China
    Modal :None
    Code :menu+8896
    Sr. No. :14
    Company :China
    Modal :None
    Code :menu+2387
    Sr. No. :13
    Company :china
    Modal :none
    Code :menu+8202
    Sr. No. :12
    Company :china
    Modal :none
    Code :menu+2383
    Sr. No. :11
    Company :china
    Modal :none
    Code :menu+1183
    Sr. No. :10
    Company :china
    Modal :none
    Code :menu+1199
    Sr. No. :9
    Company :china
    Modal :none
    Code :menu+1167
    Sr. No. :8
    Company :china
    Modal :none
    Code :menu+1187
    Sr. No. :7
    Company :china
    Modal :none
    Code :menu+0000
    Sr. No. :6
    Company :china
    Modal :none
    Code :menu+1999
    Sr. No. :5
    Company :china
    Modal :none
    Code :menu+123
    Sr. No. :4
    Company :china
    Modal :none
    Code :menu+7343
    Sr. No. :3
    Company :china
    Modal :none
    Code :menu+4725
    Sr. No. :2
    Company :china
    Modal :none
    Code :menu+1147
    Sr. No. :1
    Company :SHARP LCD LED TV
    Modal :None
    Code :unplug the power cable. * Then while pressing the {INPUT} & {VOL -} buttons on the set , plug the power cable back into the outlet. * When it powers up you will see a little "k" appear in brackets. * Then on the TV,
    so good........
  • sardarshams
    replied
    LED TV SERVICE MENU WITH BOARD NAME:-
    1. VS.TP53U71.2 = Input 208
    2. VS.TP53U61.2 = Input 208ed Tv
    3. VS.TP53L62.2 = Menu1147
    4. T.VST59.031 = Menu 1147
    5. T.R83.031 = MENU 1147
    6. TP.HV320/PB813 = MENU 1147
    7. TP.HV320/PB801 = MENU 1147
    8. TR.85.03 = MENU 1147
    9. T.VST59.031.A81A8 = MENU 1147
    10. T.VST59.031 = MENU 1147
    11. T56J.11.2 = MENU 1147, NPUT 2580, Input 0000, Menu 8892, Av 208, AV308
    12. T.VST29.03 = MENU 1147
    13. SKR.03 = MENU 1147
    14. SKR.801 = MENU 1147
    15. T5964.81 = MENU 1147
    16. TP.MS.338.PC821 = MENU 1147
    17. LAD.MV59S.G = MENU 7710
    18. T.VST29.61.C = MENU 1147
    19. 5800-A8M260-0020 Input 3195
    20. 350016386 = MENU 2008
    21. CVMV26L-A-20 = Input 2580
    22. CV182L-B = Input 2580
    23. SP208ESA HK-7050A-V208 =Menu 7050
    24. 35017414 rev-01 = Menu 2008
    25. TVST 59.A5 = MENU 1147
    26. CV181L-Y Input 2580
    27. T.VST59.62 = MENU 1147
    28. JUG7.820.531-3 = Input 3133
    29. 35016445 REV-01 Menu 2008
    30 T.VST59S.73 = MENU 1147
    31. TP.VST59.P83 = MENU 1147
    32. T.MT 8223.33 = MENU 1147
    33. TMS.18VG.81B = MENU 1147
    34. T.MS.18VG.71A = ENU 1147
    35. 40.TBI.TO7-MABE HG = Menu / Contrast 1950 or 9735
    36. TP.MS1306.PB772 = Menu / Contrast 1950 or 9735
    37. CV309H-V = Input 2580
    38. TP.VST59.PB819 Menu 2008
    39. CV56BH.242 Menu 2580
    40. TP.MS.608.P82 Source/Input 1147
    CHANGHONG SERVICE MENU CODE:-
    1. Input 3138
    2. Input 1125
    3. Input 42580
    4. Input 3138
    5. Menu 1125
    6. Menu 1149
    7. Menu 2580
    8. Menu 0816
    ECOSTAR SERVICE MENU CODE:-
    1. Menu 2008
    2. Menu 2508
    3. Menu 8002
    4. Menu 8202
    ORIENT SERVICE MENU CODE:-
    1. Input 2580, 2588
    2. Source 2588, 2580
    HAIER SERVICE MENU CODE:-
    1. Menu 1147
    2. Menu 8202
    3. 8823
    4. Menu 4578
    5. + High Light Audio+8893
    6. Menu/Exit +1999+OK
    TCL SERVICE MENU CODE:-
    1. Menu + Contrast + 9735 or 1950
    SUM SUNG SERVICE MENU CODE:-
    1. On Standby Press Mute + 182 + Power
    2. Turn Off, Info, Menu, Mute, Power
    LG SERVICE MENU:-
    1. Press and hold the menu button until 4 Digit password Display open
    2. 8741
    3. 0413
    4. 0000
    5. 8878
    6. 7777
    7. 8743
    VIDEO CON SERVICE MENU:-
    1. Menu 123
    2. Menu 0323
    3. Menu 1147
    4. Menu 1947
    5. Menu 6483
    6. Menu + Sound + 8532
    ONIDA SERVICE MENU:-
    1. Source 2580
    2. Menu + Vol+ + 8532
    3. Menu, Pic, Cont, 9735
    4. Menu, Pic, Cont, 1950
    INTEX SERVICE MENU:-
    1. LED 1601 = MENU 13
    2. LED 1602 = MENU 8896
    3. LED 1602N = MENU 8896
    4. LED 1600 = INPUT 2580
    5. LED 1611-VT13 = Source + 6964
    6. LES/9HD08-B013 = Input + 2580
    7. LED TV2110 = Menu+8896
    8. Led 2200 FHD= Menu + 1147
    9. Led 2202 FHD= Menu + 1147
    10. Led 2410 FHD= Menu + 8202
    11. Led 2800 FHD= Menu + 1147
    CHINA UNIVERSAL LED TV BOARD SERVICE MENU:-
    1. Menu+208
    2. Menu+0101
    3. Menu+710
    4. Menu+1234
    5. Menu+4711
    6. Menu+4725
    7. Menu+5880
    8. Menu+6181
    9. Menu+7050
    10. Menu+7168
    11. Menu+7343
    12. Menu+7710
    13. Menu+8093
    14. Menu+8500
    15. Menu+8202
    16. Menu+8593
    17. Menu+8896
    18. Menu+8893
    19. Menu+9301
    20. Menu+9380
    21. Menu+9385
    22. Menu+9527
    23. Menu+9735
    24. Menu+9883
    25. Input+1147
    26. Input+2580
    27. Input+0000
    28. Input+208
    29. Input+308
    30. Source 0000
    31. Source 2283
    32. Source 2285
    33. Source 2580
    34. Source 2585
    35. Source 2587
    36. Source 3137
    37. Source 3138
    38. Source 3195
    39. Source 6483
    40. Source 7343
    41. Source 6483
    42. Menu+0000
    43. Menu+1147
    44. Menu+1150
    45. Menu+1167
    46. Menu+1185
    47. Menu+1187
    48. Menu+1189
    49. Menu+1199
    50. Menu+1150
    51. Menu+1173
    52. Menu+1999
    53. Menu+2008
    54. Menu+2383
    55. Menu+2387
    56. Menu+2508
    57. Menu+2580
    58. Menu+2588
    59. Menu+2611
    60. Menu+2880
    61. Menu+2888
    LCD/LED TV Service Menu Code with Board Name:
    CV338H- A32: Menu 1147
    CV338H- A42: Menu 1147
    CV338H- A50: Menu 2580
    CV628H-T42: Menu 1147
    CV628H-B42: Menu 1147
    CV950H-A42: Source 2580
    MSD338ST V5.0: Source 2580
    TP.HV310.PB801: Menu 1147
    TP.HV320.PB801: Menu 1147
    TP.HV510.PC821: Source 2580
    TP.HV530.PC821: Source 2580
    TP.MS338.PB801: Menu 1147
    TP.MS338.PB802: Menu 1147
    TP.MS338.PC821: Menu 1147
    TP.MS338.PB822: Menu 1147
    TP.MS338.P818: Menu 1147
    TP.MS338.PB818: Menu 1147
    TP.MS358.PB801: Menu 1147
    TP.MS608.PB831: Menu 1147
    Tp.MS608.P83: Menu 1147
    Tp.MS608.P82: Input/Source 1147
    TP.MS628.PC821: Menu 1147, Menu 2580
    TP.MS628.PB803: Menu 1147, Menu 2580
    TP.MS628.PB831: Menu 1147
    TP.MS628 PD65: Menu 1147, Menu 2580
    TP.MT5505.PC801: Menu 1147
    TP.MT5507.PC821: Menu 1147
    TP.MT5507.PB801: Menu 1147
    TP.RT2984T.PC821: Menu 1147, Menu 2580
    TP.RT2982.PC821: Menu 1147, Menu 2580
    TP.RT2982.PB801:
    TP.R69 PD64:
    T.MS608.61: Source 2580
    T.MS608.81: Source 2580
    VS.SP33811.2: Input/Source 208
    ZP.VST6A338.PB818: Source 2580
    T.R83.031: Menu 1147
    T.R85.031: Menu 1147
    TR.85.03 Menu 1147
    T56J.11.2 Menu 1147
    VS.Tp53U61.2: Input 208
    VS.Tp53U71.2: Input 208
    VS.TP56L62.2: Menu 1147
    T.VST59.031: Menu 1147
    TP.VST59s.PB813 Menu 1147
    CV56BL-L: Input 2580
    CV56BL-Q24: Input 2580
    CV56BL-Y24: Input 2580
    SKR.03: Menu 1147
    SKR.801 Menu 1147
    SKR.816: Menu 1147
    SKR.819: Menu 1147
    LAD.MV56U.A36 Menu 1147
    LAD.MV56U.A48 Menu 1147
    LAD.MV56U.A75 Menu 1147
    LAD.MV56U.B48 Menu 1147
    LAD.MV56U.C36 Menu 1147
    LAD.MV59S.I Menu 7710
    LAD.MV59S.G Menu 7710
    LAD.MV59S.Q Menu 7710
    LAD.MV9.R: Menu 710
    LAD.MV9.P: Menu 1147
    T.VST29.03 Menu 1147
    T.V56.03 Menu 1147
    T.VST59.031 .A81 A8 Menu 1147
    T5964.81 Menu 1147
    T.VST29.61 C Menu 1147
    CVMV26L-A-20 Input 2580
    CV182L_B Input 2580
    SP208ESA HK-7050A-V2.08-E Menu 7050
    T.MS18VG.72 Menu 1147
    T.VST59.A5 Menu 1147
    CV181 L-Y Input 2580
    T.VST.29.61 C Menu 1147
    T.VST59.62 Menu 1147
    T.VST59S. 73 Menu 1147
    TP.VST59.P83 Menu 1147
    T.MT8223.3B Menu 1147
    T.MS.18VG.81 B Menu 1147
    T.MS18VG.71A Menu 1147
    CV309H-X Source 2580
    CV56BH-Q28: Input 2580
    CV56BH-Q32: Input 2580
    CV56BH-Q42: Input 2580
    CV56XH-U32: Input 208
    CV56XH-U42: Input 208
    CV56XH-U50: Input 208
  • sardarshams
    replied
    TCL LED TV SERVICE MODE Access to the service menu (all the adjustments on your own risk !!):
    In the picture settings menu, select "Contrast" and at this point tsify dialing the following:
    1950 - general service menu (Design Menu)
    9735 or 6428 - subsection Factory Menu
    9705 - subsection Service menu
    6405 - subsection Hotel menu
    6425 - another (separate) menu, nothing new, but there is quick access to the reset (reset All and reset Shop)
  • sardarshams
    replied
    All Service Code
    Sr. No. :177
    Company :
    Modal :
    Code :
    Sr. No. :161
    Company :MI
    Modal :None
    Code :Insert Ac Plug Relese STb from Tv Power Key Then Press & Hold Power & OK Keys In Remote Now TV Will Open With Service Mode For Software Instalation Also Fallow Same Method
    Sr. No. :160
    Company :MI India
    Modal :NOne
    Code :Press the Menu button and then the right arrow button on the your remote, and then arrow down to the Sound settings. Arrow right and enter the Advanced Audio Settings, and arrow down to the Balance section. Make sure it is set to 0. Type "1969" on your remote. Your TV will leave the menu screen, and a green "M" will appear in the upper left corner of your screen. Press the Menu button to access the service menu. The 'Factory' tab at the top will be highlighted in yellow
    Sr. No. :159
    Company :Panasonic
    Modal :Hotel MOde On Off
    Code :How to enter to Hotel Mode 1. Purpose Restrict a function for hotels. 2. Access command to the Hotel mode setup menu. In order to display the Hotel mode setup menu, please enter the following command (within 2 second). [TV] : Vol [Down] + [REMOTE] : INPUT (3 times) Self-check indication and forced to factory shipment setting Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds. Exit Disconnect the AC cord from wall outlet.
    Sr. No. :158
    Company :Panasonic
    Modal :Self Check
    Code :Self Check Mode 1. Press the �MENU� button (on the remote control) and the �VOL DOWN� button on the LCD panel. 2. Press ON/OFF button on the panel to Exit. Hotel Mode Adjustment 1. Press the �VOLUME DOWN� button on the TV panel and simultaneously press the INPUT button on the remote control 3 times to enter Hotel Mode. 2. Set Hotel mode �on/off�, then press �EXIT� to come out.
    Sr. No. :157
    Company :Panasonic
    Modal :TH-32A300DX
    Code :While pressing [VOLUME ( - )] button of the main unit, press [INFO] button of the remote control three times within 2 seconds.
    Sr. No. :132
    Company :Vision Quest
    Modal :all
    Code :Input/Source 2580
    Sr. No. :131
    Company :Veste/
    Modal :all
    Code :Menu 4725 then select "RESET
    Sr. No. :130
    Company :Symphony
    Modal :all
    Sr. No. :129
    Company :Toshiba
    Modal :all
    Code :On Menu, select "Installation", then " System Information" press the right arrow button. ("System Information" will change to "Factory Reset" or something similar) • Adjust the volume to zero, press the mute twice from the remote and press the menu button on the TV (fourth button from the bottom and marked p and decree it shares) to exit, the menu shut the TV • Press the Menu, Highlight the Picture, Press 9301, ok
    Sr. No. :128
    Company :Supra
    Modal :all
    Code :INPUT, 3, 1,3,8,MENU-1147,INPUT-2580,MENU-1147,MENU-2008,MENU-7050,INPUT-2580,"Menu", "Red", "Green", "Yellow", "Cyan,"MENU" - dial 2008,SOURCE - 3, 1,9,5, MENU -1, 1,4,7. Exit EXIT,
    Sr. No. :127
    Company :Videocon
    Modal :all
    Code :Menu 123 • Menu 0323 • Menu 1147 • Menu 1947 • Menu 6483 • Menu+Sound+8532
    Sr. No. :126
    Company :LG
    Modal :all
    Code :• Press and Hold the Menu button until 4 digit password displayed: • 8741 • 0413 • 0000 • 8878 • 7777 • 8743
    Sr. No. :125
    Company :Samsung
    Modal :all
    Code :• On Standby Press Mute+182+Power • Turn OFF, Info, Menu, Mute, Power
    Sr. No. :124
    Company :TCL
    Modal :all
    Code :• Menu+Contrast+9735 or 1950 • With the TV on, Select Home Select Setting and OK A 5121 Select System and OK Select About and OK, System info for TV will be displayed Use the remote and press the following sequence: Up, Right, Down, Right, Up Press the Fast Forward button 3 times Press the Rewind button 2 times
    Sr. No. :123
    Company :Haier
    Modal :all
    Code :• Menu 1147 • Menu 8202 • Menu 8893 • Menu 4578 • Menu+Highlight Audio+8893 • Press "MENU/EXIT"; Press 1999; Press "OK"
    Sr. No. :122
    Company :Orient
    Modal :none
    Code :• Input 2580, 2588 • Source 2588, 2580
    Sr. No. :121
    Company :Orient
    Modal :none
    Sr. No. :120
    Company :Ecostar
    Modal :none
    Code :• Menu 2008 • Menu 2508 • Menu 8002 •
  • sardarshams
    replied
    Menu 8202
    Sr. No. :119
    Company :Changhong Ruba
    Modal :none
    Code :• Source 3138 • Source 1125 • Source 42580 • Source 3130 • Menu 1125 • Menu 1147 • Menu 2580 • Menu 0816
    Sr. No. :118
    Company :Board Name
    Modal :40-T31TOT-MAB2HG
    Code :Menu. Contrast 1950 or 9735
    Sr. No. :117
    Company :Board Name
    Modal :SP208ESA HK-7050A-V2.08-E
    Code :Menu 7050
    Sr. No. :116
    Company :Board Name
    Modal :350016386
    Code :Menu 2008
    Sr. No. :115
    Company :Board Name
    Modal :5800-A8M260-0020
    Code :Source 3195
    Sr. No. :114
    Company :Board Name
    Modal :LAD.MV59S.G
    Code :Menu 7710
    Sr. No. :113
    Company :Board Name
    Modal :T56J.11.2
    Code :Menu 1147, Input 2580, Input 0000, Menu 8896, AV 208, AV 308
    Sr. No. :112
    Company :Board Name
    Modal :TP.VST59s.PB813
    Code :Menu 1147
    Sr. No. :111
    Company :Board Name
    Modal :T.R85.031
    Code :Menu 1147
    Sr. No. :110
    Company :Board Name
    Modal :T.R83.031
    Code :Menu 1147
    Sr. No. :109
    Company :Board Name
    Modal :T.VST59.031
    Code :Menu 1147
    Sr. No. :108
    Company :Board Name
    Modal :VS.TP56L62.2
    Code :Menu 1147
    Sr. No. :107
    Company :Board Name
    Modal :VS.Tp53U61.2
    Code :Input 208
    Sr. No. :106
    Company :Board Name
    Modal :VS.Tp53U71.2
    Code :Input 208
    Sr. No. :105
    Company :China Universal Board
    Modal :Jumper Board
    Code :• Source 2585 • Source 2587 • Source 3137 • Source 3138 • Source 3195 • Source 6483 • Source 7343 • Mute 6483
    Sr. No. :104
    Modal :Jumper Board
    Code :• Input 208 • Source/Input 308 • Input 3195 • Source 0000 • Source 2283 • source 2285 • Source 2580 • Source 2583
    Sr. No. :103
    Modal :Jumper Board
    Code :• Menu 8893 • Menu 8896 • Menu 9301 • Menu 9380 • Menu 9385 • Menu 9527 • Menu 9735 • Menu 9883 • Input 1147 • Input 2580 • Input 0000
    Sr. No. :102
    Modal :Jumper Board
    Code :Menu 0000 • Menu 208 • Menu 0101 • Menu 710 • Menu 1234 • Menu 4711 • Menu 4725 • Menu 5880 • Menu 6181 • Menu 7050 • Menu 7168 • Menu 7343 • Menu 7710 • Menu 8093 • Menu 8500 • Menu 8202 • Menu 8593
    Sr. No. :101
    Modal :Jumper Board
    Code :Menu 2888
    Sr. No. :100
    Modal :Jumper Board
    Code :Menu 2880
    Sr. No. :99
    Modal :Jumper Board
    Code :Menu 2611
    Sr. No. :98
    Modal :Jumper Board
    Code :Menu 2588
    Sr. No. :97
    Modal :Jumper Board
    Code :Menu 2580
    Sr. No. :96
    Modal :Jumper Board
    Code :Menu 2508
    Sr. No. :95
    Modal :Jumper Board
    Code :Menu 2387
    Sr. No. :94
    Modal :Jumper Board
    Code :Menu 2383
    Sr. No. :93
    Modal :Jumper Board
    Code :Menu 2008
    Sr. No. :92
    Modal :Jumper Board
    Code :Menu 1999
    Sr. No. :91
    Modal :Jumper Board
    Code :Menu 1973
    Sr. No. :90
    Modal :Jumper Board
    Code :Menu 1950
    Sr. No. :89
    Modal :Jumper Board
    Code :Menu 1199
    Sr. No. :88
    Modal :Jumper Board
    Code :Menu 1197
    Sr. No. :87
    Modal :Jumper Board
    Code :Menu 1187
    Sr. No. :86
    Modal :Jumper Board
    Code :Menu 1185
    Sr. No. :85
    Modal :Jumper Board
    Code :Menu 1167
    Sr. No. :84
    Modal :Jumper Board
    Code :Menu 1150
    Sr. No. :83
    Modal :Jumper Board
    Code :Menu 1147
    Sr. No. :82
    Company :NEC
    Modal :none
    Code :While powering ON, hold "MENU" or "INPUT" on TV,
    Sr. No. :81
    Company :Insignia USA
    Modal :none
    Code :Input 2580 (TV is on)
    Sr. No. :80
    Company :Hisense
    Modal :none
    Code :“Parental ” enter 0000 then select “Clean All ~
    Sr. No. :79
    Company :COBY
    Modal :none
    Code :menu, Hi-Lite “audio” then enter 8893 Mode/Source 2580
    Sr. No. :78
    Company :Samsung and Sony Service
    Modal :CV628-B42 CV338-B42 and CV338-A50 Boards
    Code :Source 2580 Source 2583 Source 2587 Also other china universal boards service mode Menu 1147 Menu 1183
  • sardarshams
    replied
    Menu 1185 Menu 1187
    Sr. No. :77
    Company :MI
    Modal :ALL
    Code :INSERT AC PLUG ...RELEASE STB. FROM TV POWER KEY THEN PRESS & HOLD POWER &OK KEYS IN REMOT ...........SOFTWEAR INSTT. SAME METHHOD
    Sr. No. :76
    Company :Element
    Modal :none
    Code :Menu 0000 > menu 1147
    Sr. No. :75
    Company ynex
    Modal :none
    Code :Source/Input 2580 Hold Vol down on TV and hold the (#1) button on remote
    Sr. No. :74
    Company :Beston led
    Modal :none
    Code :menu1147 input 2580
    Sr. No. :73
    Company :ONIDA
    Modal :none
    Code :MENU + 2008
    Sr. No. :72
    Company :Singer
    Modal :none
    Code :press the sequence on the remote control: 1, MUTE, RECALL, MUTE. 1, MUTE, DISPLAY MUTE
    Sr. No. :71
    Company :samsung LCD
    Modal :none
    Code :INFO, MENU, MUTE, POWER ON
    Sr. No. :70
    Company :Haier
    Modal :HTR20 20" CRT TV
    Code :Press MENU buton on TV pannel andMENU buton on remote control at the same time
    Sr. No. :69
    Company :Haier LCD
    Modal :HL40XP1
    Code : Press Menu button, press the key 8893, and Press “OK”
    Sr. No. :68
    Company :China lcd
    Modal :none
    Code :Press SLEEP→PIC→DSP→MENU button on the remote (2)Press MENU => Q.VIEW => MUTE to enter (3) "PRESET"."Ch ,press 2483
    Sr. No. :67
    Company :Beko - LCD
    Modal :none
    Code : Menu- 9, 3, 0, 1
    Sr. No. :66
    Company :seconmo AOC TV
    Modal :none
    Code :mode adjust volume to zero, press mute key and press number key 9 8 7 6
    Sr. No. :65
    Company :Haier
    Modal :none
    Code :1. Press “MENU/EXIT”; 2. Press”1”+”9” +”9” +”9”; 3. Press “OK”
    Sr. No. :64
    Company :Vestel
    Modal :none
    Code :Menu 4725 then select "RESET" Vision Quest Source / Input 2580 Vizio menu under “Help” tab is Factory Default enter 0000
    Sr. No. :63
    Company :Toshiba
    Modal :none
    Code :Menu, select “Installation”, then “ System Information” press the right arrow button. (“System Information” will change to “Factory Reset” or something similar)
    Sr. No. :62
    Company :Symphony
    Modal :none
    Code :Source/input 2580
    Sr. No. :61
    Company :Sony
    Modal :none
    Code :Hold “arrow up” on Remote and push power button on TV (TV is ON)
    Sr. No. :60
    Company :Sharp
    Modal :none
    Code :Menu, 1999 Menu, 3481 Menu, 1147 While holding [ VOL– & INPUT ] buttons on TV plug in set when “K ” appears push (VOL– & CHANNEL-)
    Sr. No. :59
    Company :Seiki
    Modal :none
    Code :Menu 0000
    Sr. No. :58
    Company :Samsung
    Modal :none
    Code :Mute 182 power Samsung (European) Power off, Info - Menu - Mute - Powe
    Sr. No. :57
    Company :Sanyo
    Modal :none
    Code :Hold VOL Down on TV, press and hold #1 button on remote, VOL will jump to halfway and set shuts off. Turn back on have 1st time setup screen
    Sr. No. :56
    Company :Panasonic
    Modal :none
    Code :Hold [ VOL— ] on TV, press and hold menu button on remote
    Sr. No. :55
    Company :Mitsubishi
    Modal :none
    Code :Menu 123 or Menu 2470 (TV is on) NEC While powering ON, hold "MENU" or "INPUT" on TV
    Sr. No. :54
    Company ynex
    Modal :none
    Sr. No. :53
    Company :PANASONIC
    Modal :TH-32A300DX
    Code : Menu+1950
    Sr. No. :52
    Company :Micromax LCD/LED
    Modal :none
    Code :3) Service Menu - Random stuff Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 9, 7, 0 and 5 in series, Service Menu will appear in the left top of screen
    Sr. No. :51
    Modal :none
    Code :2) Factory Menu - Access to color calibration & WB settings Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 9, 7, 3 and 5 in series, Factory Menu will appear in the left top of screen
    Sr. No. :50
    Modal :none
    Code :1) Design Menu - Can access all other modes through this - Access to Overscan and other settings Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 1, 9, 5 and 0 in series, Design Menu will appear in the left top of screen
    Sr. No. :49
    Company :samsung led/lcd
    Modal :none
    Code :power info menu mute power
    Sr. No. :48
    Company :LLOYD
    Modal :none
    Code :menu+1147
    Sr. No. :47
    Company :LLOYD
    Modal :none
    Code :menu+sound balance+1969
    Sr. No. :46
    Company :Philips LED LCD
    Modal :24PFL3457
    Code :MENU+1950
    Sr. No. :45
    Compa
  • sardarshams
    replied
    ny :Philips LED LCD
    Modal :22PFL 4407
    Code :MENU+2580
    Sr. No. :44
    Company :LG TV:
    Modal :none
    Sr. No. :43
    Company :LG TV:
    Modal :none
    Sr. No. :42
    Company :Samsung TV
    Modal :none
    Sr. No. :41
    Company :Samsung TV
    Modal :none
    Sr. No. :40
    Company :Sony TV
    Modal :none
    Sr. No. :39
    Modal :none
    Sr. No. :38
    Company :LG LCD
    Modal :none
    Sr. No. :37
    Modal :none
    Code :MENU +6483
    Sr. No. :36
    Modal :none
    Code :MENU +1147
    Sr. No. :35
    Modal :none
    Sr. No. :34
    Modal :none
    Sr. No. :33
    Modal :none
    Sr. No. :32
    Modal :none
    Code :MENU+123
    Sr. No. :31
    Company :CHINA
    Modal :none
    Sr. No. :30
    Company :TELEFUNKEN
    Modal :all model
    Code :MENU+4725
    Sr. No. :29
    Code :INPUT+0000
    Sr. No. :28
    Code :INPUT+2580
    Sr. No. :27
    Code :MENU +1147
    Sr. No. :26
    Company :None
    Modal :Jumper board
    Code :Menu+8896
    Sr. No. :25
    Company :China
    Modal :None
    Code :mute+6483
    Sr. No. :24
    Company :China
    Modal :None
    Code :source+0000.
    Sr. No. :23
    Company :China
    Modal :None
    Sr. No. :22
    Company :China
    Modal :None
    Code :source+3138
    Sr. No. :21
    Company :China
    Modal :None
    Code :source+2580
    Sr. No. :20
    Company :China
    Modal :None
    Sr. No. :19
    Company :China
    Modal :None
    Sr. No. :18
    Company :China
    Modal :None
    Sr. No. :17
    Company :China
    Modal :None
    Sr. No. :16
    Company :China
    Modal :None
    Code :menu+8893
    Sr. No. :15
    Company :China
    Modal :None
    Code :menu+8896
    Sr. No. :14
    Company :China
    Modal :None
    Code :menu+2387
    Sr. No. :13
    Company :china
    Modal :none
    Code :menu+8202
    Sr. No. :12
    Company :china
    Modal :none
    Code :menu+2383
    Sr. No. :11
    Company :china
    Modal :none
    Code :menu+1183
    Sr. No. :10
    Company :china
    Modal :none
    Code :menu+1199
    Sr. No. :9
    Company :china
    Modal :none
    Code :menu+1167
    Sr. No. :8
    Company :china
    Modal :none
    Code :menu+1187
    Sr. No. :7
    Company :china
    Modal :none
    Code :menu+0000
    Sr. No. :6
    Company :china
    Modal :none
    Code :menu+1999
    Sr. No. :5
    Company :china
    Modal :none
    Code :menu+123
    Sr. No. :4
    Company :china
    Modal :none
    Code :menu+7343
    Sr. No. :3
    Company :china
    Modal :none
    Code :menu+4725
    Sr. No. :2
    Company :china
    Modal :none
    Code :menu+1147
    Sr. No. :1
    Modal :None
  • mospeada
    replied
    Sceptre X322BV-HDR
    Menu 1147
  • mccloud
    replied
    i need a bios bin file for aspire 4743 series board code JE43-CP MB 10277-1M 48.4NI01
    LCD LED TV Service Menu Codes
    ALL LCD LED TV SERVICE MENU CODES
    China Universal Board / Jumper Board Service Menu Code
    Changhong Ruba Service Menu Code
    Ecostar LED TV Service Menu Code
    Orient LED TV Service Menu Code
    Haier LED TV Service Menu Code
    TCL LED TV Service Menu Code
    Samsung LED TV Service Menu Code
    LG LED TV Service Menu Code
    Videocon LED TV Service Menu Code
    Supra LED TV Service Menu Code
    Toshiba LED TV Service Menu Code
    Symphony LED TV Service Menu Code
    Veste/ LED TV Service Menu Code...
    10-31-2024, 03:58 AM
  • RRice25541
    Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
    by RRice25541
    So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
    the color is all outa wack, like the settings have been corupted,
    I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
    so
    The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
    when i bring up the menu and type the pass codes to access either mode the menu disappears...
    05-13-2022, 10:44 PM
  • howardc64
    M557-G0 no WiFi/Bt no WIFIVendor file?
    by howardc64
    Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
    • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
    • Service Menu shows many Bt/Wifi info missing
    • Vizio app shows no WIFIVendor file
    Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
    • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
    10-15-2024, 01:12 PM
  • dxz
    lenovo thinkpad e480 problem
    by dxz
    howdy yall,
    back in this last december i lost my svp for my thinkpad, then i found this technique and it worked successfully.
    the only thing i found weird was that now in the bios menu, specifically under the secure boot configuration in the security tab, it went from mentioning microsoft windows 10 to now showing microsoft windows 8 when i scroll over the restore factory keys option.
    and im wondering if my current problem is due to the flash/patch ive done:
    im having a hard time activating windows 10 pro :lenovo thinkpad e480 that i purchased...
    06-16-2023, 04:10 PM
  • Retro140
    Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
    by Retro140
    So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
    To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
    06-18-2023, 06:13 PM
