Factory Resets Listing
This is a sticky topic.
    Re: Factory Resets Listing
    It looks like you do need LG remote since I do not believe the universal will have the 'ADJ' button.
    • nash10
      • Oct 2009
      • 18
      #82
      hello can you give me the service manual of devant 42mel100 or eeprom bacause i wanna update because the lcd screen is blurred or shadow or ghosting display....help me with this masters thanks in advance......
      • nash10
        • Oct 2009
        • 18
        #83
        devant 42mel100 chassis msd209 do u have firmware
        panel:konka kpl +420b1c3e1
        can you give firmware or service manual sir....
        • Kilroys
          • Feb 2014
          • 70
          • Sweden
          #84
          Hope this will help someone.
          • nash10
            • Oct 2009
            • 18
            #85
            is this service menu for devant sir?
            • nash10
              • Oct 2009
              • 18
              #86
              not working up for service menu or firmware......
              • edwinarriaza
                • Jun 2016
                • Guatemala
                #87
                good day! i have an lg 55lw5600 need to know if going into service code can solve image problem. when image is displayin it starts giving horizontal lines from left to right after hours watching the image becomes nive and clear for a while the troubles again. when tv starts instead of showing the lg logo it displays horizontal white and purple stripes. then the lg block that moves across the screen has the lines after several hours the lines go away and you can tune chanels or go to smart tv programs.
                i would like to know id reseting the tv with service code could restore damaged files and it would start correctly. or if i need to change a board or else.
                thank you i apreciate you care about other people.
                • Piper
                  • Jul 2016
                  • Sierra leone
                  #88
                  How do I turn off child lock from my Nec tv without a remote (model: NLT-32HDB2) please?
                  • nams5t
                    • Jun 2016
                    • ayisha
                    #89
                    akai 32 lcd tv,,lta320ap02 standby problem only red light any help
                    • nv3tech
                      • Aug 2016
                      Vizio 28" D28hn
                      I am in search of a service menu code for this TV. The tv only has a power button on it so the code where you hold the channel buttons will obviously not work. I have tried the codes in this thread to no avail. Any help would be greatly appreciated.
                      • cleverone
                        • Jul 2014
                        • Myanmar(Burma)
                        #91
                        I've taken this page for my future needs.Thank a lot to uploader.
                        • ernest79336
                          • Aug 2016
                          • 5
                          Hello everyone i had a DYNEX DX-LCD26-09 that when you turn it on it would just have a white screen no buttons would work menu,input,ect I bought a new main board for it still no change.Then i hooked up a Roku to it via composite held down the input button and the vol down all the sudden it started working i hope this will help someone
                          • Korgano
                            • Jan 2017
                            This may not be the right place to post this question however being new here I thought it the best place. I have a Hisense 40d50p and i'm trying to prevent it from overscanning on my PS4. I have set the screen mode to PC which eliminates the overscan but prevents me from setting sharpness and colour. I have entered the service menu and changed the settings in there. Now for my question how do I get the settings to apply after I have turned the TV off or changed the input? I have searched all over google but can't find an answer so any help would be greatly appreciated.
                            • Gerry9
                              • Feb 2017
                              Thank you for your list of codes. I had been looking for the RCA code and voila, you had it. It fixed my problem which was the following:
                              Source was stuck on pc input. Even if changed to another input, it just came back to the pc input. Problem solved with resetting tv to initial manufacturer settings.
                              • billydanger
                                • Feb 2014
                                • 15
                                Have a Sony Bravia KDL-40SL140 with no remote. According to service manual I should (using the remote) enter
                                DISPLAY 5 volume + POWER
                                to enter service mode. Since I have only a systemlink 3 universal remote (no DISPLAY key) does anyone know a way to enter service mode without a remote (or with universal remote)?
                                Thanks in advance.
                                • tcolwell
                                  • Feb 2017
                                  • usa
                                  #96
                                  where'd you get this? i'm looking for something similar for my samsung UN39FH5000 remote
                                  • dreamerx213
                                    • May 2017
                                    Hi I have a Insignia ns-55d510na17
                                    The other day i stumbled across the service menu and changed the white balance settings. How can I reset them to factory defaults ?
                                    • Shariroxx
                                      • Aug 2017
                                      • United states
                                      #98
                                      Hi there, I am a first time user on this forum, so forgive me if I'm not in the correct spot. I am looking for factory reset code for an 65" olevia lcd tv.
                                      • Gavino_varne
                                        Gavino
                                        • Oct 2017
                                        • 5
                                        • India
                                        #99
                                        Hi I have a Skyhi 32 LED TV which is struck on android screen and does not go any further. I have tried multiple reset combinations from your forum's assistance and nothing seem to work. The main board on my TV is TP.MS608.P83 Could I know the combination for this mother board for a reset please ?
                                        Thanks in advance. I am new to this forum and I dont see an option to ask a query, so If I have not come the right way, I apologise. Request help plzzz.
                                        • Gavino_varne
                                          Gavino
                                          • Oct 2017
                                          • 5
                                          • India
                                          #100
                                          Hi Can anyone out there please please help. I have a Skyhi TV with the main board being TP.MS608.P83. The TV stands on Android loading screen and does not go any further. Please help if I could do some sort of reset or if I could get a firmware for the same
                                            LCD LED TV Service Menu Codes
                                            TCL LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            10-31-2024, 03:58 AM
                                          • RRice25541
                                            Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                                            by RRice25541
                                            So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                                            the color is all outa wack, like the settings have been corupted,
                                            I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                                            so
                                            The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                                            when i bring up the menu and type the pass codes to access either mode the menu disappears...
                                            05-13-2022, 10:44 PM
                                          • howardc64
                                            M557-G0 no WiFi/Bt no WIFIVendor file?
                                            by howardc64
                                            Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
                                            • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
                                            • Service Menu shows many Bt/Wifi info missing
                                            • Vizio app shows no WIFIVendor file
                                            Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
                                            • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
                                            10-15-2024, 01:12 PM
                                          • dxz
                                            lenovo thinkpad e480 problem
                                            by dxz
                                            howdy yall,
                                            back in this last december i lost my svp for my thinkpad, then i found this technique and it worked successfully.
                                            the only thing i found weird was that now in the bios menu, specifically under the secure boot configuration in the security tab, it went from mentioning microsoft windows 10 to now showing microsoft windows 8 when i scroll over the restore factory keys option.
                                            and im wondering if my current problem is due to the flash/patch ive done:
                                            im having a hard time activating windows 10 pro :lenovo thinkpad e480 that i purchased...
                                            06-16-2023, 04:10 PM
                                          • Retro140
                                            Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                            by Retro140
                                            So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                            To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                            06-18-2023, 06:13 PM
