Philips 32 PFL 7762D PSU problem
  • manoftheyear
    • Nov 2010
    • 39
    • Europe
    Hello.
    Got myself a bad Philips TV, gives an error code 2, service manual says it stands for "12V missing".
    Two N-channel mosfets shorted, marked Q301 and Q302 on the board, these are for making the 12V and 24V, right? Should I suspect something else gone bad too, anyone?
    The MOSFETS are STP10nk60zfp, what else to look for than the usual current, voltage and RDS on values when getting a substitute? How much the RDS on can differ from the original one? Would FQPF10N60C be an ok choice for replacing the originals?
    Attached the schematics I found from the internet if it's of any help.
  • gilly1984
    • Jun 2012
    • 751
    Re: Philips 32 PFL 7762D PSU problem
    I know when i had a shorted fet it took out a pwm ic controller too. This was on the primary side though.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
      Check or replace the IC that drives these MOSFET's, check the resistors and Diode connected to the Gate of the MOSFET for shorts or open. I recommend replacing the IC because if the out put drive pins are stuck at High (+ drive) it will take out the new MOSFET's.
      • manoftheyear
        • Nov 2010
        • 39
        • Europe
        Diodes D301 and D302 are OK as are the resistors, these are smd types tested them off-circuit. These are connected to the Gates? Then again resistor R1 is open. It is connected to Drain. D1 tested OK. You still think the IC (DLA001) might be bad? At least none of the pins are shorted to each other.
        Can I replace these:
        with these:
        • manoftheyear
          • Nov 2010
          • 39
          • Europe
          Anyone??
          Could replacing the resistor and the two MOSFETs (and probably the IC that drives them) cure this one?
          Any opinions on those MOSFET substitutes?
          • imran khan
            • Mar 2013
            • Pakistan
            I have Philips LCD 32PFL5203/98
            Power Supply Board Number
            Dsp-182CP
            Q602 and Q603 both are K3569 found short circuit with blown open R804 0.10 ohm,no any other parts found short
            Re-install new parts with orignal one but its short again,
            • janos6662000
              Philips 47PFS7509/12 LCD TV problem
              by janos6662000
              Hi
              I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
              When i applied cable signal to check image, i had normal picture, but TV was restarting.
              I downloaded original firmware and applied the update, but the problem remained.
              From a colleague i received a "factory package software" which is a lot bigger.
              I made another firmware update, but still did not solve the problem.
              Somewhere on the way the error got worse, because at the moment the...
              08-12-2025, 12:54 PM
            • courtcircuit
              Philips HTS8000 home cinema noise problem
              by courtcircuit
              Hello
              I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
              Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
              Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
              I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
              Removed each of tyhe boards
              02-08-2025, 08:22 AM
            • artenidas
              Thinkbook 14 G2 ITL problem with open MOSFETs.
              by artenidas
              I'm working on a USB-C powered laptop (Thinkbook 14 G2 ITL) motherboard K051P with the TPS65994 (U24) and USB-C controller (UT1, likely JHL8040R).
              Here's the current status:
              U24 has both 3.3V and 5V present
              The EEPROM for U24 has 3.3V on pin 8
              UT1 also seems fine (has 3.3V supply)
              No shorts found anywhere on the board
              EEPROM was flashed and soldered correctly, the .bin file is exactly 32KB, so it looks valid
              🔧 The problem is:
              The second MOSFET (PQS12) is not passing 20V...
              08-04-2025, 06:44 AM
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • bohaboha
              PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
              by bohaboha
              Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
              how to fix it thanks
              02-05-2025, 09:23 PM
