Hello, looks like there are some smart / experienced folks on here so thought I'd ask for help in trying to fix a tv.
My Background: noob/enthusiast when it comes to fixing electronics, pro when it comes to using them
. I'm very mechanichaly inclined though just need to know what to do.
Story: saw a plasma at goodwill, looked good, red standby light was on but tv didn't power on, 30 bucks, figured it was worth getting and seeing if I could get lucky. Plus I used to have a pioneer elite projection tv, that had power supply issues (ended up just being bad connections on power supply board from heating and cooling, made it work).
TV: Pioneer Plasma PDP427CMX
Issue: won't power on when pressing power button, standby red LED on front of tv stays on, solid red when tv plugged in and power switch is turned on.
Goal: to make this TV work, hoping that it's something simple and not a few boards that actually need replacing at a few hundred bucks a piece, would be sad to throw away such a nice piece
What I've done so far:
-took back of plasma off
-researched what could be wrong when similar issues
-results came back as bad power supply board or caps
-looked around all boards and caps and everything looks good
-also noticed a red LED on power supply board that is not on and a tiny red LED on a small board next to power supply board that is on, so small that i wouldn't notice it was an LED if it wasn't on (not sure if these are supposed to be on or off but wanted to say in case it means anything).
-checked connections on boards, all look good
-researched more about caps
-noticed two caps on power supply board (near them the part of the board was labeled "secondary") could possibly be bad, were just slightly bloated on top, ordered same 2 caps on mouser (250V 820uF), removed old ones, soldered on new ones, plugged in TV, power switch on, crossed my fingers, pressed power.... nothing changed
Not too surprised since i troubleshoot stuff all the time and usually first thing usually doesn't fix the issue, would be nice though
So now I'm here because I don't give up that easy and hoping that maybe someone can give me some input on what/how to check or maybe someone here has worked on one of these TV's.
Tried to be as descriptive as I could but if I missed something please let me know, also can post pics later tonight if they might help.
Thanks for reading and look forward to any asistance on the matter so i can press that power button and smile when that red standby light turns to green!
