Pioneer Plasma TV on standby and won't power on
  • vovay45
    • Nov 2015
    Re: Pioneer Plasma TV on standby and won't power on
    Pioneer PDP-42-A3HD
    When I turn power ON
    1.Green light is ON
    2.I hear some relay switching on and off but nothing on display and no control.
    • Tomo175
      • Dec 2015
      Pioneer model 6020FD won't turn on. Stand by red light blinks 5 times.
      Any idea what this error code means?
      • Bjames
        • Mar 2017
        • Us
        8 blinking loghts on a pro 1150HD I DO HAVE POWER IN THE supply board but is there a way yo test the main. Board?
        • kach11
          • Apr 2017
          Hope someone can help clarify my standby issue. I read the replies on this thread but not sure if it pertains to my plasma issue.
          I have a pioneer plasma PDP 5070. It was working earlier today. However, I used my remote control from my cable box to turn the TV on/off and watch.
          Then I powered off/standby to unhook the cable box which, I needed to switch out for a new box. It was couple of hours before I reconnected the cable box and tired to turn the TV on. I tried to turn the power on directly from the button on the TV and it just remained on standby. I used the pioneer remote control and nothing happened. I switched out the batteries on the remote and noticed that the LED transmission/sensor lights up for all of the buttons on the remote EXCEPT for the TV power button. It seems like the remote control does not sense/transmit any signal.
          Not sure if this issue is the same and I have some how triggered that trap switch. Can someone advise?
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • lp20th
            Samsung Plasma TV Power Supply Issue
            by lp20th
            I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
            11-28-2023, 10:28 AM
